Will we ever see another a/c like the MD-80 again?
But draggin piece of FOD. Took me two hands and full attention to drive it on autopilot, weird to land...just did not like it. 73 much more user friendly.
Heyas,
DC-9-30 with the -15 engines
Best. Airplane. Ever.
Nu
Hear.. Hear.. (or is it Here.. Here.. not sure).....
Sadly, they're all but non-existant on the line nowadays as the -9's have been deemed "most efficient" by dum-dom and sissy-scott... Alas...
Never flew it, but hated riding in them. Nothing like having brake chatter that would loosen your fillings - though I've noticed it doesn't seem as common any more. Did they engineer yet another solution for a Douglas aircraft in the field?
[DC-10: Built in Long Beach, Engineered in the field. The WHAT failed?! Dang, we never though of that! Crap, we'd better fix it!]
15's on a 15F
Now that would be the bird
It has been 6 years, so correct me if I have forgotten. But there is a primary trim and secondary trim. I know there is two motors. I thought there was two jack screws.
IIRC 1 jack screw but 2 trim motors. The accident was a result of improper lubrication. Besides that the DC-9 have been flying for 40 years. Bad design...I don't think so Tim.
Sure, but that doesn't change the fact that its a single point operating system for a critical flight control. Plus the lubrication intervals vary wildly between operators, with the FAA's blessing.
You just described many airplanes, from small to large.
Is that sort of like having three hydraulic sources to only one rudder pcu?
What about a dual magneto with one cam driving 2 sets of points? Guess what, that one cam has only one little screw holding it in place. If it comes loose, your a glider pilot in the single engine applications.
High wing Cessna has one bolt holding the wing strut on, if the bolt breaks, you will be auto rotating.
How many Cessna's have had a wing failure due to bolt failure?
I don't think was ever a DC-9-10F, the DC-9-10 combi version was called the DC-9-15F. The difference was the 10 had one over wing exit per side, the 15 had two over wing exits per side. BTW the 10 was was a real hot rod
You may have me on a technical point. What ever ABX had 22 years ago is what I flew. And you're right, it was a hot rod!
forget the MD-80,bring back the 727 !!!!!!!!!!!!!!!
