Latest DAL/NWA arbitration debates
jetflier
Total Time
lot's
As you are aware, the DAL proposal calls for a separate aircraft type for the DC9 FOs.
For me, the highlight of the day was Mr. Katz last questions for a DAL rep. It went something like this;
Katz: Captain ________, you are an MD88 captain. Is that correct?
DAL Rep: That is correct, sir.
Katz: What does it say on your license?
DAL Rep: A310, B767/757, Uh......DC-9.
ACL65PILOT
Total Time
9000+
It really is no big deal it is the way the handle aircraft that are the same type but with big differences.
We do the same thing with the 767-400 and the 767,757,767-300ER.
We also did the same with the 737-200, 737-300 and the 737-800.
DAL feels that going from a DC-9 to a MD-88 or 90 leg to leg would be too much. I agree.
DAL737FO
Total Time
8000+
What's the point. The 737 is a common type rating but the 737-200 paid less than the -300 and a whole lot less than the -800. Same type rating though.
JoeMerchant
ASA pilot
Total Time
14000+
The 75/76 pays the same...but the sizes are much different.....Sounds like the DC9 drivers are getting treated differently.....
FDJ2
Total Time
10000+
So are the MD-88 drivers, the MD-90 pays more, so are the 747-200 drivers, the 747-400 pays more. Some one call a lawyer, I smell a lawsuit.:laugh:
ultrarunner
Total Time
10000
Yeah, the -9's should be a separate bid. NO reason to jump from ship-to-ship. I think airlines have typically separated that type.
When DAL had -9's in the past, had they started top operate the '88's? DAL may have already had both on property. If so, were they separate?
PuffDriver
Total Time
bunche
Yep, you'd better notify your buddies. This has millions written all over it for you. Plus, it may land you on the Delta list. Why not try?
ACL65PILOT
Total Time
9000+
I think that even the FAA would have issues with you going from a non-FMC platform to a FMC platform, leg by leg. There is a lot of issues with that.
tomgoodman
Total Time
20,000
-9/-88 transition
Same type rating, but they were always separate categories, and only instructors maintained currency in both. When we first got the -88, it wasn't really "glass". FMS wasn't ready for installation yet, so the CRT screens only worked in arc and rose modes. After installation, only LNAV was authorized, and after a while, VNAV was given the OK.
General Lee
Total Time
A lot
The cockpits are pretty different, even to someone who has never flown either. I guess the 742 and the 744 are the same too, right? Was this really a highlight? Maybe for you guys. I thought our guy RH did a great job comparing the the 767ER to the A330. Essentially he looked at old records, found out Airbus based the A330 off of the 767-300ER, and looked a Delta specs to see what missions our 76ERs do vs how NWA used the A330, and even looked at how many ultra long haul crewed flights we had vs NWA. A lot of your A330 flights have two man crews, whereas most of our 76ER flights have 3 man crews, and some have 4 man crews (none of yours do). Shouldn't than mean something? Maybe you aren't using your A330s to their max ability? Then, he looked at our pay scales on each pre-DCC. Wow, I think they are identical...... hopefully the arbitrators do too...the A333 is a bit bigger, but it looks like the missions are the same....(thanks to you guys not using it the way it could be used, more often)
Delta's B-767 ER and Northwest A-330 are
11 identical aircraft based on real world data."
Again, the first article,
6 rather than go through the whole thing on page
7 two of the article, it is exhibit page three.
8 It just talks about how when Airbus was
9 designing the A-330-200 model, that it was
10 targeted at the Boeing 767 ER whose range
11 capability was greater than any previous
12 Airbus twin-engine aircraft.
So that when Airbus was designing
14 the airplane, they were designing it to
15 compete with the 767 ER.
A. Right. The bottom line is that the
9 767 average rate is $171.70. For the A-330
10 it's 163.50. And again both within the same
11 neighborhood of each other
So we asked Delta management as
9 they were coming up with the combined schedule
10 that was going to come into effect, I think
11 the first load is in January, what performance
12 data did they use to try to figure out which
13 airplane can accomplish which route.
14 So they gave us a list that is
15 displayed on page 11. And what they gave us
16 was the actual seat count of the aircraft and
17 the range that's based on a full passenger
18 load with appropriate payload corrections
19 based on the mission.
20 Q.
the maximum seat count multiplied by the
3 maximum range to come up with a maximum
4 available seat mile for the airplane.
5 Again, the chart raw data is shown
6 there as it came from Delta management
And obviously we've highlighted
3 there the four legs that Delta does that are
4 double augmented flights. And the A-330 does
5 not do any double augmented flying.
6 As you go down the list for
7 Northwest, you see at the very bottom they do
8 fly the A-330 as part of the Norita hub on
9 shorter range legs that have two pilot crews.
10 When we get to the bottom of the
11 page for the 767 ER, we are still looking at
12 9.9 or 10 hour legs that require three crew
13 numbers.
Bye Bye---General Lee
clippyrip
Total Time
They are the same bird.
You can add a spoiler and fancy hub caps to your Dodge Neon but its still a Dodge Neon. Go ahead and get the 4 door, its still a Dodge Neon.
Total Time
7,500+
Anyone else find it interesting that under cross examination NWA's side admits that DOH "disadvantages" the Delta pilots and that a ratio is a much more fair integration methodology to start with.
So as a fall back position NWA's witness testifies if the arbitrators must award a ratio list, then they should make it dynamic, to protect NWA's earlier retirement driven career progression.
But then they admit, Dynamic has problems:
First, they start with an assumption that it would take a Delta MD88 FO ten years of growth and attrition to bid up to the 737, or 757. During the same time without a merger the NWA new hire would hold a 787 B slot, or a 767ER B slot under Delta's plan. Then the witness testifies that adoption of a dynamic list raises the career earnings of a NWA 2008 hire by 4%, while reducing the career earnings of a Delta new hire 5%, comapred to the static proposal.
But with a static ratio, the difference is 1%.
18 You can see the consequence of the
19 static list on the left and the dynamic list
20 on the right for using job value units. The
21 Northwest pilots in the static will see a five
22 percent reduction in their group earnings.
23 The Delta pilots see a four percent
24 in the static than in the dynamic list.
25 The Northwest pilots lose a far
2 smaller amount of group career earnings than
3 the Delta pilots.
Now what was the percentage of NWA raises compared to the Delta raises in the JPWA? It was a whole lot more than 1%.
ALPA's merger goals:
a. Preserve jobs.
b. Avoid windfalls to either group at the expense of the other.
c. Maintain or improve pre-merger pay and standard of living.
d. Maintain or improve pre-merger pilot status.
e. Minimize detrimental changes to career expectations.”
Using just and only NWA's testimony, Delta's ratio achieves ALPA's definition better than either of their plans.
I truly do not understand NWA pilots' cries of arrogance and unfairness with regard to the Delta proposal. Once you get past the hazy images of 747's flying over Mt. Osaka and start dealing with objective numbers the visibility clears right up.
Oh, and the Green book pilots just remained on the smaller equipment for quality of life.:rolleyes:
nwaredtail
Total Time
9000+
Shush, don't tell anybody. The dumb arbitrators and NWA merger committee might find this out and figure DAL is trying to pull one over on them to the advantage of their own pilots.
nwaredtail
Total Time
9000+
Funny, I can't find where they said any of that. Disadvantages from a day 1 snapshot maybe, but 5 to 10 years down the road, most DAL pilots make out better under the combined DOH model at the new DAL than they would have of DAL stood alone.
Under your POS model all DAL pilots benefit on the backs of NWA pilots. That won't fly.
I guess your model has no disadvantages for NWA pilots, like:
1. losing 5-10% seniority from day one.
2. Losing 10-20 over the next 5-10 years
3. Losing up to 50% over 15 years
but those numbers the NWA guys should just ignore?
You, GL and others just cherry pick your arguments but with no substance behind it. Your arguments make y'all the USAIR of this SLI arbitration.
Total Time
7,500+
And another nail in Dynamic's Coffin:
Q. No other airline has a dynamic
9 seniority list advice, do they?
10 A. Not that I'm aware of.
Total Time
7,500+
Facts:
1. NWA brings smaller aircraft to the table, relative seniority by equipment is our status quo without the merger.
2. According to your witness Delta loses 4% under NWA's plan
3. According to your witness NWA loses 1% under DAL's plan.
According to your witness you lose ~1% of pay with Delta's plan. Delta loses ~5%. Which plan meets ALPA's own goals. This is without consideration for the raises obtained by NWA pilots, bringing NWA to parity in the JPWA.
I will refer you to the testimony of Captain Averill on the 15th of November. I'm not picking our best arguments, or even arguments being made by the Delta side. I'm just evaluating your representatives arguments. I'd love to see their charts, maybe NWA will leak them.
I know my side and am not asking for anything more than status quo.
Total Time
7,500+
If I just wanted to pick quotes for headline value I'd post stuff like this, while discussing NWA's proposed list:
7 Q. A third of the Delta pilots are
8 stapled on the bottom of the Northwest list;
9 is that correct?
10 A. On the bottom of the Northwest
11 list?
12 Q. Yes, on the bottom of the list, on
13 the bottom of the list. I misspoke. On the
14 bottom of the list.
15 A. Well, there are 3,000 pilots below
16 them.
21 A. The point is that the attrition
22 that we have enjoyed is a function of the
23 ratios that were built at the bottom, based on
24 the jobs that were brought to merger.
25 Q. Does it put a third of the Delta
2 pilots stapled below at the bottom of the
3 list?
4 A. At this point in time, it does.
3,000 Delta pilots stapled? Stapling half the list? Rant Rant & Whine.
The reason why we don't focus on NWA's proposals to staple half of Delta is because it so nuts that it is not worth even debating.
Superpilot92
LONGCALL KING
Total Time
Dunno?
This is like a broken record, blah blah blah blah, etc
Total Time
7,500+
Really? Broken record?
I thought changing integration methodologies during rebuttal was news. It sure was to me.
I'm comforted a little by the fact however NWA puts together a list, it is not as bad for any of us than we think because it includes pilots who don't work at NWA, who are retires and those who have been out on disability with no intention of returning. Each one of those "gone but still on the list" pilots is a number. If NWA announced two dozen new 747-400 Captain slots, you would think it was news, well, this has the same effect.
The part I do not understand and maybe you can explain is, why do the NWA pilots demand so much more than status quo?
nwaredtail
Total Time
9000+
Facts:
really? I always thought the A330-300 and 747's had more seats in them than the 777. Again, I am sorry for my error. You better call DAL and tell them.
Maybe at day one, then everyone moves up more on a % basis at the combined company. This is called a win-win vs. DAL screws NWA
Gee, then maybe the 6% I lose day one, 22% at year 10 and 60% at year 17 are just my imagination.. Tell me how I was going to retire in the top .05% at NWA or DOH, but the highest I get is 17% under DAL screw job. Where does the math get 1%.
Fact is you are either lying or full of crap. You choose.
Then you won't mind a dynamic list, because you wouldn't of had NWA retirements anyway, right?
