flynryan15
- Oct 27, 2003
Just curious does the Q400 have a trend vector on the air speed tape?
Thanks for the link. Does the real q400 has glass pfd like the one shown in the video? How about autothrottle? AOA indicator?
Everytime I watch one of these, it just reminds me that we're all vulnerable at one point of our career...
Yes, it does.
Everybody here is missing the real point. DONT STALL!!! Its really not that hard. Stall recovery profiles should NEVER be used on the line because you should NEVER unintentionally stall an aircraft...
Colgan FO:
22:16:26.6
HOT-2
uhhh.
The stick shaker started about a second later. You think she saw something?
There is no single cause for an accident, but a bunch of links coming together to form the chain.
Actually, it looks like flaps 10 according to the FDR based animation. That is also consistent with what has been stated as Colgan procedure to stop at intermediate increments like flaps 10 prior to flaps 15.Actually they were at flaps 15:
22:16:23.5
HOT-1 flaps fifteen before landing checklist.
22:16:26.0
CAM [sound similar to flap handle movement]
If pilot error is to blame, it is the training program that should be primarily blamed. Stall profiles at airlines need to be changed. And not to mention, fatiuge and scheduling rules need to be changed, but the FAA will not give a rats as$ when power airline lobbyists use their "pressure."
Raise your hand if you've been taught by a Part 121 airline during the stall recovery section of simulator training to not lose altitude at all costs, no matter how long you keep it in the shaker, how much you ride the barber pole, and how close you get to a pusher.
"Don't let the nose drop!"
If you do max power and IMMEDIATELY lower the nose, the shaker will stop, and that is not what we were taught in the sim.Why is the training program to be blamed? All my training from private to 121 has taught the same type of recovery from a stall. Lower nose, increase airspeed, pitch up when sufficient airflow over wings, and level off and clean it up at previous altitude.
You would had you perceived it to be a tailplane icing stall.I know my 121 training didn't tell me to pitch up to 31 degrees at full power with airspeed decaying...
