Will we ever see another a/c like the MD-80 again?
You'll like the dc-9, like others have stated its a beast and was built like a tank. I will be going back to it also. I actually am kind of looking forward to it, especially now that i am pay protected on the Bus :beer: Its ALOT more work than the bus so be ready for that but it truly flys great.
Are you sure about the pay-protection? There are pilots junior to you flying ANCSO747. That pays about what the Airbus pays. I think you'll be pay-protected for less than a $1/hour.
No i am saying we will be pay protected on the Airbus because thats the plane we currently are on. The point is we wont be getting DC-9 payrates and are pay protected since we got displaced. It has nothing to do with the people junior to us or the 742's.
Hi!
The Bombardier "C". It is designed to seat 100-150.
It has the new Geared Turbofan engines from Pratt and Whitney. They are supposed to burn at least 20% less fuel, with at least 20% less emissions, and over, I belive 20% less noise (might be 40% less?).
NWA was planning on buying it to replace their DC-9s.
cliff
GRB
The biggest problem with the MD is that it was certified in the '60s as a DC-9. There is no redundancy for horizontal stabilizer control (1 jackscrew).
It would never get certification using today's standards.
2?
It has been 6 years, so correct me if I have forgotten. But there is a primary trim and secondary trim. I know there is two motors. I thought there was two jack screws.
It's been six years for me too(still furloughed) but I think there were several ways to trim but only one jackscrew. At my old airline in STL we had a previous AK 80 that happened to be the only one they found with a ungreased screw to comply with the emergency AD after the accident. Lesson is grease the screw.;)
Two motors, one jackscrew. No redundancy.
Cal looked after the jackscrews. The story goes there were TI mechs that thought they needed extra effort and their additional attention became common practice at the Hobby MX hangar.
Bigger problem with being based on a DC-9 type certificate is the pay rates are already established. If that weren't the case I think the 717 would be more prevalent than EMBs.
as opposed to screw the grease
But draggin piece of FOD. Took me two hands and full attention to drive it on autopilot, weird to land...just did not like it. 73 much more user friendly.
Heyas,
DC-9-30 with the -15 engines
Best. Airplane. Ever.
Nu
Hear.. Hear.. (or is it Here.. Here.. not sure).....
Sadly, they're all but non-existant on the line nowadays as the -9's have been deemed "most efficient" by dum-dom and sissy-scott... Alas...
Never flew it, but hated riding in them. Nothing like having brake chatter that would loosen your fillings - though I've noticed it doesn't seem as common any more. Did they engineer yet another solution for a Douglas aircraft in the field?
[DC-10: Built in Long Beach, Engineered in the field. The WHAT failed?! Dang, we never though of that! Crap, we'd better fix it!]
15's on a 15F
Now that would be the bird
IIRC 1 jack screw but 2 trim motors. The accident was a result of improper lubrication. Besides that the DC-9 have been flying for 40 years. Bad design...I don't think so Tim.
Sure, but that doesn't change the fact that its a single point operating system for a critical flight control. Plus the lubrication intervals vary wildly between operators, with the FAA's blessing.
You just described many airplanes, from small to large.
Is that sort of like having three hydraulic sources to only one rudder pcu?
What about a dual magneto with one cam driving 2 sets of points? Guess what, that one cam has only one little screw holding it in place. If it comes loose, your a glider pilot in the single engine applications.
High wing Cessna has one bolt holding the wing strut on, if the bolt breaks, you will be auto rotating.
How many Cessna's have had a wing failure due to bolt failure?
I don't think was ever a DC-9-10F, the DC-9-10 combi version was called the DC-9-15F. The difference was the 10 had one over wing exit per side, the 15 had two over wing exits per side. BTW the 10 was was a real hot rod
You may have me on a technical point. What ever ABX had 22 years ago is what I flew. And you're right, it was a hot rod!
forget the MD-80,bring back the 727 !!!!!!!!!!!!!!!
