400A
 - May 26, 2003
A tire shredding itself apart at 100+ miles an hour ca nput a hole in the fuselage, desrtoy all the hyd lines to the gear, etc. The LR tires are so small, their RPM is much greater than it would be say on your Hawker. Because of where a squat switched is placed, taking it out would just be getting started. No problem at all. Look what happened to the Concorde with a blown tire. It tore a hole through the airplane into the fuel tank.
With the Squat switch out, the plane could think it is now in the air (Weight Off Wheels), and it could stop the T/Rs from deploying as well as stop the boards for extending, or at least extending as far as the should on the ground. Take the Life dump of your Hawker for example. With the flaps in the #3 position and WOW, the lift dump further extends not only the flaps as you know, but the boards as well. A squat switch telling the airplane it's in "air" mode would be the same you not having flaps in Pos. #3. The boards and flpas would not extend any further. Does that make sense?
Oh yeah, that is exactly what I was afraid of. I Just knowing nothing about the 60.
That would be a sick feeling. Blown Tires and now in Air Mode. Yikes.
