whymeworry?
- Sep 17, 2005
Yes it dose. I think they waited to long to advance the thrust levers.Forgive my ignorance, but does manually advancing the power levers over-ride the AT's in any way, even temporarily? Seems like it should be designed that way just in case.
And I think you're talking out of your ass because you don't have a clue what happened on that airplane. Why are some of you so quick to throw fellow pilots under the bus?Yes it dose. I think they waited to long to advance the thrust levers.
If the power dropped off line and there was no power to operate the Autothrottle System, then how could they advance forward to command more power as the pilots described? Unless the engines still provided enough rotation to maintain residual power to every thing. If that was the case then why did and of passengers notice the emergency lighting come on before impact?
Typically, if there is total electrical power failure on an aircraft with FADEC controlled engines, the engines are designed to operate at a certain speed...I can't think of the correct terminology at the moment as I only have 1 eye half open and trying to get the coffee going.If the power dropped off line and there was no power to operate the Autothrottle System, then how could they advance forward to command more power as the pilots described? Unless the engines still provided enough rotation to maintain residual power to every thing. If that was the case then why did and of passengers notice the emergency lighting come on before impact? The passengers interviewed claimed every was normal till impact. Some thought it was just a very hard landing.
SG
Cardinal;1498233Incidentally said:against[/I] stabilized approaches.
Well, usually when there's a crash and no fire = no gas.
1. They landed it on wet rain soaked grass = not a lot of sparks
2. In a fuel starvation incident, it is astronomically unlikely that BOTH engines would quit at the EXACT same time.
3. Lots of talk about the APU, did it actually start?
The right wing was nearly ripped off? No fuel spillage? Hmmmmm.
Really?
From BBC Website:
"A significant amount of fuel leaked from the aircraft but there was no fire"
http://news.bbc.co.uk/2/hi/uk_news/england/london/7197506.stm
Ok... Is the BBC reporter a reliable source on aviation technicalities? How much did they actually say?
If that much fuel spilled on the grass those tree hugging Brits would be acting like the Exxon Valdez just parked at Heathrow. Yet you see no large containment or cleanup efforts.
No I didn't say a GEN was deffered, I gave a possible reason for why the APU door was opened as you pointed out.You don't know much about systems do you? Are you a pilot? I'm starting to think you are a poser![]()
Generators stay on line at an N2 setting just bellow ground idle, they will not come off line until the N2's drop bellow this %of N2 wich is much lower than the flight idle setting. If the engines quit, the generators would have being powering the A/T system and the drop of N2 would signal the A/T to add power.(the engines are dead but during this period while the N2's are droping, there is still AC power on the A/C) Once the N2 would drop bellow the ground idle setting (well bellow the flight idle setting.) at that point is when the emergency lights would come on and the APU autostart would kick in.
So now the Gen was deffered Hum?
Lack of fuel Very unlikely. A BA source says the plane landed with more than ten tonnes of fuel, more than normal after a 12-hour flight.
I'm watching a live feed from BBC, over here.
Evidently the BA Flt declared an emergency then turned toward the runway.
There is a lot of spectator eyewitness BS being spread right now, and no facts as of yet.
BBC is now interviewing a BA Captain, and he says this just doesn't happen to British pilots. Therefore, it must be a severe damage emergency or windshear or geese ingestion into the engines to cause the airplane to have a problem prior to touchdown. He said at least three times, "This just doesn't happen to British pilots. We are well trained. It had to be an aeroplane or weather problem."
Also curious to see if there are any BS lawsuits like in the states here that come out of this.
It had 10 tonnes of fuel on board. The report does not state how much of that fuel leaked but some of it did.
You seem to have an issue with British people, why is that?
The aircraft is subject to an investigation so once that is complete I'm sure they will clean up the sight.
I think you will find that there are many more "tree huggers" here in the US than in all of the UK.
My dad used to say "engage brain before placing mouth into gear"
Good advice for you.
I see you edited your post to make it even nastier.
I was just busting your balls, but if you want to take it personally, go for it. Apparently the stiff upper lip fades when you come over here and associate with us Yanks. I see you have an ex ValuJet plane as your avitar. Work for Citrus? Couldn't get on with BA eh? Sorry to hear that.
You're ragging on an AirTran guy about not being able to get hired at another company while you're a lifer at ASA?
Pot, meet Kettle.
