Let's say you had a giant treadmill with an airplane on it
HERE'S THE OFFICAL ANSWER :)
Linked from "Ask the Pilot" column at salon.com
And why should it? How can it fly if it's not moving? For an aircraft to get and stay aloft, it needs lift; it needs air passing above and below its wings. And for that it needs to move. For a cursory lesson on how this works, simply shove your arm out the window of a speeding car. Shape your hand into an approximation of a wing, angle it slightly into the oncoming wind, and voilà, it's flying.
Now, imagine you are in that same car, on a treadmill. The car's wheels are spinning -- be it at 60 mph or 600 mph -- but when you put your hand out the window, does it rise up? Of course not. Your hand won't fly, and the plane won't fly either for exactly the same reason: because for all its efforts, the vehicle isn't moving. You have zero relative speed and zero lift.
This seemed so obvious that it needed a caveat: "On the other hand, if you were able to generate a tremendous enough amount of thrust," I noted in a follow-up post, "and redirect the vector of that thrust downward, you could, conceivably, lift the plane off like a rocket. Heck, you can make anything 'fly' if you stick enough power under it. But that isn't fair to the spirit of the premise."
Except, wait a minute, what is the premise?
Go back and read it. "Imagine a plane is sitting on a massive conveyor belt," it says, "as wide and as long as a runway." I'd glanced right over those key words, "as long as a runway." I was so caught up in the image of a motionless plane on a regular old treadmill -- like the kind you might see at the gym -- that I missed the whole question. Looking back, that does seem a dull and senseless riddle: Can a plane fly if it can't move? Obviously not. There has to be more to it.
And there is. At heart, this has nothing to do with the principles of lift but, rather, with those of friction and acceleration. The gist of the question is better understood as follows: Will an airplane, under its own power, remain motionless on a 10,000-foot-long treadmill, or will it roll forward? Will it accelerate and fly?
Turns out the answer is yes. A distinctly theoretical yes, for reasons we'll get to shortly, but for all intents and purposes of the puzzle, that's yes enough.
A car won't accelerate on a treadmill; the belt will always match the rotation of the tires. You will not accelerate on a treadmill; the belt always runs in sync with your footfalls. But an airplane is different. An airplane's wheels are not powered by gears or a drive train. They hang inertly below, and are free-spinning. The thrust force that moves the plane along couldn't care less about the ground. The engines are not fighting against the surface, they are fighting against the air.
Confusing, I know, and in the interest of full disclosure, physics was the one class in high school that I outright failed and had to take twice (you try ciphering out equations while listening to Minor Threat on a pair of clandestinely strung ear buds). And some of you might remember what happened the last time I combined things aeronautical and mathematical. So let's get somebody else to explain.
According to Paul J. Camp, a professor in the department of physics at Spelman College, it's all pretty simple. "At first, the conveyor will hold the plane still. But only to a certain point, after which, driven by thrust from its engines, the craft will accelerate."
But the problem clearly states: The conveyer belt is designed to exactly match the speed of the wheels, moving in the opposite direction.
"The key is in the behavior of friction," Camp says. "Friction is a peculiar force in that it has an upper limit. For instance, push an object on your desk, but not hard enough to move it. Why doesn't it move? Because the friction force exactly balances the force of your push. At some point you push hard enough to set the object in motion. This is the point where friction has topped out and is not capable of growing any larger."
With the airplane and treadmill, there is, at the outset, friction force capable of rotating the tires at the proper speed to keep the plane stationary. However, as the thrust is increased, that force eventually maxes out. (Two separate frictions are at play here, actually, one between the tires and belt, the other between the plane's axles/bearings and its wheels. The first will max out before the second.)
"And at that point the wheels no longer roll, they slide," says Camp. "Or rather, they roll and slide at the same time. Tire motion is now decoupled from the belt motion. No matter how much you whiz up the treadmill, you won't add any more rotational velocity to the wheels because friction is already doing everything it is capable of. The plane skids toward takeoff -- likely accompanied by much smoke and a powerful rubbery stink."
And there you have it, at least on paper. Bear in mind that for a plane to reach that point of decoupling would require two things above and beyond the pale of normal engineering.
First, a remarkable amount of power -- far more than any jetliner, and probably any military plane, is capable of developing. The illustration on Pogue's blog is of an Airbus A320; some sort of rocket plane would be more appropriate. Second, no existing aircraft tires could take such abuse. The rotational velocity required before reaching the friction limit would have them bursting within seconds, causing the plane to be flung backward. Believe it or not, landing gear isn't engineered with giant treadmills in mind, and pilots need to adhere to maximum groundspeed limits, lest their tires wind up like this. These limits occasionally present problems during tailwind operations or in the case of flap and slat malfunctions -- scenarios dictating the need for unusually high takeoff or landing speeds.
For good measure, the treadmill itself, as described, could never be built. It can't "exactly match the speed of the wheels," because the wheels will turn at the speed of the treadmill plus the speed of the plane relative to the ground. When the speed of the plane is greater than zero (which it is the moment its wheels start to spin; otherwise they would never move), then the problem becomes impossible. By definition, the wheels have to be turning faster than the treadmill.
Flyer1015,
Thanks for that link and answer. I was looking for that, but you beat me to it.
It all makes sense now!!
Good answer to a crazy question.
Picture yourself on the treadmill wearing rollerskates. You hold a rope in your hand that is secured to a building far in front of you. The treadmill is moving at 5 mph and you pull on the rope. Would you move forward? Yeeeeeesssss!What if you pulled at 60 kts? Think of the propeller thrust as the rope as you pull.
12 shots of tequila
what is with the rope and skates.???
let's keep it simple
I run on a treadmill, my legs provide thrust to propel me forward 2mph. Like the propeller on my plane provides the thrust.The treadmill, if set correctly at 2mph, will counteract that forward movement the net gain zero.
In your explaination the treadmill at is moving at 5mph and you are just standing there counteracting the 5mph force by holding your position with a rope. So if you pull on the rope yes your are going to move forward. but if the treadmill reacted to your "pull" with an equal speed up still no net gain. In your example you are just going past the set speed of the treadmill. In the question it states that the treadmill is keeping up with all speed changes.
good typing for 12 shots by the way!
The treadmill cant keep up. You answered your own question. you provide "thrust" with your legs, which is dependent upon the treadmill for thrust. The propeller "thrust" is independent from the treadmill. It will try but it can't keep up.
FlyinScotsman , read my post above yours with the long explanation.
It's kinda convoluted, but I think it makes sense.
It makes sense.
But in context we all think of a 172 or even a 737 reaching normal takoff speeds on a treadmill and nothing......nada no flight.
yes there will come a point where friction reaches its max and the tires will not be able to spin fast enough to keep up and enough friciton is created that the airplane actually moves forward. That I get, even though in the explaination it admits it is at astronomically high speeds and thrust etc.
Your explanation said nothing about max friction of even eluded to it. Not quite the same.
So the original question, will the plane fly?
Theoretically, Yes.
Realistically, No.
Everyone's right.
You are incorrect.
Airspeed is taken from a pitot tube. When a pitot tube is not moving through the air, the airspeed would read zero.
This would be the case with a stationary plane on a moving treadmill. Even though the wheels would be moving, the airplane itself, which the pitot tube is attached to, would not be moving.
Because the airspeed will read zero, the airplane will not takeoff.
Bingo-we did this exercise during aero engineering 101 in collegio. Bottom line-you run on a treadmill 150 MPH and the treadmill keeps up, there is no wind in you face, errrrrr, wings.
Hey, no need to get nasty just because you are wrong!
The speed of the treadmill and the speed of the aircraft's wheels have nothing to do with it's airspeed. A plane moves due to thrust created from a prop or jet, totally independent from the ground. Where is the airspeed taken from? It's not from the wheels like a car, it is from a pitot tube. It will take off.
(I can't believe I even got involved in this one)
dumbass
I mean, really this is common sense. It's just like you running on a treadmill.
Imagine standing on the wing of this airplane. Engines spool up, wheels start rolling forward.
BUT, the treadmill goes in the opposite direction, exactly countering the wheel motion forward. And at takeoff thrust, the treadmill still goes fast enough to keep the aircraft from rolling forward.
You, standing on the wing, won't feel a thing. No wind flowing over/under the wing.
Imagine standing on the shoulders of a guy running full speed on a treadmill.
You won't feel any wind in your face.... since you have no forward motion relative to some point on earth besides the treadmill.
Why do airplanes have wheels Einstein?
So mx doesn't have to re-skin the belly every time the ham-fisted sky monkeys land.
Are those wheels powered?
(I won't answer that-you have to figure it out)
What does the powerplant of an aircraft push against?
(I don't give a flying frack at a rolling douhnut if it burns gas or kerosene-it doesn't matter)
Have you ever seen a floatplane take off going upstream on a river? Yeah, they get into the air just fine. Takes a little longer but they do just fine.
Now I want you to go to the gym and do an experiment. Not really, since you are obviously not an expert you shouldn't do this. Not at home or in someone else's gym. In fact, the illustration that follows is just that...an illustration. Do not do it. IMHO You shouldn't even be out in public unsupervised!
Get on your tread mill and crank the speed up just as fast as you can run. Then grab ahold on the pedistal that has the odometer and heart rate thingy on it. Run like a hamster on a wheel untill you are starting to get your runner's high...
then with both arms pull on the pedistal as suddenly and violently as you can!
did you move???
Do you have any contusions or lacerations? Bruises? Well, have a shot of tequilla and consider yourself lucky to be alive!
(surely no-one here is dense enough to do this!)
Again, do not try this at home...you are not an expert and you don't know what you are doing...clearly and above all else you know not what you are doing.
I'm surprised some of you can get to the airport alive...let alone find your way back to your computers! Did you all go to embry riddle or Purdue?
hehehehehe...
Went to the library and researched this for hours..
According to my calculations...using the formula V/Cl x V(t) + Treadmill speed/s x 3.14+ Gravity= your answer. Yup time to crack open another one.....F_UCK IT
If I'm flying a plane with 1000lb of Canaries, and they all get loose and are flying around inside the aircraft, does my gross weight decrese by 1000lb?
Only if they get blown through the outflow valve. Or would they get sucked out the outflow valve???
hehehehehehe...
Where's mythbusters when you need 'em?
They were already asked to look at this myth, and they refused because they said any moron could understand that the plane would takeoff without a demonstration.
another way to look at is an airboat in a river. The thrust of the airboat is from an airplane propeller.
Aim the airboat up river and give her all she's got. If the river keeps accelerating downstream as you speed up going upstream. Will you move?
If the top end of the airboat is 100kts, and the river is flowing at 100 kts the other way, will you have moved past the dock you just left on the shoreline?
Instead of calling others names, you are now resorting to self incrimination??:confused:
I am jumping in here a little late, but the folks saying the airplane will fly, just exactly what is the takeoff path going to look like? Straight up like a UFO, or regular-like.
I can't tell who's funnier. The guys lobbing in the sarcasm or the people who are legitimately arguing the point of this sillyness.
Gup
Why on earth are we discussing this one again??? And FS, I thought you were smarter than this ;)
You guys are thinking as if the engine produces forward motion via the wheels. The wheels are only there to make it easier for the engine and propeller to pull the airplane on the ground, guys... Well, and for somewhat smoother landings, I guess...
Look at it this way (using a small SE prop for ease of understanding):
You are standing in front of the airplane, holding it by the propeller blades. YES, the engine is off!!! Wheels are on a threadmill, brakes released. And yes, YOU are standing on solid ground.
The threadmill starts up, slowly at first, then faster and faster. Initially, you'll feel a tug, as the wheels start spinning, but you'll find that it's actually not that hard keeping the airplane still as the wheels go faster and faster. Yes, I know, eventually you'll get to the point that you can't hold it any longer, but that is at a much higher wheelspeed than you apparently think.
Now realize how much more pulling power that engine and propeller has. It'll easily overcome the small amount of friction the threadmill is exerting on the wheels. Thus, the airplane will move forward on the threadmill, and it will become airborne at normal indicated airspeed. TIRE speed will be way higher than normal, but assuming the tires will withstand those speeds, the airplane will be airborne LONG before the friction from the threadmill is at the point of countering thrust.
did you move???
hehehehehe...
belchfire, don't bother. I already posted what is the 'correct' answer to this whole thing.
It's the ask the pilot column on salon.com , just backtrack and find the link I posted.
