The interesting item, which we discussed but I'll resurface the conversation, with the IBBS battery is in normal operation it is "armed" and not supplying power. Like in our FX-3 with IBBS we turn the switch ON and it only supplies power when the main bus is not supplying power. This is why when I eventually found the sense wire disconnected from the IBBS breaker (which handles charging the IBBS) I saw a "IBBS in use" CAS alert in my G3X/GDU.
- The IBBS transitions from aircraft bus power to its internal battery when the bus voltage falls to approximately 10.5–11.5 V. That is the point the unit starts supplying backup power from the internal battery pack.
- During backup operation, the output voltage will typically sit between about 10 V and 14 V.
- In the battery performance table (manual), duration figures are given for load down to 10.0 V — implying that useful output down to ~10 V is anticipated under load.
