Let's say you had a giant treadmill with an airplane on it
How about this one. You take off in a tail wind, as you increase forward speed the tail wind also increases to match your forward speed, Aircraft 10 KIAS, Tail wind 10 Knots, seconds later aircraft 20 KIAS, Tail wind 20 Knots, several more seconds later Aircraft 100 knots, Tail wind 100 knots. Would the aircraft take off?
I think you might have written the question wrong. KIAS is indicated airspeed, and if you have indicated airspeed you have relative wind flowing into the pitot tube and therefore across the wings. With indicated airspeed you generate lift, with enough of that stuff you will fly.
Should have been ground speed not KIAS, you posted it before I could finish the edit.
The difinitive answer is NO, no takeoff!!!!
Here's why...
The question clearly stated that the relative position is maintained constant. This is the key thing!!! The people who think that it'll take off and are using the rationale that the airplane will move forward based on the fact that the airplane will be propelled despite the treadmill. That's what would happen in reality, but it's not what was specified in the question.
The question specifically stated that the airplane MAINTAINED ITS RELATIVE POSITION!!!
This scenario is best simulated by a float plane trying to take off against a raging current. If the float plane was doing 50 knots of speed through the water but the current was also 50 knots then the float plane would have zero knots of relative motion, therefore the wings of the stationary airplane would not be moving too, thereby producing zero lift.
To all you guys saying people like FEDEX were stupid, you're the dumb ones, there's no way that the airplane would get airborne, NO WAY AT ALL, given that the question specifically said that there was no relative motion.
Dopey mofo's
I'm sucked in because I starting to have a hard time telling who believes what. . .
Just because someone asks a question, it doesn't mean the question itself is valid. The question has two mutually exclusive states.
If you begin to move and the plane goes faster, you could takeoff.
However, if you are in the
same relative position and maintaining the aircraft's relative position, you will not fly.
Bingo!!!!!!!!!
I'm glad someone else understands what the F**K's going on here...
The question is flawed. As stated, it wouldn't fly, but if the plane started moving, it would.
Anyone who thinks that if the plane stayed in the same position on the treadmill and would still lift off is a complete dumbass and slipped through the cracks to get his pilot's license and/or college degree!!!!! (and there are alot who believe that based on the posts on here)
Its amazing how much idots out here think it would fly... down right scary.
Please turn in your CPL/ATP
No relative wind = no lift !!!!!!
Pretty soon this concept is going to click in your mind and you're going to realize just how much of an a$$ you made out of yourself. The plane will fly. It's just basic physics.
Are you for real ?
Woosh!
1) You need to get laid
2) The original question assumes the aircraft does not move, It states "As you add power and begin to move for the takoff roll, the treadmill speeds up and keeps the plane in the same relative position. As the plane goes faster, the treadmill speeds up, always maintaining the aircraft's relative position.
dutchman, they are saying that it would fly because the plane would drag its ass down the treadmill just like it was a runway. Yes, it would... we accept that, and yes if that was the case it would fly.
The assclown who posted this question played us for fools, the question stated a given which was clearly not physically possible.
I know how to solve this whole F**King problem... buy a helicopter!
1) Yes, yes I do. I didn't make the graphic though.
2) Yes yes, I know. I post on about 2039840234 webboards and I've seen this thread on all of them. I'm just messing around.
3) just giving u crap :)
The question is whether or not the belt can provide enough backwards force though friction to equal the force applied by the engines. The answer is: YES. You can see this by placing a rollerblade on a treadmill. As you increase the speed of the treadmill, the force applied by your hand to keep the rollerblade stationary increases. The belt could potentially spin the wheels fast enough in the opposite direction to hold the plane stationary. If you neglect friction in the wheel bearings, the plane takes off.
As far as I can tell, THIS was the only guy dopey enough to suggest that the plane would stay in the same position AND take off!
Congratulations mate!!!
By the way, it's clear that we were played for a fool.
The correct answer is that there's no answer, the question's f**ked.
Time for bed
The question is well and truely fracked!
"as the plane goes faster"???
Wait!
If the plane "goes faster" how can it be "maintaining the aircraft's relative position"???
They are mutually exclusive! The plane cannot go faster and stay in the same relative position!
Now, would you naysayers like to take a shot at telling the rest of us what the question really meant to say?
Read the question again. The treadmill plays a crucial roll in the
plane's acquistion of speed as long as the plane is not airborne. If
it is still on the ground and the wheels are rolling forward at a rate
to move the plane at, say 150 mph, the conveyor belt is pulling it
backwards at the same 150 mph. So relative to the stationary earth,
the plane is going exactly nowhere. This is like going up the steps
of the down escalator at the same rate of speed the steps are going
down - you get nowhere. And if you are going nowhere and the wind is
not blowing, you will not generate any lift at all and therefore will
not be able to take off.
If wheels do not have any friction, you will slide on them, not roll.
This is like a car that slides on the ice. However, the clear
intention of the questioner is that the wheels have enough friction to
prevent sliding on the conveyor belt. Therefore the plane is not
decoupled from the belt's motion. And in the scenario described, will
I read the question again.
It still says "As the plane goes faster" ...
It does not state "as wheel speed increases"
It states "as the plane goes faster"
I say again the question is fracked!
Get it?
But thanks for taking your time to explain what the question really meant. Given that your side has blasted the it will fly side for trying to reinterpret what the question really meant...I maintain my relative position.
The question is fracked!
your right :)
screw it, time for bed!
Someone just rig up a big treadmill and use a RC airplane and see if it works or not. You don't have to see it take off, just if it moves forward at all.
...and this thread will never end.
This is almost funny as letting my dog spend the day getting the last drop of peanut butter out of an empty jar.....some of you here are as clueless as my dog, but I'm glad you find this entertaining
I think this will go on longer than the "Pinnacle Buys Colgan" thread!
OHHHHWELLL,
Sounds like another $hitty MESA cost cutting program, heeeerrreee it comes, MESA still SUKS!
PBR
