HelloNewman
- May 7, 2004
If you look at the DOT stats Delta, Airtran and ASA share the bottom of the list - wonder what they have in common? Maybe closing down a runway for construction at the world's busiest airport that peaks in excess 115 arrivals per hour has something to do with delays.
Are you D'Angelo?
I know a few people who work over at Mesa. They tell me a lot of times they will cancel flights due to "weather" or "flow". The pilots will call ATC and they are told weather or flow is not a problem on that particular route. Look I am not saying there is no such thing as weather delays or ATC delays. I am saying that they make an easy scapegoat however. I am not this D'Angelo you speak of. I am simply stating an opinion. I don't know for 100% sure however I am definately suspicious. It is just to easy to hide problems under Weather/ATC at ALL airlines.
