Gary Kelly Ain't Waitin' for the DOJ!!
  • Thread starter Thread starter Lonestar
  • Watchers Watchers 58
That there is the rub. Check out the mins required for both. I'd bet there are quite a few AAI FOs the don't meet the mins to even apply to SWA, but they expect relative senority?
I believe 1000 TURBINE PIC to apply at SWA vs 500 PIC at AAI. And a type rating to start class.
I guess this is a non issue.
You're wrong about the 1000 Turbine PIC and you're probably right about the 737 type.
AirTran payed for mine :)
You see Dicko, that's the problem. You really don't know the facts and spew what you believe, not believing the truth.
Look it up yourself at http://www.southwest.com/html/about-southwest/careers/positions/pilots.html
I'll post the highlights to help you out.
Flight Experience: 2,500 hours total or 1,500 hours TURBINE total. Additionally, a minimum of 1,000 hours in Turbine aircraft as the Pilot in command3 (as defined below) is required. Southwest considers only Pilot time in fixed-wing aircraft. This specifically excludes simulator, helicopter, WSO, RIO, FE, NAV, EWO, etc. NO other time is counted
As a side, Dicko, I know you're a CAPT now, but curious if you met the mins at SWA when you were hired at AAI? Not that it matters much, just curious.
There is a reason SWA group is older. It takes longer to get hired there and it is more competitive. I am sure pilots have interviewed multiple times at Airtran to get hired, it just is not as common. This is not a statement for SLI discussion, just an observation.
And the mins at vorgin america are 1,000 TPIC and 5,000 total which is more than at southwest. Should they get higher relative seniority in case of a merger?
I'll be happy to answer your question. I think I probably added to some confusion. My fault.
I was talking about AirTran FO's having 1000 121 TPIC. The vast majority did when they were hired (since 2002).
You are absolutely correct about the required minimums for both airlines.
Yes, I had over 1000 121 TPIC when I was hired and met all of the SWA mins. No 737 type obviously.
I was told by both AirTran pilot HR and friends who were writing me letters of rec. that 1000TPIC was the minimum to get your foot in the door. The published mins were the same then as they are now. I'm sure you know that minimum means minimum. Not competitive.
We are about the same seniority. The results will be interesting. I say this with no acrimony
Cheers
If Airtran bought VA would you give them relative? The AAI folks in here have said multiple times that VA doesn't count. Right back at ya!
Sent from my ADR6300 using Tapatalk
Be careful about the "hiring minimums" argument. Most of the pilots hired by AirTran had experience that vastly exceeded the minimums.
You might find that, while SWA's "minimums" were higher, that the average AirTran hire actually had more flight time, especially if SWA hired more fighter types and corporate guys, while AirTran hired a bunch of Delta retirees and legacy furloughees.
VAs still a start up and no where nears being profitable. If they were a profitable entity with desired assets and gk felt they needed them to grow when he felt he couldn't otherwise, then yes, all wn CAs 93 and senior go first then relative to the bottom. Absolutely. The more this system gains traction, the easier the arbitrators job will be. After the SLI remember, Happiness is a personal choice.
Wow-great point. Let's hope for their sake the arbit won't ask for deets on actual hiring times/backgrounds. It's the law of unintended consequences.
I can't comment on hypotheticals, just history. We were going to offer Midwest relative seniority. Looking at Southwest's history, you were going to offer F9 a staple.
I have never advocated a staple and with F9 that was only an opener that never got negotiated. Their's was pretty unreasonable too. My point with the GA comment was to point out to JJ that if we can't ask you guys about VA hypothetical match up with AAI why does he think he can use it with us? Just asking.
Dicko-
Ditto- Interesting times! Trying to stay optimistic, but when some of these guys spout off, especially the ones with no stake in the outcome, it gets a bit frustrating. I simply like my job. And want that to continue.
Unfortunately 'fair' is a relative term.
No pun intended.
Cheers-
BD32
You won't get an answer on that. That doesn't fit into the AAI realitive seniority mantra.
Same for the question about how a $7,000.00 a month increase in pay won't be taken into consideration from the arbitor.
You want to deal in reality or hypotheticals? If AirTran merged with the 1985 Chicago Bears, would Coach Ditka get the number one spot? What about The Fridge or Sweetness?, they definitely should have better seniority over an AirTran pilot.
You guys are fricking ridiculous, if AirTran were to merge with VA, THEN IT WOULD GO TO ARBITRATION, JUST LIKE WITH SWA. That is the reality, I suggest you start living in it.
