Engine fail?
Exactly, but I think he was going in the other direction of your statement. Because of that raw power, and make no mistake, the 60 has its fair share, if you come to fly without your "A" game and one rolls back on you (before V1 or Just After), you will in fact have your hands full; a 60 can get away from you with minimal ease.In a 60?!? It ain't exactly a Seminole. Maybe if they both quit; a heavy 60 on one will still outclimb a CRJ. :laugh:
Can any airplane really be overpowered?
If the LR60 is known to be overpowered, wouldn't the proper description be under-winged?
A few years back I was a copilot on a Lear 31 and we had all four tires blow on takeoff.. about 10 Kts shy of V1 which resulted in a loss of directional control.. Once the tires blew, the wheel assembly hit the runway and shattered.. of course we didn't know at the time... had we not been on a 13,000ft rwy I don't think we would have survived. The wheels on the 60 are similar to the 31 ( if not the same). Just a Thought...
My thoughts are with the families... RIP
I've been told that............ if you position the rotary test switch to the "mach trim" position and push the test button, it will silence the horn. So I've heard.
I flew 60's for about 10 years. Completely agree with what was said earlier about the T/R and FADEC relationship! If I want full reverse, give me full reverse. Real curious as to what happened on this one.
RIP and Godspeed to everyone involved.
Feds determined FOD blew Right side Mains.. Then the Left Mains went about 2000 feet into the attempted stop. None of the Plugs blew... all the tires blew out the side wall. The initial Right side when it blew, dropped the wheel assembly onto the rwy.. and shattered.. No Brakes.. No Wheels... " D.O. Kept asking us.. the Acc. Stop..Acc.GO shows 4,300ft why did it take you 10,600 to stop..Duh.. No brakes or wheels.. No Directional Control..!!"
Within the same situation, some people get in trouble with the auto re-light; the plane snaps to the L or R, the pilot stuffs the appropriate rudder input, and about the time the pilot gets it headed back twards the centerline, the auto-relight lights off the engine that rolled back (Power levers are still in the T/O detent so power will come right back), and now that rudder input you have in, just snapped you back past the centerline, and here we go again.
Granted that's not the norm, but in the 60, you'll see that in the sim more often than you'd think because it is so overpowered.
I remember climbing at Vmo/Mmo well into the 30s could be done with no effort at all; Only time I have ever climbed @ 12K FPM (lasted less than 20 seconds) was in a 60; only time I have ever gotten an overspeed warning on 1 engine in the sim on a hot/high day was in the 60; only time I've ever seen a sim partner Vmc an airplane in the sim was in the 60, and the only time I've ever really scared the SH!!T out of myself, was as a new captain (from DA50s) in the 60. Power Power Power
Thousand feet per minute in RVSM airspace is normally recommended and required.
That's an old wives tale/aviation myth. 1000 FPM is reccommened during the last 1000 feet of level off and/or in the vicinity of other aircraft. This is simply to reduce the TA/RA alerts."And nothing like setting off TA's on airliners 8000' above you coming out of TEB, or doing 2600fpm out of FL360 with the overspeed horn going off..."
It is by no means required under any FAR or guidance that you have seen. IT may or may not be required in your RVMS manual; it is only because whoever wrote the manual put it in there and the FEDs signed off on it. Delete that statement and the manual would still get approved.
Okay, ever notice how a know-it-all usually doesn't? Like they say on the McLaughlin Hour "WRONG" Sorry to rain on your parade, I even supplied you with the link below. It's a recommendation by the FAA. BTW, I wrote several Aircraft RVSM Operation and Maintenance Manuals that were all FAA approved it's changing all the time. I'll tell you what, let's change it to "IT SHOULD BE " did you read the original quote? Now go crack that RVSM manual in your bird and study up. Look it up: http://www.faa.gov/about/office_org...ice_units/enroute/RVSM/documents/chng7mod.doc
It will be interesting to see what the air return on the 12th was for. From flightaware it looked as if they were heading to TUL and turned back then did 2 maint. test flights before heading to CAE. Of course none of this may be related. I took off over the crash site this morning and it was a little odd feeling.
http://www.thestate.com/local/story/530614.html
this says they radioed that they had a blowout but could not stop.
Now you wait just minute. I was not rude to you, short or curt with you, why have you choosen to respond in such a manner? I'll not have you speaking to me like that.Okay, ever notice how a know-it-all usually doesn't? Like they say on the McLaughlin Hour "WRONG" Sorry to rain on your parade, I even supplied you with the link below. It's a recommendation by the FAA. BTW, I wrote several Aircraft RVSM Operation and Maintenance Manuals that were all FAA approved it's changing all the time. I'll tell you what, let's change it to "IT SHOULD BE " did you read the original quote? Now go crack that RVSM manual in your bird and study up. Look it up: http://www.faa.gov/about/office_org...ice_units/enroute/RVSM/documents/chng7mod.doc
LRvsH25B said:That's an old wives tale/aviation myth. 1000 FPM is reccommened during the last 1000 feet of level off and/or in the vicinity of other aircraft. This is simply to reduce the TA/RA alerts.
And the notice you linked to talks about when climbing or decending near another aircraft...not for ALL climbs or decents.
