AirplanesSuck
Malevolent Matriculator
- Sep 17, 2006
RIP Sara and James.
There's absolutely no reason that the 31, 60 and 45 shouldn't have had a dragchute like their predecessors.
1) Correct... if the T/R relay box receives "air" signals from squat switches.
2) Not completely correct... the hydraulic pressure for brakes comes from the nose gear down line. However, the anti-skid function is controlled by individual squat switches. The only way you can guarantee effective brakes (with squat switches in "air mode") with the gear down is turning the anti-skid off or using emergency braking.
Not trying to nitpick, but the question was "will you loose brakes if a squat switch is damaged?" No, you will not, you could loose the anti skid function, but you still will have full brake pressure.
3) Not completely correct... The squat switch relay box uses signals from both switches, and as long as one is in "ground mode," the relay box is in "ground mode." However, many systems bypass the relay box and get signals from both squat switches individually (anti-skid, for example).
True, some things are controlled off of individual switches. But I was trying to answer specific items. You cannot speed up the engines with the piggy backs up and the T/R's closed, and you do not loose total brake pressure either.
4) Correct. Aborts do not rely on autospoilers... they are to be fully deployed manually.
Edited so as not to offend anyone who writes more than he/she reads.
Why would a 45 need it? Awesome brakes.
RIP Sara and James.
My suggestion would be to GET A NITROGEN TIRE GAGE AND START CHECKING your tire pressures yourself.
Is there such a thing as a Nitrogen Tire Gauge? I never thought of it before, but wouldn't any high-quality calibrated tire gauge work? Pressure is pressure, right?
Yeah my condolences too. My man Jumbo. Hey there I don't think the 45 needs a chute as the carbon fiber brakes and landing gear are state of the art. We had balanced field length at Lugano, Switzerland and it's as short as it gets. They really do work well. How's Continental Treating ya?
C
Anyone that doesn't think a drag chute on every Lear built (new or old Learjet) is NOT a good idea....is just an aviation MORON.
PERIOD.
If you or Bombardier...or any other pilot on earth thinks that a drag chute is a bad idea.....well, you are just that..............MORONS. All of you.
Not trying to nitpick, but the question was "will you loose brakes if a squat switch is damaged?" No, you will not, you could loose the anti skid function, but you still will have full brake pressure.airplanes suck said:2) Not completely correct... the hydraulic pressure for brakes comes from the nose gear down line. However, the anti-skid function is controlled by individual squat switches. The only way you can guarantee effective brakes (with squat switches in "air mode") with the gear down is turning the anti-skid off or using emergency braking.
And, I certainly take no offense to you for answering. As has been said before, I think we are all just trying to become better educated on this.
Best regards
Hung
Bombardier does not put the drag chute on the Lear 45 because of cost. Cost is much more important than human life or cost of damage caused by an incident/accident. Go to school and learn something before you comment on liability or anything that has to do with damages. It actually takes some education in a college type setting to realize how important human life really is to USA corporations.
Bombardier would much rather have a certain amount of people die per year, and the insurance companies associated with those operators pay the court awarded claims.....rather than have to make their planes that much more safer and more expensive to their customers.
If you don't know this, all I can say is: go back to school.
Death and damage is a calculated figure....manufacturers KNOW for a 100% fact that both WILL happen. They just have to gamble and build airplnes OR go out of business and do nothing. Its America and they have good lawyers, so they gamble and make planes and ALSO make 100's of millions of $$$ in profit.
Airlines are the same way. They know crashes will happen and are actually waiting and they are prepared for these crashes to happen. They have crash councelors ready, chaplins for the religeous people, media contacts ready to repspond, spokesman to say the right things to the public, and whatever else is part of an air crash. And all they are really worried about is "how do we keep the monetary damages to a minimum." The aircraft manufacturers also have speeches prepared for any crash that might happen. Its part of the aviation business. Live with it or get the hell out. If you think the great and horrible loss of life is NOT going to happen again, well, get the hell out of the aviation business, because you are part of the problem.
Its going to continue, crashes are going to continue, and arguments about how crashes happens will never stop.
Education before, after and during crash investigations are all we have to make the future safer.
Good luck.
space...............
Clean-sheet design of the 45 and improved XR (this goes for the 40 as well) to improve safety with this aircraft. Improvements such as emergency free-fall Gravity extension trailing link landing gear with 1800 cycle life Carbon Fiber Brakes that offer unbelievable stopping power, plus the standard backup hydaulics and emergency brakes. An improved pressurization that is much more user friendly and bleed-air system that supplements with HP air during low power settings when the ant-ice is on. A Spoileron back-up roll control in case of total aileron failure. Split elevator system with manual disconnect in case of elevator jam on one side. A much better designed wing with wing droop and vortilons to lower ref speeds and improve low speed handling amongst other features such as an improved spoiler system. Delta Fins that produce lift in the event of an inadvertant full stall that give this aircraft stall handling characteristics that are as docile as one could possibly hope for which also reduce ref speeds and dutch roll. (Bombardier Training Center in Dallas will let you demonstrate this in initial and recurrent training) a split bus DC electrical system that automatically load sheds and turns off power on the non-essential busses during a single or dual generator failure.
All nice things, that were already on airplanes in the 1960's.
Go back to some kind of school and then start posting your bullsh!t.
If you were being funny or meant to say something I didn't get, sorry. Be more specific when people have lost there ************************* lives.
Huh? That was a completely serious question. I have never heard of a "Nitrogen" Tire Gauge, hence my post. I'm not an A&P, just a pilot. We check the pressures fairly frequently on our -60, but as far as I know, we don't use a "Nitrogen Specific" gauge. If such a thing exists, or if we are using something inaccurate, I want to know.
How you interpreted my post as "being funny" or "Bullsh!t", I'll never know.
Not funny. My drunk dumb friend posted on my computer last night. Disregard.
But I do like drag chutes, they have their place. lol
Sure it was. It's nice to save face, isn't it?
