Read the regs sometime, the regs require a boom mic below 180000ft. The regs also say that the Fed is determines the headset they use. Start with 121.359 (g), work your way over to 121.305, take a whiff of 121.317(b), then slide over to 25.1457 and read em and weep.The fed himself on my captain fed ride was wearing a uflymike, I'll leave it at that...
I use Uflymike and love them and had a fed on my jump seat the other day. I just didn't let him see them and used company headsets for that flight. I do love them though. They are awesome.
PBR
Suks to be you, and wrong all at the same time!
Ok, so I looked up all these regs and 121.359(g) and 25.1457 only refer to boom mikes and CVRs. The other two sections didn't even mention headsets anywhere that I saw (121.305 is instruments and 121.317(b) is No Smoke Sign/Fasten Seatbelt Sign usage). Anyhow in all these sections no where did it say anything whatsoever about TSO applicability or headsets needing/required to TSO'd. So where specifically does it state all headsets used in 121 ops must be TSO'd??? I don't see it anywhere and it's not required per the SKW FOM.
You keep telling yourself that, over and over. That will make it legal. You won't use that setup while you fly with me. Good luck.I use a uflymike on the crj. It takes one AAA battery. I can change the battery on my headset faster than I can don the damn O2 mask. PBR, don't think that's gonna cause us to bust airspace. Not to mention the headset itself gives you something like 5 hours of warning before the battery dies. That question was even in one of our (skyw) quarterly training bulletins. The only requirements/regs are that we use a headset with a boom mic on it. Nothing in our op specs. Nothing in the FAR's.
PBR
Bottom line any device that fails unsafe isn't worth the money. I will ask the question again, If the battery goes dead , does your product still work?
PBR
Correct me if I'm wrong, but I don't believe any LightSpeed headsets are TSO'd either.
