declaring an emergency
CharleyV,
Thanks for your comments. I should clarify something. Several posters have commented on calmness and coolness as though I might approach each situation as though it were a ho-hum event. Not so. I don't want to give that impression, either. Sometimes that's certainly the case, and many of my engine shutdowns have been that way; proceedural and pretty much a non-event.
When I started the season this year, I had been out of it for two years. I had been out of a conventional gear (tailwheel) airplane for quite some time, and haven't had any single engine time in donkey's years. When I did the checkout in the single seat airplane, I got airborne and thought about all the foolish things I've done in my life, and added that to the list. Just like all single seat checkouts. Depart, and you have fifteen minutes to teach yourself to fly the airplane, and one shot at teaching yourself how to land it. So it went.
Shortly thereafter, I had a dispatch to a fire above a small town at the base of a mountain. Surface winds were gusting up to 50 knots in places, and it was extremely rough. Someone questioned my definition of extreme turbulence, and this was indeed extreme turbulence. The aircraft was not always under my control. It's not uncommon when working a fire, and unfortunately, the wind and the weather is what creates and drives the fire; when it's at it's worst, that's when you go to work.
As I maneuvered close to the hillside for the first look and size-up, the airplane began rolling left. I countered with full aileron and rudder, and it kept rolling left. I lifted the gaurd to arm the drop system, and engaged the turbo switch, that gives me an extra 4% power (removes the gaurd on the fuel controller). I applied full power. The airspeed rolled back to just above stall about the time the roll started, and I dumped the nose at the ground. It kept rolling and kept slowing. I started dumping in some flap to increase the stall margin while I worked for recovery.
I recovered shortly thereafter, but was fighting hard with the local rotors agains the mountain. Lots of turbulence. When all was said and done, my legs were shaking on the rudder pedals, and kept shaking for the next hour. My toes, both pressing hard on the bottom of the rudder pedals while I did my best Fred Astair, went numb. My mouth was dry; I couldn't talk well on the radio, and most of the time couldn't move my hand enough to engage the PTT switch. It turned out the turbulence had been rough enough I'd lifted the gaurd to arm the system, but missed the switch beneath it, and hadn't been albe to dump, anyway. After that, I didn't dare let go of the stick long enough to change hands to reach over the 12 inches and move the switch.
I couldn't maintain altitude, and ended up descending below the drop site while fighting the mountain winds. I did finally get up by working some ridge lift on an opposite face, and did get two drops into the fire. The bottom line was that there was no sense of bravado, no sense of stoicness, no sense of serenity. It was a disaster in motion, to which I was a paid participant who lacked the sufficient life insurance coverage to give up.
During the ensuing drops, on the first run, I was unable to recover as I passed the target. I put out half a load and applied power, but fell off to the stall and couldn't pull from the dive immediately; I took an exit over the target and at an angle and in a bank down a narrow finger canyon while I worked the recovery. There is an irony to running out of airspeed and altitude while going down hill...usually it's overspeed downhill, but not that time. The second one went better, but that is sometimes the break on a drop. Not by choice, but by conditions, which can be adverse.
The point to it is that coolness and collectiveness aren't always bedfellows to working the airplane, though that would be the preference. No panic, no excitement, but more of a sickening feeling that comes when bile rises in the back of your throat, your leg muscles burn and feel weak, and You have an impending sense that something bad is happening or could happen, and you don't have all the facts yet.
There are certainly times when it's worse, and there have been times when I knew what it was like to have knowledge of an impending death, and the starkness of that reality. That didn't happen, but I've been there enough that I know the feeling well; it sits between a halted internal scream, and the calm of surrender to the inevitable. It's balanced by resolving to do everything in your power to fight that inevitability until no more breath exists, and to date it's that balance that's kept me alive.
My regular job involves paying passengers and employment under an operating certificate, security, IFR, turbojet engines, and the normalcy of point to point flying. It's dull, it's boring, and it's okay. I shine my shoes, I smile at passengers and greet them, and I keep the airplane on the centerline at all times. I train, I work as a team and a crew, I follow proceedures. I also have discretion, and most of the time, I'm not going to declare an emergency for simple issues. In a part 25 airplane, this may includes engine failures, that can still leave the airplane with far more performance than God ever intended a body to have.
If I need to "declare" an emergency, I'll do it. If I don't, I won't. I will not capitulate to making such a declaration based on this or that, but on the circumstances at the time of the occurance. THe former scenario in which we tossed the engine at V1 would have been the same in any airplane, in any situation. There was nobody to talk to. It was an uncontrolled field; the best I could have done is conversed with a private pilot, and our hands were full. So it is in many cases.
I've used this example many times, but it's a good one. It involves a pilot flying an ag airplane to the field, south of where I was working years ago. He was carrying Parathion 8E; for those of you who know nerve agents such as VX, it's the same. His hopper burst. He was bathed in the chemical. A single drop on the tongue can kill or incapacitate. It's absorbed through the skin, the vapor is lethal. He was in a bad state.
He spied a dyke on which to land (the mass of earth pushed up, not the...). He set the airplane on the levee and got it stopped well enough. Water was in a ditch alongside the dyke, and if he could get into the water, he might have a chance. He cut away the canopy door, tossed his helmet, climbed down, and made a beeline for the water. He would have lived, if he hadn't run into the still-turning propeller. Speed kills, and sometimes there are issues bigger than the perceived "emergency." Stepping back and looking at the real picture may save a life. Maybe the emergency isn't such a big issue after all, maybe it is. One cannot make a blanket statement one way or the other; one must deal with each event as it occurs.
Bottom line? Deal with each event on it's own merits, according to the proceedures, training, and judgement that is in you. Beyond that, rely on God, and every other resource at your fingertips.
Anybody who has ever sat in the thunderous silence that surrounds Al Haynes when he speaks of his experience in a crippled DC-10 has heard a masterful presentation on the handling of an emergency. May none of us have to go through that, but thank God somebody did, and lived to share it with us. Just remember, no matter what is is that any one of us has experienced, it pales in comparison to that of others. All we can do is use the experience that is in us to make good judgements. Beyond that, it's God, and luck.
avbug
You should write a book! Or at least, an article for one of the magazines like Flying. I read your last post and couldn't stop reading. That is some exciting life you live, on the edge. I think, I would like to do that sort of exciting flying - and then common sense takes over and I say "YGSB!"
Godspeed in your flying. Sounds like God isn't just your co-pilot, he's right there pushing your wing back up.
Tri-holer said:
avbug
Tri-Holer,
You took the words right out of my mouth; avbug should and must write a book. He has more diverse experience than anyone else on this board or in aviation period. He certainly has the skills needed to convey a message to low time or high time pilots. His background and writing skills coupled with his impeccable understanding of the regs would make it a hit, I would be the first to buy it! This mans talents would surely go to waste if he doesn't write that book.
What do you say avbug, you would be doing all the low timers a service that only you could provide with such wisdom, experience and especially heart! Please don't let us down, we need ya!
Not everyone agrees with everybody all the time, I agree with avbug most the time as do most people that read his posts.
Lets do a survey to see how many would buy avbug's book.:D
At this rate, I am afraid, I doubt Avbug will live long enough to write a book. Most pilots fly in environments where they are very likely to make it home from work in one piece. Definately a different world from the one Avbug is describing.
With the number and severity of senarios Avbug has been describing surely he must see that it is just a matter of time?
A little realistic risk assessment is called for, though he said himself that some of the fire pilots think of themselves as "disposable", so I guess he knows how fragile his existance is.
Fire fighting is a noble job. Can't do it when your dead though. Please be careful Avbug.
AVBUG
AVBUG is quite simply the most dangerous pilot on this board.
He glorifies his job by stating that his very function is a constant on-going emergency. He romanticizes the callousness of his attitude by stating it is normal and every day rigors of the job.
If his job is as dangerous and hazard filled as he makes it sound and his situations as commonplace as he makes it seem then one thing is clear to me. I would declare an emergency every day. I would not allow the frequency of the hazards to drag me into a sense that because it happens all the time it isn't a danger and doesn't warrant the exact same response every time.
Fine, I have read the drivel about how it wouldn't make any difference and its a judgment call and some fires just aren't that big of a deal. Unfortunately, AVBUG would like to substitute experience for good judgment. He says to himself, "Well I came through that ok so I guess it wasn't really an emergency." The word for this is complacency. There is a phenomenon in aviation called the failing aviator syndrome. It is characterized by a pilot who begins to view very non normal and even dangerous events as commonplace. He begins to feel that he is impervious to danger and is so skilled that he can overcome any problem with his cunning and experience. In the extreme he will acquire NOFAD. No apparent fear of death. This happens when he has lived through enough and survived enough to have the feeling he is invincible. I don't mean to suggest AVBUG is there yet. But the tone and manner of his posts suggest he is close.
What really scares me is that he obviously has impressed many of the young pilots on this board by his Chuck Yeager stories and tales of the improbable. Aviation's number one concern is to operate your aircraft in a manner that gives you the greatest chance of survival. I don't care what the job is. His statement on the number of pilots in his line of work that have died really gives me pause. The poetic license that he employs in relating his stories like he is the hero of some novel scares the !@#$%^ out of me. It really concerns me that I share the air with a pilot with that sort of attitude. I'm still not sure he's for real but if he is, he's a real hazard to the profession and he doesn't even know it....no matter how many hours he's lived through. It's like the guy with 6 DUI's. He's toast he just doesn't know it yet.
So I guess we can't count on you to carry your weight, huh? Too bad. We could have used an intelligent guy like you in the fire service. It's a shame we won't have the opportunity to avail ourselves of your superior judgement. Ah well. If you change your mind...
Re: AVBUG
I disagree...to a point. Avbug's posts are a product of the flying experience he has. I'm comfortable that he is very good at what he does. If there was a raging forest fire bearing down on my home, I'd certainly hope he was above it with a load of borate and water.
But I wouldn't put my family on a passenger aircraft he was flying...just as I'm sure he wouldn't bet ten cents on my chances as a tanker pilot. (Although I'll bet we could both learn...)
Anybody remember the movie Jaws? Hooper (Richard Dreyfus) represents those of us who fly modern airliners. Quint (Robert Shaw) is Avbug. Same industry, different jobs...and each job has a totally different set of rules and requires a different way of thinking. That doesn't mean that either one of them is wrong.
A word of caution: expressing views like Avbug's during an airline interview means not getting the job. Take it from someone who is the son of one chief pilot (at a different airline--no nepotism here) and a friend of several others. If you tell them that "an engine fire isn't an emergency but could become one," you just blew the interview.
Interesting. I've never had a problem in an interview, and I've provided realistic viewpoints every time. Might even say it's gotten me a job.
To date, I have yet to have a passenger complain, and I have a stack of letters or recommendation from former employers, pilots, and check airmen. It's just a few folks on the board here who seem to have the problem.
I fly Part 25 turbojet airplanes in passenger service as my regular employment, and have absolutely no difficulties at each check, during training, or flying the line. Never have. I just don't get worked up if a break a fingernail.
I'll go so far as to say I know a pilot who nearly lost his job for discharging a fire bottle at altitude after receiving a fire light. It was a circuit problem, not a fire. The employer, a certificate holder and operator, reprimanded the individual (I disagree with their actions, but it's not my place to do anything about it) over the incident, in which he put two bottles into that engine when there was no fire. He caused panic for the pax, and landed short of the destination.
Were I in his shoes, though he did act a little rashly in the way he went about it (based on crew reports), I would very likely have done exactly the same. I doubt I'd have done it with as much excitement or drama, or in as much of a rush. However, in absence of any proof that there wasn't a fire on board, I would have shut down per the checklist, and if necessary, discharged a bottle. I would have notified ATC, and landed as appropriate. Most likely I would have landed at the destination, which is also per the checklist, if certain parameters are met.
I don't know that I would have felt inclined to make a mayday broadcast, to shut the engine down with the T-handle and discharge the agent right away, or start an emergency descent to a field short of the destination as he did...again, it's not my place to say. I wasn't in the airplane, and only know about it from the reports. As I said, I disagree with the way he went about it, but the general actions are pretty much as I'd have done.
But then apparently I'm a very dangerous pilot. Right? Please dont' tell the FAA...no telling what they'll do. But wait! I'm an accident prevention counselor for the local FSDO. Perhaps I should turn myself in, stop giving safety seminars and counseling students and college classes. Perhaps I should give up my auxilliary assignment as Director of Safety for the company, do ya think? Perhaps I should quit instructing on the side, too. I don't want to be responsible for thousands of deaths. And quit fixing airplanes too...they need someone much more responsible to do that. Counts me out.
Why stop there? I could turn in my drivers license, and possibly sell my handguns and quit reloading. I might as well chuck the parachutes in the trash; no more skydiving for me. I'm dangerous. I'll wear thick gloves so I can't molest pets and small children while walking down the street...seeing as I can't drive anymore. Thank heavens there are people on this board who can set me straight. It's a good thing I tune in here, isn't it?
Maybe I'll just get started on that autobiographical novel; "Top ten reasons why I should throw myself off a tall building, and the top twenty reasons the world will be safer when I'm gone." Whaddayathink???
Or perhaps I'll just keep doing what I'm doing, because everyone who is around me (to include the FAA, employers, etc) has absolutely NO problem with who I am or what I do. Yeah...I think that's what I'll do.
And clownpilot, seeing as there's no rational ground for discussion, and sanity, maturity, and serenity is out the window, let's just meet out by the flagpole after school so I can kick your butt up around your ears. It may be the one thing I can do REALLY well. Whaddayasay?
PS: Typhoonpilot, who's to say your family hasn't been passenges on a trip I've flown already? Ya just never know.
Avbug
Hey dude, I really am trying to stay off your back, but now you are threatening people with violence. So not only are you one great pilot, one great mechanic, but also a great fighter?
Is there an ultimate fighting championship message board where I can read about those exploits?( I am serious)
What planes do you have time in? Not a detailed list of everything you've touched, but how much total time PIC in heavy type 1 tankers? About, nothing precise, you know an estimate. You could fill out that profile column instead of assuming everyone knows your accomplishments. See I filled out mine, so everybody knows I am a podunk.
How much PIC and what type of part 25 plane are you talking about?
And lastly, between this and other boards you post on you pretty much live on a computer. It is hard to see how you also have time for a job and friends and fighting. Ease up, try some humor. Maybe have a beer. Who knows you might even meet a woman.
Avbug,
This probably goes without saying, but I wouldn't get too wrapped around the axle about anything Clownpilot has to say. Given most of his posts, in most of his threads, ignoring him is usually the best idea. Don't fuel his fire, so to speak (pardon the pun). ;)
Fly Safe.
Well first of all, I'm not "Typhoonpilot." There's another guy out there that goes by that handle.
Secondly, as for any of my family members being on one of your flights, what can I say? I'm sure you're a fine pilot, but I think you're leading some of the younger students on this board astray on this issue.
Does anybody remember the original point of this thread? "What are some real-life situations where you would declare an emergency?"
I put it to all of you that in modern aviation, when something goes wrong, a pilot must remember the four fundamentals: (1) aviate, (2) navigate, (3) communicate, and (4) cover your a__, in that order. Declaring an emergency has very little to do with the first two fundamentals. It's related to the third, and it has everything to do with the fourth. It would be great to live in a world where "C.Y.A." didn't apply to pilots. We don't live in that world.
Like so many of the other airline pilots that have since abandoned this thread, I don't understand this decades-old fear of declaring an emergency, and I'm tired of arguing about it. I will leave you with a question that I have posed several times now, a question not even The Mighty Avbug has attempted to answer: why make it easier for the F.A.A. and/or your company to take action against you by not declaring an emergency--an urgency or distress condition--when one arises?
Engine failure in a twin? Yes, declare. Vacuum failure in IMC? No back-up for the vacuum system? Yes, declare. If the ability of the airplane to safely fly has been seriously affected, either by a mechanical failure or by some external cause, a declaration is appropriate. It doesn't mean you don't have the situation under control. It establishes a structure between you and A.T.C. that will make it easier for you to meet the emergency.
Would I reach up and yank the T-handle the moment I saw a red light come on? No. Why? Because I'm not a moron. I'm sorry, Avbug, but "young" and "low-time" do not mean "inept."
This thread is raising my blood-pressure; I'm not coming back. If any of you guys have questions on this issue and would like my input, PM me.
>>Why stop there? I could turn in my drivers license, and possibly sell my handguns and quit reloading. I might as well chuck the parachutes in the trash; no more skydiving for me. I'm dangerous. I'll wear thick gloves so I can't molest pets and small children while walking down the street...seeing as I can't drive anymore. Thank heavens there are people on this board who can set me straight. It's a good thing I tune in here, isn't it?>>
Well, as for the skydiving..........Go ahead and toss the parachutes in the trash..........but continue your skydiving.
Turning in your pilot's license will be sufficient. Frankly, if your car starts on fire I don't really care whether you keep driving it or not.
As for molesting pets and children I have already stated that I believe you have mental problems; mostly having to do with a complete lack of connection to reality.
>>Maybe I'll just get started on that autobiographical novel; "Top ten reasons why I should throw myself off a tall building, and the top twenty reasons the world will be safer when I'm gone." Whaddayathink???>>
As I said, relinquishing your pilots license will suffice(assuming you actually have one).
>>And clownpilot, seeing as there's no rational ground for discussion, and sanity, maturity, and serenity is out the window, let's just meet out by the flagpole after school so I can kick your butt up around your ears. It may be the one thing I can do REALLY well. Whaddayasay?>>
Why doesn't that response surprise me. Please seek help.
Wow! Is this the same Avbug that berated me for saying that I would treat a head cold with OTC Dayquil or Sudafed before flying? The same Avbug that, in so many words, suggested it would be better instead to call in sick until the symptoms subsided, presumably about 10 days? Talk about schizophrenia.
I think some of you are starting to see the curtain drawn on the Wizard. Keep pulling.
There is no double standard; you would be best to call in sick. Exactly as I said before. I would.
Go back and read all the threads. The origional question was about declaring an emergency, and in every case I have repeatedly stated: IF YOU NEED TO DECLARE, DECLARE, IF YOU DON'T NEED TO DECLARE, DON'T DECLARE.
Real simple, huh? Nothing inconsistant, no differing of standards. I've given examples of my own behavior to back up this statement, and examples of others with whom I'm associated. Each example has been consistant.
If you fly with a headcold, you're an idiot. If you elect not to fly when you have a headcold, then you've exercised good judgement. Clear?
Wouldn't be a Web forum without the occasional catfight would it?
Back to the original discussion, here's my take on declaring an emergency. The first time I had a Flameout (compressor stall) I declared an emergency, went down low, got it re-light as soon as I was in the relight envelope and was back on my way, no problem, no paperwork. Couple of weeks later I had another flameout, did the exact same thing, except that I felt stupid for declaring an emergency. Third time I Flameout climbing out of FL410 I decided to play it cool.
Me: "Center, Lear 12345 is going to need to go down to FL250 to reset our pressurization system."
Center: "Are you declaring an emergency?"
Me: "No sir, just need to go down and hit the reset switch."
Real cool, right? Well, center didn't seem to think so, as I descended into traffic at FL370 (see the Lear won't stay at FL410 on 1 engine). Long story short, I ALMOST got violated by not declaring an emergency on a minor problem (flameout), thereby causing a MAJOR unseen problem (loss of separation), that could have easily been avoided had I just declared.
On the other hand I also see Avbug's point, Declaring MIGHT not do you any good. Bottom-line use your best judgment and never be afraid to declare, but realize it's just a tool, and it might not be the tool you need!
PS- for those Lear drivers, it wasn't pilot error that caused the flameout, but bad fuel computer.
The case brought up by 501261 is a good point. A declaration of an emergency was made the first two times (if I read correctly), but not the third. In the third case, the proble arose when ATC wasn't informed as to the actual nature of the problem. Had ATC been informed that the flight was unable to maintain altitude and was experiencing an engine-out, certainly priority would have been granted. Weather or not an emergency had been "declared," you can bet ATC would have granted priority handling.
It's imperitive to communicate the nature of the problem to ATC, where able. (Assuming ATC can hear, or that communication capability is available, of course). It may or may not be necessary to declare an emergency, but we know that we are required to notify ATC at any time if a condition exists which affects the safety of the flight. That goes without saying.
A friend with whom I flew is presently piloting for a major airline. He left after several years in fire service, after a full career with a branch of the service as pilot in several capacities. He was an excellent pilot, and to my mind an excellent example of an officer and a gentleman.
We experienced a hydraulic loss during a drop on a fire. He flew the airplane while I went aft to troubleshoot and attempt repairs. I isolated the systems as appropriate, and replenished the hydraulic supply, but was unable to restore hydraulic pressure.
We notified the Lead working the fire, who escorted us back to the tanker base at Lake City. The lead, a former Initial Attack Captain on that airplane, performed an enroute external inspection of our airplane, using his Baron. The base manager was notified, and he elected to close the base and send all tankers to TLH. He notified the airport crash rescue, who deployed on the runway while we circled overhead.
After 45 minutes of troubleshooting, checklists, and discussion, we elected to land. We manually extended the gear (which involves going downstairs and throwing the nosegear out by hand on that airplane, incidentally) and flaps, and prepared to enter the pattern from above. The issue on landing was lack of directional control; the nosewheel on that airplane (4Y) is freecastering, and it won't roll straight for more than a few feet. Brakes are the means of steering, with differential power being of little use when attempting to slow during a landing. In that airplane, loss of hydraulics means loss of control on the landing.
As we prepared for pattern entry, a bee of some kind emerged from behind the drop panel. It began flying around us, and seemed attracted to my cohort. My friend became very agitated, and then admitted that he was allergic to bee stings. I exited the flight deck and went through the bomb bay to the rear, and tore apart his luggage searching for an epipen in case he needed an injection. I couldn't find it, and returned to the cockpit area. The bee was still there, and my friend was very excited.
At this point, the only emergency, as far as he was concerned, was the bee. We had dealt with the other problem(s), but the bee was a bigger one. I was able to catch the bee in my hat, and toss it (and the hat) out the top hatch (didn't attempt to swat it for fear of missing, and agitating it and making things worse).
We recovered hydraulic pressure on final, and landed without incident. We stopped on the runway, and were inspected by crash rescue, before proceeding to the loading pits to shut down. It was then I determined that a hydraulic actuator in the #4 tank had blown out, draining the entire system. A little over two hours later, the repair was done, and we were back in service.
The point there, for whatever it's worth, is that all the elements were present. No emergency was declared formally, but everyone was kept informed, and all necessary arrangements were coordinated. Mouthing the words "I declare" wouldn't have changed that; everything worked exactly as it should. Certainly when the more significant immediate threat to health by the insect(s) occured, nothing more could have been gained by declaring an emergency. An ambulance was already in place, and there was nothing more to do but deal with the situation as best we could.
One year later my friend elected to take a job with a major airline, where he is quite happily employed. I believe this particular story, which is humorous when properly told, was shared by him in his interview. He used it, with the full detail not given here for brevity, as an example of how to deal with an "emergency," as well as proper crew coordination and resource management. Those conducting the interview responded well to the incident.
Incidentally, the structural failures aren't an exaggeration, and are a matter of record in Service Difficulty Reports. They've become a matter of some interest lately, because we cracked both wings on a C-130A during work on a fire outside the country; two months ago both wings came off that same airplane during a drop. That matter is currently part of an active ongoing investigation. Other failures occured, but none as noteworthy.
General opinion around here is NOT to declare an emergency unless things are really bad and seconds away from being fatal. This is the WRONG idea.
I have actually heard other flight instructors give scenarios to their students and it does not take too many stories to get the picture that having a problem is a shameful act and should be dealt with as quietly as possible. It is such a terrible and dangerous philosophy to teach pilots.
Do not be conservative with this tool. Use it anytime you have a problem that can lead to a bigger problem if you do not take care of it immediately. Don't worry about any possible paperwork at the end. That is the least of your worries. If it has you rattled, even if it is something you did (or forgot to do), don't hesitate to declare an emergency and get back on the ground.
NTSB is full of ATC responses like "he seemed to have it under control and responded in a calm matter", or "did not realize just how low on fuel he was because he did not declare", etc, etc, etc.
If you have a problem outside of your personal experience level, declare the emergency. Everybody will get out of your way and be happy you made it down safely.
avbug said:
<snip> IF YOU NEED TO DECLARE, DECLARE, IF YOU DON'T NEED TO DECLARE, DON'T DECLARE.
It is just important to evaluate WHY you decide not to declare. If your decision is based on pride, looking stupid to your peers, fear of paperwork, over confidence, or in general worrying about some consequence OTHER than the problem at hand then your decision not to declare is tainted.
I am trying to avoid examples but here is one anyways. Back in the day of being a new pilot I had a door open on takeoff, it was a different enough experience at the time to startle me and distract me from flying properly. I chose to declare and land. I shut the door and departed. No paperwork. Perhaps a few folks thinking I was too punchy on the "E" button, but who cares. Years and experience later a door opening is not a big deal (Especially after flying skydivers for a year). I would never declare now because at my experience level this is clearly not an emergency, but at the same time I would not think less of any other pilot that did declare something that I felt was minor or a strech. Again, I feel that it is important that new pilots especially understand that emergency and imminent death ARE in fact two different things.
As a air ambulance I was flying along 40 miles north of Boston Login on a Friday afternoon. I left Madrid Spain early that morning with a patient enroute to Miami .So I stoppped in Azores then Nova Scotia,Canada. All of a sudden I see crap in the back flying every were as the medics are now working with a cardic arrest patient. I tell so the closest airport with any sort of good medical facility was Login. I declared a medical emergency center cleared my directly to runway 9 and descend to 3000 feet . Remember I was at 35000 feet now 30 miles from the field. So 7 minutes later I,m sitting on the ramp with Airport police, airport ambulance, hospital ambulance and customs but no immigratiion. Pretty wild stuff.
Typhoon1244 said:
There are certain companies who strongly discourage--to the point of termination--declaring an emergency. AirTran is one of them. They discourage this because they're worried about the "bad press" an emergency could generate. I'm sorry that this attitude about emergencies is being perpetuated.
I've quietly sat back and read some pretty stupid posts on this site many times, but this one takes the cake!
It's clear you've never worked for AirTran.
Just a general series of random thoughts:
1. Declare the emergency just to be relieved from the FARs requiring airworthy airplanes. An alternator failure is a minor annoyance to me; number 9 in IMC was last week. This time the battery lasted until landing. Sometimes it doesn't. Fine, Approach clear me to land and tell tower I'm coming in, and no, I'm not canceling IFR and remaining clear of your airspace.
2. Just because I've told ATC "Mayday" or "Emergency" doesn't mean that I'm anything other than confident I can handle the situation. It may mean I'm not putting up with anymore of their BS and need to get the now POS airplane on the ground, NOW. And yes, Southwest is going to have to do a hold and pass out some more peanuts. Now I'll do my best to make sure I'm not unduly delaying other air traffic, but if I need the Class "B" airport shut down while I'm getting no-gyro vectors across the approach paths to do a PAR at an Air Force Base, I am. To all of the crews of the 25+ airliners that sat an extra 20 minutes at a certain Class "B" airport during push, thanks.
3. You won't believe the amount of **** you can pull and be completely cleared of all charges because you got on the ground safely. Open up part 91 and use it as your checklist of rules to break. If you live and the FAA has questions, you did what it took to meet the emergency using all of the information you had available. "You declared an emergency, what can we do?" Worst case, after a year, you're still alive to take some checkrides and get your certificates back. 'Tis better to be tried by twelve than carried by six.
4. Roll the equipment. Those guys live for jumping into their vehicles and racing to the edge of the runway. When you're on short final with a single-engine twin when you discover the gear won't extend, your thoughts will touch on the fact that ARFF is still upstairs playing cards in their firehouse.
5. Who am I setting an example for? I usually have a far less experienced pilot in the seat next to me that considers me to be the ultimate authority on anything aviation. If I don't declare in front of them, when they are out with their family on board, they may also not declare for something far more serious and accept ATC delays. They may not get on the ground safely. Even airline crews get killed by not declaring.
6. You may not really know how serious the problem really is. What I thought was a vacuum failure was an intake manifold departing the engine. The main separation was right next to an exhaust leak. . . hot exhaust right from the cylinder blowing directly on the ready-to-combust fuel/air mixture. At best, loss of power, at worst, ka-boom!
7. If the controller asks if you are declaring an emergency, my response is always "yes". There is a reason the controller asked. Sometimes they see a route that they can give you to get you on the ground fast but they can't give it to you unless you either ask for it or declare an emergency. Controllers get to bend rules in an emergency, too. It helps them in the tape talk to have the rules broken for an aircraft in distress.
8. The life you save may not be just your own. I declared an emergency after encountering severe turbulence in a light single engine in IMC. I was fine. I had regained control of the aircraft, but my passenger had hit the ceiling three times while still buckled in. He had a minor concussion. Five minutes after landing a twin with gyro failure (he'd declared) was headed to our area and the controller refused the handoff from the other sector, "We just had a Cessna and a regional jet encounter severe turbulence. This is no place for a light aircraft with gyro failure." The twin pilot, fully in control of his twin partial panel, thought this was really, excellent, useful information, turned around, and landed safely.
9. Abnormal smoke (not from the outside forest fire) in the cockpit at 500' in the mountains. Who am I going to declare with? My observer? His nose works. The scanner on his first flight in the back seat? If killing the master had not made the smoke stop, we would have been landing shortly. On the way back to base we carefully returned one radio to service and let base know what we were doing.
10. Checklists and ops rule the 135 aircraft. If X, we run the checklist and if time available we declare. If a spot on the white shirt requires declaring an emergency, then so be it. If the left wing falls off and the company does not want an emergency declared even though we will be descending rapidly, I'm not working there.
11. ATC is trying to run me into the side of a mountain. I'll verify the controller still wants me on the heading and altitude. Usually they respond with a climb and a turn sounding like Mickey Mouse. If they don't, they've got one mile and them I'm climbing and turning, and declaring an emergency because I'm deviating from my clearance. If the pilot screws up, he dies. If the controller screws up, the pilot still dies.
12. I've got fuel to Oakland, my alternate, and 60 minutes. ATC reroutes me to Oakland through Portland 10 minutes after takeoff. "Minimum Fuel." If they come back with "Cancel IFR," I come back with "Emergency, 4 hours 20 minutes of fuel remaining."
13. Deviating around build-ups. There's no emergency or question. I'm turning right/left 10/30 degrees around a build-up. SO is everyone behind and in front of me.
Fly SAFE!
Jedi Nein
avbug said:
I've had engine fires and muiltiple failures, irate passengers and medically challenged passengers, structural failures, and once had someone in the right seat experience a heart attack. However, I have never "declared" an emergency. I rolled the rescue trucks once, and that wasn't my decision (but I didn't fight it, either).
Most of the time the situations have been handleable without outside intervention. Situations which have warranted declaration in most cases precluded taking the time to make such a declaration...usually too busy for such formalities.
Bear in mind that declaration of an emergency isn't necessary to get priority handling, and also bear in mind that ATC can make the decision for you. Also bear in mind that declaration of an emergency isn't the E-ticket to freedom from violation; don't declare an emergency to save your self from a violation. The FAA isn't stupid, and attempting to cover up a problem by declaring an emergency doesn't bode well.
If you do have an emergency, notify somebody about it if it will help. There is no harm in it, and there can be some terrific advantages.
Don't automatically assume an instrument failure, or engine failure, or even a fire is an emergency. Look at the specific circumstances of the moment and weigh it against your options and needs. Don't hesitate to ask for help, but don't make a mountain out of molehill, either. I have yet to have experienced an engine failure in which making any such declaration would have made one iota of difference, but that's not to say it isn't possible. In the few cases when sweat was caused to form, talking on the radio was the farthest from my mind, and certainly my lowest priority.
Sometimes the declaration of an emergency is perceived to be a mystical act that changes the nature of everything, and that a formal declaration must be made. It's viewed as though ATC cannot help and assistance cannot be brought to play without this magic act. Not so. State your problem and your intentions, and treat it just like you would any other phase of flight. It needn't be formal, or melodramatic; tell ATC what you have got, and then fly it. Certainly don't minimize your statement (typified by the historical significance of "minimum fuel" vs. a true emergency, for example), but tell it like it is. State what you intend to do, and then do it.
One thing I have seen in declarations is the unwillingness to fully take charge of the moment. Rather than state that Flight 683 would like to return for landing, state that you have an engine fire and are proceeding direct for the numbers, request the trucks, etc. Tell ATC or whomever you're talking to exactly what you have, what you intend to do about it, and what help you need. Then have a ball.
I'am confused. You say that you have had engine fires, multiple failures, a passenger who has had a heart attack, and structural failures but you don't think that any of the highlighted areas are emergencies. If I was the passenger having a life threatning situatiion such as a heart attack, I would want the pilot declare an emergency and get me help right away.
In the last paragraph you say that if you have a fire, request the trucks and go right for the numbers. My question to you is that if you tell ATC you have a fire, or structural failure, why wouldn't you just tell them that and that you are declaring an emergency? By doing so, you are telling ATC that your aircraft and passengers are in grave danger. You also get the chance to tell them what is going on which could assist the NTSB and the FAA in determining what happened and how to prevent it, because it will be on tape.
You also say don't make a mountain out of a molehill. Is a passenger having a heart attack a mountain, or a molehill? I also can't count the ways that telling ATC you have an emergency helps. You lose an engine in the mountains and you can't maintain obstacle clearence, wouldn't you want to ask ATC where the lowest terrain is located relative to your position. This is just one example how ATC can help.If I read the post correctly, I should use my best airline captain voice and tell ATC I have a little problem, I have another airplane stuck in the cockpit and can't maintain altitude, but It is not an emergency at this time.
There seems to be a popular idea that declaring an emergency is carte blanche to toss the rule book out the window, it ain't so. You are allowed to deviate form the regulations to the extent required to meet the needs of emergency, nothing more. If you think that the FAA will not review your decisions and second guess whenther your deviations were necessary, you got another think coming. Perhaps they will not, but here have been plenty of cases where the FAA has disagreed with a pilot's judgement in dealing with an emergency and has handed out violations accordingly. Furthermore, the emergency authority only works if the emergency is no fault of your own. If you contributed to your being in htat emergency, the provisions of 91.3 do not apply. It is well established in NTSB case law that the FAA may violate you for deviating from the regulations if your emergency was a result of your judgement.
Yeah, you're going to come roaring out of Bakersfield with your mighty warrior and a wheelbarrow full of clanking balls. If ATC gives you anything less than a perfect routing your gonna whip out the "e" word and slap them around, whip them into shape and get exactly what you need from them. Yeah, all you gotta do is declare an emergency when you have over 4 hours fuel on board and plenty of options.
Bad idea, really, really bad idea. Here's a link to an NTSB decision in the case of a pilot who did exactly that, used minimum fuel and the e word to bluff ATC into direct routing wheh he had plenty of fuel. http://www.ntsb.gov/O_n_O/docs/AVIATION/3932.PDF Notice that he got his pilot certificate revoked. Kinda stupid advice when you compare it with how the world really works.
1) if you are 10 minutes out of bakersfield with 4 1/3 hours fuel on board, you don't have an emergency. You have plenty of options
2) If you realy did have a fuel emergency, continuing to Oakland is not a necessary elemnt of meeting the emergency, gettig on the ground is, and you have many much petter options than Oakland.
3) If you have a fuel emergency because you continued on to Oakland after ATC delays, the emergency is of your own making, so the protections of 91.3 do not apply to you.
Still think it's a really cool idea to use the e word to beat ATC into submission and get the routing you want?
Wow. Lots of conversation on a post I made two years ago. Good grief.
Absolutely, 100% CORRECT!
I have no issues with that. I have always espoused the same thing.
However, it also seems that what we have here is a passle of folks who either can't read, or failed to comprehend...so for those who have nothing better to do than reply to two year old threads, what the heck...
I'am confused.
Don't be. You'll only get a headache.
I wouldn't be suprised. Two brothers. One an airline pilot, the other a 747 Capt and F-16 pilot in the ANG we're flying their family owned 421 back home after a family vacation. Both families were in the back, lost an engine, never declared an emergency. They flew it 25 minutes to their home base.
Being that the point of these replies has been to worship the almighty holy act of declaring an emergency and to abhor and castigate anyone who would fail to utter the magic mantra, you're talking apples and oranges. I never said a word about not dealing with a problem...I did say that there is absolutely NOTHING magic about "declaring" an emergency.
Don't ever be lulled into thinking there is. The successful outcome of your emergency evoloution is in your hands, not in your microphone; you are responsible for making it happen.
You're describing in the quoted paragraph above, two individuals who are apparently well technically qualified, who elected to pursue a particular course of inaction. That may have been the best course, it may not; you provided no particulars. However, I never advocated that, did I? (for the slow...I did not).
What I did stipulate is that "declaring an emergency" has taken on some sort of mystical aura; an epithet that calls out to the help-gods and sends them scurrying to your aid. The skies change color, your skin tingles, and your dandruff is immediately cleared. Your skin is clearer, and runways around the world open their doors to you, angels sing, and mayors polish the key to the city.
As opposed to simply stating your situation, your intended actions, and then doing your job...flying the airplane and dealing with that situation.
If you're given priority, you're given priority, period. State your situation, and your intentions. You can use the magic "e" word in there if it makes you feel better. When I worked fire on the ground, I knew folks that just loved to run lights and sirens. Some sort of schoolboy fantasy. Sometimes it's warranted, and sometimes not. I liked to slow down, turn the **CENSORED****CENSORED****CENSORED****CENSORED** thing off, and arrive on scene without a headache, one minute slower, and in one piece.
If you state your situation and you don't get the help you desire, you restate it...or not. You've already identified your intentions. You're not asking for straight in to XX runway, you're telling ATC your intentions. And so you should.
Flying for 25 or 50 or 100 miles when it's unnecessary (assuming it were so in your scenario...for all we can do, with the lack of information, is assume), is another matter. That is lack of action. Not merely "not" declaring an emergency, but seemingly ignoring the situation completely. Something I have never advocated. Respond slowly and deliberately, fast hands kill. But respond.
I imagine you might, but if I were the passenger, I'd want the pilot to get me to help safely, and to do the job to the best of his abilities. Do you suppose that "declaring" an emergency, that magic phrase that makes the angels rush to your side, will make a bit of difference? Or will simply stating your situation and your intentions cover it, instead. Are you going to carry 250 knots to the runway threshold, scream down to the end on smoking brakes, throw out the slides and evacuate the airplane into the waiting arms of salvation with bright, red, flashing lights (all for the want of cuticle removal, or perhaps the ever popular screaming heegeebees)? Fly abnormally and meet the ambulance on the runway, just like an episode of Emergency, or Chips? Or just state your intentions, get priority handling, and go?
Me? I'm just going to go.
I've had critical patients on board when flying ambulance, many times. Knowing that use of the term "lifegaurd" will already grant priority, using the magic "e" word seems superfluous. Priority is priority, and you don't get more simply because you use the "e" word.
Folks get excited when they see a fire. They run, they panic. They flip out. The drool, they get short of breath, their thinking and their vision narrows. They even run back into the flame. A professional doesn't do that. A professional walks calmly to the fire, sizes it up, and works it. We are professionals. Not deer frightened with panic.
Ah, ten-four there, good buddy. I can see where using the "e" word makes it all crystal clear for ATC, the FAA in general, and the NTSB. Good thinking. After all, I merely have suggested identifying clearly your problem, stating your intentions, and then handling it like a professional. Throwing that pesky "e" word in there makes it all different. Generations will learn volumes from the use of that "e" word. Good idea. Now it's all clear as a bell.
I can see where "XXX approach, XXX is making straight in for three four left with an engine fire, request trucks and an ambulance," would not convey the problem at all. ATC would never guess that anybody needs assistance...after all, they might think it's a weenie roast, or a sightseeing tour. Throwing the "e" word in there changes everything. Good thinking!
I do, indeed.
Now, that really depends. There are times, most times, when even the most pressing matter doesn't call for a run, but a walk. After all, rushing is when folks get hurt.
Someone has a fire, and presses the panic button. Let's exercise that emergency descent we were taught as student pilots...lets' get into that little forest clearing right beneath us, because, by golly, we have a gen-u-whine eee-mer-jun-see! Don't take no notice, will ya, that there's no way to get help down there, that you'll set the forest on fire around you, and that there's nothing to put out the fire...just get it down there. Get it done, as they say. Durn goot thinking, there.
Same with that heart attack. Big emergency folks. Everybody look at me. I'm having an emergency. I'm going to rush to the ground right here, put down in this field...after all, a person dying from a heart attack is a whole lot safer over here, behind this hay stack, than in the air...on the way to a runway where help might be waiting. But declaring that "e" word might just bring them back...the smile on their face, the warmth radiating out when that grateful patient hears the "e" word might just restore a shockable rhythm to that person's heart.
Or you could simply contact the local unicom, contact center, contact an approach or tower or other ATC facility, state your situation and intentions, while you act on them. Panic, the traditioned perception that some how the magical calling of a situation an emergency changes the situation miraculously, lies steeped in the wives tale fostered in errol flynn movies of silk scarves and oversexed virile actors.
We're not talking rocket science. You want to use the magic "e" word? If it makes you feel better, you do that. Don't expect great miracles, but use it. Go on.
The point I have made, now and always before, is to handle the situation by whatever means is necessary. If that means using the magic "e" word, then go for it. You know you want to.
Don't forget the lights and sirens. Not only are they pretty at night, they look cool. Right?
if something happens in the aircraft that's got you so busy that you dont have time to talk on the radios on your way back to the airport... its probably an emergency... either that or you're flying an airplane thats too much for you to handle and you're probably an emergency in that case as well.
A couple of comments;
As someone else noted, a Controller or Supervisor can decide to declare an emergency and roll the ARFF trucks whether you asked or not. When in doubt, that's just what we'll do.
The ARFF guys really don't mind the practice, and let's all hope that's really what it is.
Whether you use the "E" word or not, LOTS of pilots are LOUSY at telling ATC what we can do to help. Being a pilot, I know that loosing a vacuum pump can be critical in IMC, and a real ho-hum in good VMC. Most controllers are not pilots. Some won't know how serious the situation is. If you ASK, or TELL the controller what you need, they'll normally do their best to accomodate. Don't let the controller pick the runway you get, tell them which one you NEED. On the other hand, controllers can often suggest options you hadn't considered. Perhaps a private runway nearby, an airport with better WX, whatever.
DO NOT worry about a bunch of paperwork. The FAA is normally only going to need paperwork if substantial damage was involved, a runway was shut down for some time, or a loss of separation or some such occurred. If everything works out OK, we seldom ask for any. We may need to ask for some details to forward to the Command Center, and to answer media inquiries, but it will be very general and limited.
