So, no big announcement Seven. Could it be you're just full of crap?
Pinnacle Dispatch : Wednesday, May 11, 2011
A Message From Doug Shockey, Chief Operating Officer
I want to give you an update on the status of our transition and let you know of a specific change to our plans related to the process for combining our turboprop fleets.
We continue to make progress; and along the way, we’re getting regular feedback, not only from the FAA but also from our mainline partners.
As you might know, Delta has adjusted its plans to wind down Saab flying a number of times, and we were hopeful Delta might reconsider. However, it’s become clear Delta will stick with its plans to eliminate Saab flying from operations by the early part of 2012. This impacts 21 of the 28 Saabs currently operated by Mesaba, which ultimately will be returned to Delta under the terms of our lease. With Delta’s decision, it just doesn’t make sense to go through the cost and manpower of moving Colgan’s aircraft to Mesaba when the vast majority of the end-state turboprop fleet is currently operating at Colgan.
We still plan to combine our turboprop fleet under one airline, and that airline will still be called Mesaba. However, rather than move the Colgan aircraft under the Mesaba operating certificate as originally planned, we will keep the Colgan aircraft (32 Saabs and 29 Q400s) under the Colgan operating certificate and add the seven Mesaba Saabs flying for US Airways. The Mesaba certificate will continue to support the Delta Saab operation as that fleet winds down, and then that certificate will be retired. In the end, the Colgan operating certificate will be used to house this combined fleet and will be renamed to Mesaba.
In addition to being easier and less expensive because of fewer aircraft to move, this change will allow for easier FAA approvals. After all, the Colgan FAA office already has approved, and is fully involved with, Colgan’s Saab and Q400 operations. The Mesaba FAA has no familiarity with the Q400. So by moving Mesaba’s Saabs to Colgan’s certificate, there is no learning curve required or additional fleet approvals needed by the Colgan FAA.
Another benefit to this change is flexibility. Because FAA approvals won’t exist to force schedule requirements, we’ll be able to move the turboprop aircraft between Mesaba and Colgan independently from the jets transitioning from Mesaba to Pinnacle. We can manage the rate of turboprop aircraft and personnel movement solely based on operational needs. From a timing perspective, we will wind down the Mesaba operation as Delta winds down its Saab operations (which we expect to be completed in the first quarter of 2012). At that point, we will move the seven US Airways Saabs over to Colgan, retire the Mesaba operating certificate (pending the completion of our jet aircraft fence transition) and assign Mesaba’s name to the Colgan operating certificate.
On the jet side, the Mesaba jets will still transfer to the Pinnacle operating certificate. The steps and timing are always subject to change as we continue getting feedback from the FAA. The main driving factor in the details and timing of our jet aircraft will be the staffing models. We have to make sure we’ve got the right numbers of crews, instructors and oversight personnel to ensure a smooth, safe transition.
It’s important to point out that we still believe there’s a good future for Saab flying. In fact, one of our 2011 goals is to develop a long-term fleet plan for the Saab, and the seven Mesaba Saabs currently flying for US Airways are a good example of this. Today’s high fuel costs reinforce the need for an economical aircraft like the Saab, and we’re working diligently to find other mainline partners that could benefit from our expertise with this aircraft.
Please note this decision does not change any of the end-state management selections that have been made.
I can’t say there won’t be more changes as we progress through this transition, but I can say that I’m extremely excited about our future. Thank you for all you’re doing to make our airline the best in our industry. We’ll continue to keep you posted as plans progress.
Doug
