Let's say you had a giant treadmill with an airplane on it
Is it possible to get the MythBusters to do a full scale model of this with a Cessna or something. Maybe they could go back to the boneyard and buy another one of AMF's Lances. I for one would love to see Kari build the rig all by herself just because more Kari=more gooder. Make it a 2 hour special so there is enough time to talk to all of the TV "aviation experts" like Dr. Bob Arnot, and (insert retired airline pilot's name here)........
The reason I like this riddle is because the first time it was posted, I could not believe ANYONE in their right mind would think it would fly. The whole relative wind thing.
I and several others argued till we were blue in the face.........And then it clicked......And I got it. I came slinking back to the computer and admitted that I was wrong. One by one some of the most well respected members saw the light and sheepishly agreed that it would fly.
It is a flawed question in that the plane WILL move forward eventually. The treadmill will TRY to keep up but it wont.
Which one do you think is correct?
The treadmill starts moving. Unless I want to slide off of the back, I must add power.
The faster the treadmill moves, the more power I must add to hold my position on the treadmill.
As the treadmill speeds up, I will have to keep adding power until one of three things happens-
1. I run out of power and can no longer maintain relative position, and slide off the rear of the treadmill.
2. Eventually my maximum tire groundspeed is reached and my tires blow, and I go sailing off the rear of the treadmill.
3. Thrust finally exceeds the rearward velocity of the treadmill and I run off the leading edge. If this happens, I am now free of the rearward motion of the treadmill and will now begin to pick up forward speed very rapidly due to being at full throttle and after an undetermined ground roll will then become airborne.
What force is acting to oppose the airplane's engine thrust and thereby hold the airplane stationary with respect to the earth?
In the original post it was stated that forward velocity would be zero because treadmill speed would match the forward velocity for a given thrust setting.
Look at this way. Would an aircraft takeoff with the parking brake set and full thrust?
That about sums it up!
What if it was a giant stationary bike? Or perhaps an elliptical machine? How about that "Gazelle" Tony Little is always trying to sell me late at night?
-Blucher:laugh:
I bet ya Longhorn is sitting in the crew lounge munchin on blue-colored Jetblue chips, laughing his a$$ off reading this thread...
The only way either side can win is if assumtions are made. If I ended up in an airplane that was on a treadmill..........well........then I was most likely drunk and missed the turn at Bravo.
Darn tequeeeeeeeeeeeeeeeeeeeeeelllaaaaaa!!!!
For those of you who say the airplane will fly...prove it.
For those of you who say the airplane will not fly...prove it.
Coopervane - I thought you posted this as a joke!! Is this last post just darker sarcasm to add fuel to the fire?? Like just previously posted unless assumptions are made that you would eventually overpower the treadmill.. I dont see how youd fly..
If mythbusters did choose to take on such an idiotic myth.. It would most likely be way too expensive. seeing as they would need to use a jet aircraft.. any prop driven aircraft would not be able to maintain directional control as torque comes into play as you open the throttle.. torque would become much more pronounced than if actually on a takeoff roll.. With no wind flow over the rudder you would not be able to counter the left turning tendencies at even slow speeds.. Thus the only thing maintaining the centerline would be nose wheel steering.. Assuming the torque didnt steer you off the left side of the mill.. Friction on the nosewheel would increase very rapidly.. blowing the nosewheel and youd go tumbling off the rear of the treadmill..
If that last post WAS sarcasm.. right on!! ya got me to take a bite..
JHC, I cannot believe this thread came back...which once again proves that it doesn't take an engineering degree to become a pilot, but that likewise it doesn't take full knowledge of why an airplane flies for somebody to take off and land without disclosing that fact ...SCARY!!!
Listen up. The only relevance a moving surface would have on the aircraft's ability to positively affect its relative motion is if the aircraft's thrust was enacted through the point of contact in question, the treadmill in this case. If it wasn't clear in PPL ground school, let me refresh the class: that cessna is NOT a car....repeat with me, IT'S NOT A CAR.
The thrust created by the engine, whether the propeller driven or jet persuasion alike, is translated through a different medium, not the ground, but the fluid we call air. Therefore, the only force the aircraft has to overcome on initial takeoff is the static friction force to make the tires begin to roll. As you can see the fact that the airplane is sitting on a moving or stationary platform is irrelevant to it. Taking into consideration the assumption that tire limit rotational speed is neglected, it doesn't matter how fast that treadmill is moving, all the airplanes sees is air beginning to rush through its wings once you push up that/those throttle(s).
To further illustrate the point of why force medium matters, clamp a rope to the front end of the aircraft to a post at the end of the treadmill, a stationary fix. Now, crank that treadmill into uber-ridiculous speed...what happens to the aircraft's relative motion with respect to the air? Nothing, the airplane sits there fat dumb and happy, 0 KIAS, with the tires spinning at the tire equivalent rpm for uber-ridiculous speed. Now what about the rope? hmm...yep, once again nothing. Furthermore, the tension force will STILL be nothing more than the friction force required to make the tires begin to roll from rest.
Now, push up the throttle, what happens? Holy crap a miracle! The rope slacks and the mighty cessna moves forward with respect to the air and the tires still on fire at uber-ridiculous speed-rpm+(rpm equivalent to X KIAS). But wait. Let's put skids on that son'b%tch, assume the treadmill is now an icy treadmill, and what happens? No way! It still moves relative to the air REGARDLESS of that moving treadmill at uber-ridiculous speed.
In a real world scenario, what would happen is that the takeoff roll would be increased by the initial head-start you gave the treadmill as it began moving the aircraft backwards with respect to the air as you sat there wondering to yourself if this experiment was going to work or not. A takeoff with an initial tailwind if you want to look at it in more familiar fashion. After brake release, throttles up, the wheels start rolling and you're moving forward w.r.t. the air son.
IF the aircraft had to overcome the speed of the treadmill by means of enacting its thrust by rotating the wheels, then the treadmill would be relevant. Look at it this way. Your bass boat is going up the river and the stream is wayyy too fast for that mercury, your buddies at both banks see you sitting there idling with respect to them, at max power, and throw you a rope, then pull you in. Are they able to pull you in in spite of the wicked fast stream? Sure. And that's a worse case scenario than the airplane on a treadmill, as the water will create higher parasite drag the faster the stream, which means billy bob needs to pull a little harder, whereas the aircraft tires will keep the friction force constant no matter the speed of the treadmill. So, if you can at least buy the "buddies pull you with positive relative motion in spite of the river speed" scenario then convince yourself that strapping an IO-360, with included propeller, to your head while you duct tape yourself to your bass boat is AN EQUIVALENT SYSTEM PROBLEM!!!!
If you cannot convince yourself of the latter, you need to go back to high school physics, for you will never understand why the airplane WILL attain flying airspeed regardless of a moving ground surface. F%ck, I need my g/f...and a drink. :D
Let me rephrase what you posted:
If you think it will fly..... you are a f*ing retard.
If you think it will not fly..... thank God someone out there has some sense.
How can you people honestly entertain this concept? Go bitch about something useful! This wheel speed must equal flight bs is ridiculous.
Pretty soon this concept is going to click in your mind and you're going to realize just how much of an a$$ you made out of yourself. The plane will fly. It's just basic physics.
so you dont think the prop will pull the plane down the treadmill?
BTW im not a f*ing retard.
:) All I'm saying is that without airflow moving over the wings at a sufficient rate to provide enough lift for flight, there will be no flight. A plane, stationary, on a treadmill will not fly....no matter how fast the wheels are spinning. Now if some how it can overcome the speed of the treadmill and gain some forward motion.... then I guess there is hope (if that's what you are asking).
I just took physics last year, and the professor put this exact question on the test. About 75% of the class answered that no, the airplane will not fly.
The rest of us got the question right.
It will fly, or so says a PhD physicist at George Mason University.
Any questions?
That's the point, you're missing it.
The airplane DOES move forward DESPITE the treadmills opposite direction.
The wheels of the airplane will move forward, the treadmill goes opposite, but the friction force can only 'hold' the airplane for so much.
Soon, the airplane will move forward on the treadmill, burning rubber, smoking, and requiring tremendous power.
Theoretically, if the treadmill is long enough (several thousand feet long), and if you can get enough power, and if the tires are strong enough to take that kind of abuse, then the airplane will takeoff.
Note that the airplane is not stationary... it does move forward.
Theoretically, it can take off... realistically? No... tires will burst, and the plane will require much more power than trying to takeoff on a paved runway. So realistically, won't take off. Theoretically, it will.
It will fly, or so says PhD physicist at George Mason University.
Any questions?
Yes..One:
If the airplane is not moving forward, where is the air coming from to provide lift? No relative wind = no lift
I always thought that catapults on aircraft carriers were worthless. They should just put a treadmill on it!!! What were they thinking?
:puke:
I thought I would dust off this old gem to kill the PIC thread.
Let's say you had a giant treadmill with an airplane on it.
As you add power and begin to move for the takoff roll, the treadmill speeds up and keeps the plane in the same relative position. As the plane goes faster, the treadmill speeds up, always maintaining the aircraft's relative position.
Would you ever be able to take off?
GO!!
It seems to me that there are three camps:
1. The This is a joke camp.
2. The It'll eventually accelerate because I know more about physics than you camp.
3. The This question clearly states the plane remains in the same spot (ignoring wheels and friction and z-ratings) camp.
Why does this question make me think of dihydrogen monoxide?
Yes..One:
The airplane does move forward. The treadmill can't counteract the thrust provided by the prop/jet. Simple.
Hmmm. The question clearly states that the airplane stays in the same relative position. How do you respond to that given?
The question is written incorrectly. Quite simply, it's impossible for the treadmill to hold the airplane in the same relative position. The airplane will move forward despite the opposite direction of the treadmill.
Ahhhhhhhh. The fourth camp:
The I know what question was really asking camp, even though it clearly states something else camp.
Na, now there's a fifth camp...the camp that says the question was posed by someone that was educated beyond their native intellectual capacity...that knew little about the limitations of treadmills and even less about aircraft!
What, the Cylons are building giant fracking treadmills now instead of more Cylons???
The chemtrails are falling the chemtrails are falling!
The original question assumes the aircraft does not move, It states "As you add power and begin to move for the takoff roll, the treadmill speeds up and keeps the plane in the same relative position. As the plane goes faster, the treadmill speeds up, always maintaining the aircraft's relative position.
An aircraft with no relative wind will not fly! This question clearly states the aircraft has no relative wind.
