Delta acquisition of NWA almost finalized!
So far in 14 months, my number has decreased about 200 numbers. I am not sure if retirements, or else. Quick question for you.
As far as the SLI, I am a junior line holder in a widebody. I should be senior to any F/O at NWA who can not hold a line on a widebody, period.
Why don't you run that idea by all the DAL fo's that are senior to you on narrowbody equipment. Tell them that you fully expect that the new seniority list MUST have them junior to you, because you are a widebody pilot, who fly's internationally.
If past action is an indicator of future results, I think Arbitration Panelists will cancel out the NWA retirements with DAL's pre merger contract, growth, lrager number of retirements and equipment. If there is a correction needed, I think it will come in a form of bid protection, or fence. (not dynamic seniority, but the same effect)
The ratios will be driven by relative seniority based on equipment (stacked in order of pre-JPWA pay).
Too bad the the same arbitrators are not involved or I might by some of your logic. In fact one of the 3 involved ruled on the final arbitration of the NWA Red Book/Green book just recently, and the gist was that (framed in the context of the original Roberts award), that the pre-merger NWA group did not have a continuing right to meter awards based on equipment (Wide Body).
I find it fascinating that many here seem to put more weight on what equipment one is awarded while completely ignoring the demographics of a base/position that allows it to go so far out of normal seniority.
A better litmus test might be what seniority does it take to hold be a ATL 767 intl line holder?
I think it's great that a new hire a DAL can hold a 767 intl' out of JFK, but it's moot, and that somehow that should be protected regardless of the demographics of the pilot group and alignment of bases and aircraft (that is going to change), as if your seniority only matters if it allows for upward movement and not downward.
Thankfully there will be 3 very experienced arbitrators, and I'm confident we will get something much closer to a middle of the road solution than what was seen either at NWA with Roberts, or Nicilou(?).
I also heard that there is nothing to prevent a negotiated SLI to be agreed upon even after the ruling.
Which means that there are approximately 55-60 new hires that will be considered 73Nb FO's. I am glad to be part of that group.
I think that when this is all done. It will not matter what anyone of us wants. It will be fair from the pilots group perspective. If anyone thinks that they are more special than another, they will probably be very disappointed with the SLI. It will look at each group and try to give the equal benefits to each group across the board.
Fins,
The two PWAs were essentially equal. Your's had W2 and ours had QoL and protections. There's nothing to balance.
Nu
Sure ... :rolleyes: that must be the reason many NWA pilots went nuts when they thought they might not be brought up to parity.
Again, I think arbitrators will use that as an EXCUSE to make their job easier, they will use it to cancel something factor they can't easily deal with (like a dynamic seniority model, for example). JMHO - means nothing.
Good points in your post. There has not been much written in arbitration awards about bases and demographics. It appears the tendency is for arbitrators to ignore factors that make it too darn difficult to explain a clear cut rationale.
The ATL767 ER line holders are junior to the domestic line holders. Pilots junior to ACL are holding lines in both domestic and ER flying, but can't do it every month.
It is hard to imagine a scenario where a pilot group makes concessions after an award.
Like ACL wrote, we probably can expect a very logical SLI.
What? I never said that a narrow body pilot who can hold widebody and is senior to me, should be junior to me. What I said was a narrow body F/O at NWA or DAL who CAN NOT HOLD A WIDEBODY at NWA or DAL should be junior to any widebody pilot.
It may be hard for you to understand. Let me try it this way.
You should be able to hold the same equipment the day after the SLI just like you did the day before. Just because DAL has a lot more widebdoies does not mean that NWA pilots should enjoy bigger equipment on top of the much bigger raise you all got.
Your SLI version would first have to put everyone in both companies in the highest paying equipment their seniority can hold, assuming everyone above them is holding the best they can. No offense, but at 14 months I'd say you'd still be an -88 FO.
No offense taken, however, If "joe pilot" can hold a widebody at DAL, and at NWA a pilot can not hold a widebody, explain to me how you think it makes sense for this pilot who has no expectations to fly a widebody NOW, should be senior to a bunch of other pilots flying widebody, by default the NWA would get a windfall, if the day after the SLI he can hold widebody pay, and the day before he did not. If I am missing something, please let me know.
All I am advocating is the day after the SLI we all should be able to hold the same equipment and shedule just like we did the day before. Is that not fair?
And yes, I have contacted my union reps, and it makes perfect sense to them.
Heyas F4H,
Excellent post.
I might add that to those who hold up the Nic as some sort of goal, the two companies are in nowhere NEAR the same position that AAA/AWA were. Both airlines are viable and in the black operationally, with reasonably (for airlines) healthy balance sheets.
I could list the rather long list of items that the NWA guys gave up for the new PWA, basically in exchange for cash, but I would suspect that the arbitrators will see that the two PWAs were basically equivilent.
Nu
June or so 07 newhires are intermitent lineholders on the ATL7ER. ATL767 (domestic) goes a tad senior to that... I'm a feb07 newhire and I'm almost always 5-10 away from junior lineholder (although I did hold a line in august).
Agree. I will be a line holder after the AE. I was a line holder in March and am just a few numbers below him.
Playing Devil's advocate - do you think you should have a higher seniority number than a a NWA pilot hired 7 yrs ahead of you because your seniority holds a WB and his does not? :bomb:
I have no problem with the idea of holding the same equipment the day after SLI (No bump, no flush).
However, I find the bigger problem being who hits the street first when the s##t flows downhill.
Should a 14mo DAL widebody FO be senior to an 8 yr NWA narrowbody FO when it comes to backwards movment?
No, a 7 year 11 month Delta FO should not be be senior to an 8 year NWA FO either.
JPWA gives you longevity back for years on the street. We will see how this plays out.
I think that the boys at the bottom of DAL's list will get what they deserve, as will everyone else.
It will be fair to the unions or the arbitrators. What I think does not matter since it cannot change the outcome.
FWIW. I am a line holder after 18 months on at least one or two aircraft in ATL and NYC, and Lax. I have not looked at CVG and SLC.
What you are getting at is DOH and I will not go down that road. I firmly believe that what DALPA proposed is the most fair and equitable solution to this marriage.
My BS flag rose up the pole when fins said there would be new-hires flying the 88 as Captain....wishful thinking, but it will go junior...but not to newbies....
It really depends on the back fill needed in the NYC 88A position.
I myself only have eight people that have bid it senior to me. That is total.
having an aircraft fence for 5 yrs or so, with a DOH or close ratio mix after the merger is complete is a fair way to go. That way any DAL or NWA pilot wont be bumped from there current aircraft since they already hold it, unless they bid off it to something else, then seniority will allow who ever to take that spot. You cant say that a 10yr NWA DC9 reserve FO, who flies that aircraft for QOL or for the scehdule, should be junior to a 2yr DAL 767 line holder. The aircraft your currently flying does not always refelct your overall seniority. If every pilot for DAL and NWA used seniority to fly the biggest equipment in the highest paying seat all the bottom pilots at DAL would probally be in the MD88 jfk/atl and the NWA pilots in the dc9 dtw/msp
12 ahead of me for 88A, although I'm not bidding it. Bill, I agree that it is unlikely. But I would have thought it unlikely that I'd be a lineholder on the 767 in October out of ATL.
Kinda hard to think of some of us as "newbie's" after all, we aren't that young, or new.
Well the fact is that to you need to understand how the list are rationalized for the SLI.
It is generally done with everyone being put in the most senior position they can hold with out using bases. That means that the new hires that are line holders on all of the "premium widebody flying" are in essence 73NB or M88B. The first 73 or so new hires have enough people below them that they would be considered 737 FO's. The rest are M88 FO's, as most of your new hires are 742 FE's and few may be DC-9 FO's.
Trust me that I if this goes the way that I think it will, the first few classes at DAL (Through May '07) will have more seniority than the rest of the new hires a few months after them. That would be ratio by equipment and using pre JPWA pay rates et al.
OK, but in you scenario, what happens to the 9 year DC9 FO when the DC9 fleet gets drawn down?
The NWA pilots are all worried about when things go the other way, I share their concern. 5 year fence for furloughs?
I still like my "Fair Plan." Most of the NWA pilots did too.
If the DC9 starts to leave within 5yrs or the fence time, they bid what they can hold without displacing a DAL pilot safe under the fence unless they bid off the aircraft, likewise if DAL removes some aircraft.
This is - I like your idea.​
Mental Masturbation at its best. My crystal ball is in the mail, once it comes in I will let you know whats going to happen! :cool:
Serious note: Chief Pilot told me yesterday that from what he is hearing, DCC is within 6 weeks. FWIW
That is probably a good rumor. Maybe. I think it will occur before Nov 23rd either way.
Was it Tim your MSP guy or the DTW one?
