Vegaspilot99
- Nov 24, 2003
25.1457 Refers to CVRs, and supports the requirement for Boom Mics.
121.581 Refers to the observers equipment, they decide.
AC20-110L Refers to TSO items, see TSO C57a.
The requirement to use TSO qualified equipment where a TSO exists are implied. The requirement for "boom mic" requirement also implies that for a part/product to be satisfactory it must be meet TSO approval. One of the requirements of the TSO process deals with the failure modes, all TSO approved products requiring power failure to the safe mode. The uFlymike unit is fail unsafe, when the batteries go dead, the unit stops working.SKYW policy manual/SOP requires "headsets to be used below 18,000MSL" This debate is like almost all the debates in aviation, no one will know until something happens. What are you gonna do when the batteries fail in cruise and you miss the descent call from ATC, or you miss a heading and fly into restricted airspace, or even worse miss that traffic call/turn? As cheap as pilots are, it is mind boggling that you would fiddle with a product that cause so much havoc if it were to fail. uFlymike has a vested interest in this debate, I have none, except for the academic. Do the math and your own research. Sorry 'bout the mistyping on the reg numbers, I am tired after a long flight day.
PBR
Ok, thanks for the clarification. It is a good setup, just that one downside...but if you keep an eye on it, you shouldn't have a problem. I've also been trying the Telex 850, but it isn't as comfortable or quiet (been told the 700/900 are louder up front than the 200) and I do have the Bose X, but it's too big to fit in my flight case with all the other jet crap I gotta carry. Dilemmas, dilemmas. Hopefully Mike gets the TSO cert and the problem will be no more.
