Travis Barker - 4 killed, 2 hurt as rock star's jet crashes
Didn't a witness report sparks going down the runway? Would both tires on one side have to blow to get this? Wouldn't one carry the load without dropping the wheel? Looking at the tmz pics, #5 specifically, it looks like they split the localizer (4 L and 6 R) -- if only one side failed, wouldn't it pull hard left or right (the loss of directional control)?
The controllers supposedly reported sparks, but not "lots of sparks" or "sparks for a long time" so who knows?
The anti-skid/brakes should work on either the inboards or outboards as long as one squat switch is in ground mode. Of course your sim scenario just sucks... I hope it didn't happen to these guys.
If you have an explosive tire blow.. it will most probably take out the wiring to the anti-skid... Loss of one side takes the anti-skid out completely.. if that happens and you are trying to stop the airplane the remaining tires will most certainly blow.. Here is the question? What constitutes a loss of directional control? When we blew our tire the airplane moved off to the left side of the runway.. since that wasn't what we wanted recovering seemed logical ..and since the airplane didn't respond properly and we were below v1 you abort.. without Anti-skid and all that friction you end up with blown tires on all sides not brakes and essentially no steering. you are unfortunately along for the ride at that point. I have argued with the FAA and at Recurrent about this and I still think no abort for blown tires above 80 kts on short runways especially... Problem is ( as what happened to us) you have to decide instantly and if the airplane does not seem to respond to your inputs you react.
additional...
Just a side-note that they planned on a 10:30 PM departure and got airborne at 11 PM. I believe they were headed to Van Nuys, an o-dark thirty trip.
Don't know if night conditions, runway glare, etc contributed. Also as most know, Hollywood VIP's are high maintenance pax.
I will defer to NTSB for the official report, but I do wonder how many "side issues" were in play besides a pure blown tire.
You obviously care what I think, otherwise you wouldn't have written such a thoughtful response...
But you're right, what do I know...my wife is just a legal professional who specializes in FAA enforcement actions. I guess I foolishly let her professional experience help form my judgement on the legal differences between a recommendation and a requirement, or "should be" and "must be".
That's great - good for her, great accomplishment. You know what? "Must be" was never used in any of my replies. I believe I used "required", "should be", and "recommended" as words. If it is something the FAA recommends than it could be considered a requirement I mean it will honestly be considered in an enforcement action as I am sure your Wife can tell you. The definition of requirement does not use "must be" anywhere in it's definition. You do what ever you or your wife choose, for all intensive purposes I would treat an FAA recommendation like a requirement when operating just like holding pattern entries and the VFR traffic pattern. Why are they treated like requirements from the beginning of Private and Instrument training but are just recommended?
[FONT=Arial, Helvetica, sans-serif]It will be interesting to see at what speed the abort was initiated. I said a prayer thanking the aviation gods the last time I flew a Westwind (a single tire on each main), a blown tire on that airplane would make for a bad day at any speed.[/FONT]
[FONT=Arial, Helvetica, sans-serif]From what I remember of Boeing's study on RTOs, most fatal RTOs occur during a high-speed abort for a problem that would've been better handled in the air. (I'll let the NTSB make the conclusions on the CAE crash.) But here's a snippet:
[/FONT]
[/FONT]
[FONT=Arial, Helvetica, sans-serif]A takeoff may be rejected for a variety of reasons, including engine failure, activation of the takeoff warning horn, direction from air traffic control (ATC), blown tires, or system warnings. In contrast, the large number of takeoffs that continue successfully with indications of airplane system problems, such as master caution lights or blown tires, are rarely reported outside the airline’s own information system. These takeoffs may result in diversions or delays, but the landings are usually uneventful. In fact, in about 55 percent of RTOs the result might have been an uneventful landing if the take-off had been continued, as stated in the Takeoff Safety Training Aid published in 1992 with the endorsement of the U.S. Federal Aviation Administration (FAA). [/FONT]
[FONT=Arial, Helvetica, sans-serif]Some of the lessons learned from studying RTO accidents and incidents include the following: [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]More than half the RTO accidents and incidents reported in the past 30 years were initiated from a speed in excess of V[SIZE=-2]1[/SIZE]. [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]About one-third were reported as occurring on runways that were wet or contaminated with snow or ice. [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]Only slightly more than one-fourth of the accidents and incidents actually involved any loss of engine thrust. [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]Nearly one-fourth of the accidents and incidents were the result of wheel or tire failures. [/FONT]
  • [FONT=Arial, Helvetica, sans-serif]Approximately 80 percent of the overrun events were potentially avoidable by following appropriate operational practices.[/FONT]
blown tire
I too had a blown tire twice with the same airplane, same side, 6 legs apart. Found to be a wiring/ohm level issue. It would lock one tire up and flat spot and blow on takeoff. The airplane both times pulled to the affected tires(outside left main). At 100 knots. It felt like a sudden crosswind pushing the airplane. The left wing dipped low so I applied right yoke pressure to raise the left, sliding slightly to the left as we lifted off, and talked about what happened in the air. Landing was uneventfull until reaching about 70-80 knots when the airplane began to shake violently as the tire was now slapping the flat spot over and over again as we continued to roll to a stop and got tugged in.
Not sure what happened here so I am not saying its the same situation, but I agree with the previous posts that an abort for what 'FELT' like a blown tire after 90 knots is not something I would abort for unless it is catastrophic resulting in total loss of control. Taking it up and having an chance to get your wits is a better plan even if you cross grass/taxi ways... if your that close to getting the aircraft to fly it would have to be a MAJOR event to stop. In the military they say an abort after 100 kts usually results in bent metal.
http://www.foxnews.com/story/0,2933,425710,00.html
How close to max landing weight would or could they have been when landing back at TEB? any 60 drivers care to figure out the fuel required for TEB-TUL minus time in air and landing weight back at TEB? Could it have stressed the little tires?
Just ran the profile with todays winds.
Burn shows 4200 and 2+49
Plus 1600 for rerserve
Plus a couple hundred for ATC/TEB delays, etc
And I have taxied out with 5,000 minimum for that trip.
Plus 15,200 gives a ramp wt of 20,200 before pax and bags.
They mileage may vary....
I have flown the Lear 60 for a few years and blown tires have never been said to cause a directional control problem. I had a tire blow in a 60 on takeoff at 105-110 KIAS. We continued the takeoff with no issues or directional control problems. We also landed 2 hours later without incident.
Blown tires in the 60, or any aircraft, are known to severaly impede brake effectiveness. Other possibilities in the 60 after a blown tire are flap damage, hydraulic brake line rupture, squat switch damage (causing spoiler, T/R, and anti-skid braking problems). Any number of things could happen.
After my blown tire incident, I concluded aborting after 80 KIAS for a blown tire is a bad idea in almost every case. Everything I have read that has data on the matter would agree.
(I'm assuming you flew 2 hours to your destination of course.)
But only thing I certainly would NOT have done was retract the gear and gone on a 2 hour flight. It may not have come back down depending on what could have gotten damaged on the gear or any rubber jammed in there somewhere. Like they did a few weeks ago at LAX, just burned fuel and landed.
Pilots call I guess on that though.
"National Transportation Safety Board member Debbie Hersman said a cockpit voice recording of the Friday night crash indicates the crew tried to abort the takeoff, but then signaled the efforts were failing.
"The crew reacted to a sound that was consistent with a tire blowout," Hersman said.
Hersman said no cause of the crash has been determined and the investigation is ongoing. She did say that pieces of tire were recovered about 2,800 feet from where the plane started its takeoff. The runway is 8,600 feet long. The plane was traveling at least 92 mph, its minimum takeoff speed, when the crew thought the tire burst, Hersman said."
And this if from the Learjet 60 accident at Troy, AL:
With an estimated empty weight of 15,800 pounds and estimated fuel of 1,100 pounds, it was calculated that the airplane traveled 1500 feet down the runway after touchdown in 4.2 seconds before striking the deer, the performance group at Learjet using the weather reported at Troy, Alabama (variable winds and temperature at 14 degrees Celsius) the airplane landed with a ground speed of 124 knots. At 124 knots and maximum braking applied, the airplane should have come to a complete stop in about 850 feet.
A sound spectrum study was conducted using the Cockpit Voice Recorder as the source of the sound. The study was conducted by the National Transportation Safety Board's Vehicle Recorders Division. The study revealed that the engines fan speed increased from 8727.5 (82.3 percent) rpm to 9590 (90.4 percent) rpm between 11 seconds after touchdown and 18.2 seconds after touchdown. This increase in fan speed does not achieve the calculated takeoff N1, however, this engine speed is higher than achievable on a reverse thrust schedule. According to Pratt and Whitney of Canada, N1 is governed during reverse operations. The governing limit varies, and is based on ambient conditions and the airspeed. At 100 knots or greater, the maximum governing limit for N1 should be about 85.2 percent (according to Bombardier Aerospace) instead of the 90 percent found on the engines 20.4 seconds after landing.
Normal operating procedures include deploying the thrust reversers within 4 to 6 seconds after landing. Pilots deploy thrust reversers (T/R) by raising piggyback levers located in the cockpit with the throttles. With the loss of the squat switch on the left main landing gear, the T/R relay box deenergized the deploy solenoid and the T/R's go to the stow position. The electronic engine control (EEC) commands the engine speed to go to idle. As the T/R's complete the stow cycle, the unlock switches open, signaling the T/R relay box to remove the discrete signals. The EEC's switch to the forward thrust schedule and within 2.6 seconds estimated, and if the piggybacks remain at the max reverse position the engines rpm begins to increase to near takeoff power.
full report http://www.ntsb.gov/ntsb/brief2.asp?ev_id=20010119X00328&ntsbno=ATL01FA021&akey=1
I hope she does a better job with the press than she did in Lexington. She really didn't impress me and made me think she really didn't know what she was talking about.
According to the PTM, that is inaccurate. The PTM states that the "Left squat switch controls outboard wheel brakes; right squat switch controls inboard wheel brakes."
92 miles and hour? min takeoff speed? is that an accurate quote?
If anyone tried to take off in a 60 at 92 mph, we'd be having another accident discussion. V1 is usually 115-125 knots and Vr is usually 125 to 135 knots. The minimum rotation speed is like 120 knots if you don't have any payload or fuel. Was that a media eff-up? They know nothing.
Maybe she did say it and meant "high-speed regime" or something.
see my edited previous post, if you lose the tire and reverse function with half the brakes remaining, then grab the emer. brake....well it is bad and gets worse with more tires blown! Almost impossible for the pilots to get it stopped.
You bet. The 60 is a strange little bird. Tragic accident... I think this was the first fatal 60 accident? (at least in the US).
I can't speak for the 60 but the 31A if you lose one transducer the opposing one shuts down so you don't have antiskid on one side and not on the other..
That's possible... I'll have to acks around. But the way the 60 says it's set up you get anti-skid on left and right sides, but only to the inboards or outboards (depending on which squat switch you lose).
If one squat switch fails, the other squat switch still should be in ground mode. You would lose half of your antiskid (inboard or outboard), and you should be able to get one T/R out. The autospoilers must have both squat switches in ground mode to work, but the spoilers should work manually. If one squat switch is in ground mode, any movement of the spoiler lever past arm will fully deploy them. If both squat switch were in air mode, then the spoilers will go to whatever position selected with the lever.
Have you been drinking rocket fuel again?
She looks like Hillary at a younger age.
She is the one in the last picture.
http://www.flightsafety.org/photo_gallery.html
UGHHHH!!! Rocket fuels will not help her in the looks department. I would need some mind altering drugs, ie. lcd, pcp, shrooms taken all at once.
Seriously, it's finally great to read a thread that doesn't get into a bash fest (except for 1 or 2 posts). Alot of great info being shared. Hopefully, this info will help someone in the future.
In J.J. LR60 accident the TRs were deployed, but after the squat switch was lost the buckets stowed. What was thought was reverse thrust was actually forward thrust. This might not be the case here, but looks awfully similiar. It appears they maintained centerline, they departed the perimeter fence at what was described as a fast rate of speed and the TRs appeared to be stowed. I really hate jumping to conclusions, but it fits. Thoughts and prayers to all the families.
I personally knew Captain James Bland!!! He was a stand up guy. My heart goes out to his family, friends, and passengers. I didn't have the pleasure of knowing Captain Sarah Lemmon as she flew for Global Exec.
James was always willing to help you out with what ever it may be. Especially us young Captains. He had tons of experience that's hard to be matched, from flying for CBP to EJM and just starting with us in our Lear 60. James was brother you listened to!
He was retired from CBP though which I think is even worse. Here he is, living the good life..flying contract whenever he wants in his retirement! 52 years old (I didn't even know how old he was until this, he would never say b/c he really looked younger...always had that cop attitude though..lol) you show up to the airport for a trip and you don't have a clue about what's going to happen in the course of this trip.
I'm not a very religous person, but makes me want to make things right with that man upstairs! This crap happens to the best of us and you never know when it's your time!
RIP Captain Sarah Lemmon and Captain James Bland. You, your families and your passengers that parished, will be deeply missed. It's not your fault, it can happen to any of us out there!
God Speed,
Bryan
I assume this was cut/pasted from somewhere. If so, where. I cannot believe an aircraft would be designed like this. Who in the heck would think this is a good idea??? If the pilots wants to "stop," why should the engines be programmed to "go?"
Another question, can somebody describe the braking system aside from the antiskid?
Yes, from the NTSB from report for the Troy, AL Learjet 60 accident.
