Travis Barker - 4 killed, 2 hurt as rock star's jet crashes
Yep
Thats scary stuff. You pull on the reversers and get forward thrust instead? Something wrong with the design there
And if you dont know how to finess the TR's to the stowed position after landing the passengers will sure know it by the forward surge of the aircraft as you taxi off the runway.
Notapilots post was from the NTSB report for the Jerry Jones Lear 60 crash.
I believe that there was a mod put on later aircraft (there is a list of S-B's available, ask at recurrent) that allows both TR's to deploy with only one squat switch in ground mode. Ill see if I can find it. Nevertheless if they stowed uncommanded the FADEC should roll them back to idle and making the piggybacks useless.
Also keep in mind ground idle is 52% N2 which is not bad but air idle is 65% which gives you quite a push.
The standard brakes steel two rotor assemblies(later models including the one in question should have had the three rotor brakes).
It would have been possible to have brakes on only one wheel if a tire blew and caused a sq sw to fail to air. If the left inboard tire blew and failed the left squat switch to air then both out board brakes would be useless and the crew would only have normal brakes on the right inboard. The only way (other than emer handle) to regain toe brakes would be to turn the antiskid off. This would close the solonoid shutoff valves and allow brake pressure to the remaining three wheels, with out antiskid protection mind you. You have to be pretty on the ball to think of it though.
Concerning the earlier discussion of high/low speed aborts (this is only what I have seen and I am in no way being critical of these crew members) everyone always gives the "standard" brief. Nevertheless the vast majority will abort for AHS,ADC,PFD failures and so forth. Secondly you dont always know its a tire failure (no annunciator for it). What if it was a flight control issue. They had only seconds to decide. While most people would be ok taking off after 80/90 kts with a blown tire they would not with a flight controll malf. Going back to what I said earlier most people abort for anything and the whole "band,swerve,or bell" goes out the window as soon as something abnormal happens. Ultimatly the PIC's decision if the safety of the flight is in queston.
I am not second guessing the crew nor am a suggesting that anyone here is. We will never have all the facts. The best we can do is learn from this tragedy.
Some of the earlier posts were extreamly critical of the 60. To me its like an excentric uncle. I can make fun of him but if anyone else says anything they better watch their a$$. The 60 (as a lot of other planes I would assume) is a mix recent and ancient technology. Lets not forget that the basis for the lear came from that old fighter (what was it swiss or spanish I think) that Bill Lear got a hold of. Among other things the 60 had the old brakes (including antiskid), a modified verison of the wing, and a plug stuck in a 55 fuselage to make it longer. But up front it had fairly recent (in the case of the XR very recent) avionics, and in the back it of course had those wonderful PW305A'a with FADEC. No it would pass cert if it was put up for it today but that does not mean that it is unsafe. On the contrary it has been a very safe airplane. Like most aircraft it has its own idiosyncrasies that you have to nake yourself aware. While there have been accidents this was the first to include fatalities.
Fly Safe and RIP to the fallen crew.
Some of the critics of the 60 (like me) are also "nephews" and your "cousins" to use your parlance. The only reason I don't tell passengers not to buy/fly on the plane is that it's my moneymaker. It's a blast to fly, but when you have to put it to work out of short runways, reasonable amount of bags, high elevation... it doesn't make the cut IMO.
briefs
Good post USC. In my post about briefing and doind what you briefed I should have made the disclaimer as you did, that ultimatley it is the PIC making a decision. I too do not know what they saw out that front window as they heard the "pop" off a tire blow. I was just describing what I saw and felt the 2 times it happened to me. I hate speculation , and I hate when people think every situatuion is the same or similar. I know that I felt the tire blow and we slid left as we were going down the runway, in looking back, I knew we were going no matter what, even if we traversed throuch the grass slighly while still moving forward. Stopping was not an option, we were about 1.5 seconds from being able to fly, with 2 powerful engines still propelling us forward. Get up, get clean and discuss options later. That was our mindset.
I think briefing for an engine failure, fire, tr deployment, loss of dir control or a major airframe issue and then doing an abort for an AHS or PFD failure, tire pop, bird stike.....the list goes on, only puts the gray back into a black and white mentality that we should have in these critical seconds. Thats what they are seconds. 2 good engines, a good wing and forward momentum and it should be a go all the time unless one of the briefed items comes into play. We truely are seconds from getting in the air. A red blink and a master caution annunciating a door light or similar should not trigger a roll back in power.
I like what you said, We will NEVER know the whole situation. Accidents and incidents are only beneficial in one way way, and that is to spark conversation, reflection and the chance to hear others somment on what theyhave done, would do, or should do in a similar situation. But not at the expense of questioning a crews decision.
Again good post and my prayers for the families involved.
more info here: http://www.wistv.com/Global/story.asp?S=9043949
It says the 2 pax who did not survived died from blunt force trauma, and the pilots from smoke inhalation.
I wonder who was sitting where, and which exit they used. They say that most people in an emergency automatically go for the door they entered through...
Edit: a picture shows the outer main cabin door handle in the closed/locked position... so I guess they did not go out that way
actually your numbers there come to a ramp weight of 21000. Pretty heavy...
Opps...yep...too quick to add...
So yes, about 6000 min fuel for that trip depending up on wx.
So yes, it is likely the RTB to TEB was done at a pretty heavy landing weight, and our figures do not take into account pax and cargo.
Hmmmmm
I am not picking on you, but the accident investigation found otherwise.
Normal operating procedures include deploying the thrust reversers within 4 to 6 seconds after landing. Pilots deploy thrust reversers (T/R) by raising piggyback levers located in the cockpit with the throttles. With the loss of the squat switch on the left main landing gear, the T/R relay box deenergized the deploy solenoid and the T/R's go to the stow position. The electronic engine control (EEC) commands the engine speed to go to idle. As the T/R's complete the stow cycle, the unlock switches open, signaling the T/R relay box to remove the discrete signals. The EEC's switch to the forward thrust schedule and within 2.6 seconds estimated, and if the piggybacks remain at the max reverse position the engines rpm begins to increase to near takeoff power.
I am in no way saying the 60 is a bad airplane or this was the cause. It is a strange similiarity. We all understand that we will know more in time, but accidents like this cause us all to think about systems and what ifs. That may be the only positive outcome of this tragedy.
If they blew a tire 2800 feet down the runway they would either abort or continue the takeoff. If they continued the take off and had some issue that prevented the airplane from rotating, it is likely that they may have realized this and eventually decided to abort. Similiarly in the TEB Strawberry crash after the aircraft would not rotate they did attempt to abort. I think it would be instinct to do so. So in either situation if an abort was made it seems strange that the TRs were not deployed. I would have a hard time believing that they would not have deployed the reversers at some point on the ground as they watched the end of the runway, fence and hill through the windshield fastly approaching. Especially since all 60 pilots know the brakes are the weak link. This would seem to support the same abnormality that happened in the J.J. crash. It would be deplorable if this problem was not fixed after the first accident and even more so if this likelyhood is not being discussed or trained in school.
Do any 60 crews know if there was a mod for this problem? It would have probably been in the last 5 years.
