jynxyjericho
- Feb 2, 2011
You can hand fly it in SNA, and the noise monitors there are pretty much straight out towards Newport Beach. In Europe the monitors are more numerous usually, and occur down below in turns too. Throw in other distractions like very heavy weight takeoffs due to all of the gas onboard to fly all the way to the US nonstop and lower transition altitudes (29.92 by 4000ft etc), and it's a bit busier than SNA. Your SWA procedure of slamming the nose down after a pronounced power reduction is a bit more than the 757, though. All that is done on the 757 is keeping the pitch up and hitting CLB thrust at 1500 ft, and then flap clean up
3000ft.
Bye Bye---General Lee
No, I called it the "idiot stick," not the "dumb stick." And although I didn't personally give it that name, I think I heard that it was named after you, General. :0
Since I realize that you don't have a lot of experience in actually flying an airplane, I'll explain it to you. It's called that, because generally when you have to use it, it's because you messed up, either in your planning or execution (although I suppose if you also use it when you don't have to, the name might apply as well). Obviously there are times when ATC changes the game, and you may have to get down and/or slow down differently than you planned, but using it the other times is what gives it its name. You're wasting energy (gas) and buffeting the plane when you don't have to.
Would it amaze you, General, if I told you that I often fly multiple pairings over many weeks without ever using the speedbrake in the air? And surprise!--I still manage to stay on my designated vertical path. You know why? It's because I actually understand aerodynamics, my airplane's specific characteristics and operation, and the relationship between VNAV operation and energy management. If you actually put down your ice cream sundae and picked up a book every now and then, General, you might actually learn a thing or two about your airplane as well! You know, instead of just randomly pulling levers like a monkey, when commanded by your overlord Flight Management Computer. Just a thought....
Bubba
For a Skywest dispatcher you sure do play pilot a lot.
Tell me more about ice cream and, how did you put it, FOOKWHA?
This from a guy who will be a "Surge 9" FO for the rest of his career, or until his company vanishes. Good luck!
Lol. Havent been a surge 9 FO in a while sweetheart. Anyway, I've already made it out so do you need a recommendation so you can get dispatching somewhere branded? Or you gonna stick it out in Utah? Can't blame ya it is a pretty state, maybe you could get some flying lessons in, come work on the other side of the acars screen. Good luck with all of it, but I wish you the worst at professional trolling.
Ahahahaha! You made it out? To where? Lav dumper? Never mind, you're still a loser.
Such a troll. You gonna make it out of Skywest SOC or are you staying in for the long haul?
