Let's say you had a giant treadmill with an airplane on it
belchfire, don't bother. I already posted what is the 'correct' answer to this whole thing.
It's the ask the pilot column on salon.com , just backtrack and find the link I posted.
Yeah...sorry...I didn't get that far before I responded. The whole setup is kind of goofy but airplanes are designed to overcome rolling friction and aerodynamic drag in order to take off. Once movement starts -let me be very clear about this - once airspeed is indicated rolling friction rapidly becomes the lesser of the forces resisting acceleration as aerodynamic drag is increasing as the square of airspeed far beyond the point where rolling drag tops out.
Right out of brake release a typical heavy jet is accelerating pretty slowly but by the time rotation speed is reached the may be accelerating at a rate of 3 knots per second.
The presumption by the naysayers is that rolling friction can keep the aircraft from moving. The fact is that as liftoff airspeed is approached rolling friction is a small fraction of the forces acting on the aircraft. In order to reach takeoff speeds you have to be able to overcome the resistance of the wheels.
Oh, it's on the Internet. Must be right then.
You guys should get some little balsa rubber band propelled airplanes and try these experiments at a major airport near you with those human conveyor belts. Maybe they could crank up the speed to about 30 MPH for you. Martha and Elmer trying to get to CID for $69 round-trip might go flying off the end of the thing and slam into the floor but you could at least possibly prove your point.
Just a suggestion. Good luck.
I thought I would dust off this old gem to kill the PIC thread.
Let's say you had a giant treadmill with an airplane on it.
As you add power and begin to move for the takoff roll, the treadmill speeds up and keeps the plane in the same relative position. As the plane goes faster, the treadmill speeds up, always maintaining the aircraft's relative position.
Would you ever be able to take off?
GO!!
I'm sucked in because I starting to have a hard time telling who believes what. . .
Just because someone asks a question, it doesn't mean the question itself is valid. The question has two mutually exclusive states.
If you begin to move and the plane goes faster, you could takeoff.
However, if you are in the
same relative position and maintaining the aircraft's relative position, you will not fly.
I'm imagining the ERAU campus is abuzz with this question. No shortage of guys sitting around their computers with bras on their heads, theorizing the possible outcome.
COOPERVANE...you're a bad, bad man. Look what you started.
another way to look at is an airboat in a river. The thrust of the airboat is from an airplane propeller.
Aim the airboat up river and give her all she's got. If the river keeps accelerating downstream as you speed up going upstream. Will you move?
If the top end of the airboat is 100kts, and the river is flowing at 100 kts the other way, will you have moved past the dock you just left on the shoreline?
Not the same situation. The river is producing immense drag upon the fuselage of the boat. In the case of the airplane, the only drag that the propeller has to overcome is the drag from the wheel bearings. This drag is virtually nothing, and increasing the speed of the treadmill won't really affect it. Once the airplane's propeller overcomes the drag from the bearings (almost immediately), then the airplane will begin to accelerate without regard for the speed of the treadmill.
In this case, it is right. That column, "Ask the Pilot" on Salon.com is by Patrick Smith, a regional Captain turned legacy furloughed F/O.
He brings lots of experience in his columns. They are all excellent, and he thoroughly does his research if he's presenting a question (as in this case).
You're right, everyone needs to be careful when finding answers on the internet.
But in this case, that column and that pilot are a good, credible source.
Then the only thing that sets him apart from everyone else offering an opinion here is that he's getting paid and we're wasting time.
This is turning into the greatest thread of all time.
Keep it up!!
You guys are torturing me here....Can't even drink my beer correctly reading this stuff....
Damn!!... where's my Ipod? Where did I put my Ipod?...
If the airplane will fly, Midway airport wants to talk to you!
Get rid of that short-a$$ set of 30's era runways, and install a pair of threadmills!
Pos-and-hold...run 'em up...and launch!
It'd work, right?
Why on earth are we discussing this one again??? And FS, I thought you were smarter than this ;)
You guys are thinking as if the engine produces forward motion via the wheels. The wheels are only there to make it easier for the engine and propeller to pull the airplane on the ground, guys... Well, and for somewhat smoother landings, I guess...
Look at it this way (using a small SE prop for ease of understanding):
You are standing in front of the airplane, holding it by the propeller blades. YES, the engine is off!!! Wheels are on a threadmill, brakes released. And yes, YOU are standing on solid ground.
The threadmill starts up, slowly at first, then faster and faster. Initially, you'll feel a tug, as the wheels start spinning, but you'll find that it's actually not that hard keeping the airplane still as the wheels go faster and faster. Yes, I know, eventually you'll get to the point that you can't hold it any longer, but that is at a much higher wheelspeed than you apparently think.
Now realize how much more pulling power that engine and propeller has. It'll easily overcome the small amount of friction the threadmill is exerting on the wheels. Thus, the airplane will move forward on the threadmill, and it will become airborne at normal indicated airspeed. TIRE speed will be way higher than normal, but assuming the tires will withstand those speeds, the airplane will be airborne LONG before the friction from the threadmill is at the point of countering thrust.
Yes, I am an idiot, but I believe I stated that earlier.
I think it is these long azz days. 11+hrs yesterday!
I got up this morning at 430am and was shaving, thinking about this stooooooopid question. All of a sudden I felt very dumb. I got it, I totally got it.
Like I said I am an idiot.:)
yall gotta me kinda confused wid all this pilot mumbo jumbo.. but i got me a airboat back at the trayler with big block 350 chevy on da back. yall saying if i go fast enuff i could go up in the air? See i dont reckon i could do thiis cause when i put the throttle up so far past about where my nee is about.. the tork of my engine would make me go sidways and id be gettin all wet with the alligators. now if i put a hifallootin jet engine on dere i reckon i might not have that tork and id be goin reel reel fast. maybe then i could be kinda like yall pilot folk. ill run down to walmart tomorra and pick me up one of them treadmills and ill try it out.. see if i cant geterdun.. suzys always tellin me i shoudl have been a airline pilot cause they make the big bucks, but i was never one of them smart kinds
GO!!
Mr. Vane, you are my new Evil-Genius hero. "Scott Hall" is far more prolific, but this was just pure, unadultarated divine inspiration.
Bravo, Thank You, and may God have mercy on your soul!
It'd work, right?
No, because the runway length required for takeoff doesn't change. You'd need to have a treadmill that is just as long as the current runways.
That analogy is incorrect. If you are in an airplane that lifts off at 100kts, and you point that airplane into a 100kt headwind then it will take off with a zero length ground roll.
Boats don't rise up off the water, unless they are flying boats.
The acceleration of our airplane with respect to the surface of the earth on the threadmill is given by:
A = F/M
where A is the acceleration in length/time squared, M is the mass of the airplane, and F is the net horizontal force on the airplane. The net horizontal force on the airplane is the thrust from the engines minus aerodynamic drag and rolling resistance.
To hold the airplane still with full thrust from the motors, some equal and opposite force must oppose the thrust of the motors.
Come on now, everyone knows you just have BELIEVE you can fly! As long as you believe hard enough, you'll sore like an eagle!
-Blucher
Since when did wheel speed equate to lift generated? The plane will not fly with no relative wind!
What force is acting to oppose the airplane's engine thrust and thereby hold the airplane stationary with respect to the earth?
The treadmill moves at ANY speed nessecary to maintain the aircraft's relative position. If the speed required is equilivent to 300 knots to maintain the friction required to hold the aircraft's position, the the treadmill can do it.
I can't believe this aspect of this brain teaser hasn't been brought up yet.
What if the pilot of the plane on the giant treadmill is a Jetblue pilot, and he is in the back cleaning the cabin. Can he walk forward (counter to the treadmill speed) to the cockpit to push the throttles up so the engines can generate enough thrust to counter the wheel friction and take off?
Hee, Hee, Hee!
Hee, Hee, Hee!
No, but the cabin will certainly be a lot cleaner before it takes off!
That's pretty scary how many different answers there are posted to this question.
I think most have caught on to the satirical nature, but frighteningly some seem to be serious, though incorrect.
An FI classic!
