Anderson to align capacity with demand
15% schedule reduction? wtf? You're spending less time in Africa is putting a damper on my offshore drilling expeditions with your wife. Guess I might as well buy a moped. <sigh>
Yet ANOTHER classic. Someone PLEASE start a Cobra17 Library of his fantastic insight prose. This guy is GONNA be somebody, someday.....
Bye Bye--General Lee
And, a pre-SOC AE is NOT on the table. The Dalpa reps in the ATL lounge said they would never agree to that, since it is a concession. Do you think our LEC and MEC members from the South want to be bumped down any sooner than they have to? Sorry, but we out number you still. Nobody on our side of the fence wants to be bumped earlier.
I am going to have to disagree with you on this one.......it is NOT a concession but a forecasting tool. How would this be a concession when there will be a system wide bid with SOC anyway?
Anything done PRE-SOC with the willingness of Dalpa would be a concession (joint AE with 742s involved--which will go away pre-soc). IF it saves the company money, (and the company wants it), it would be a concession. Anything that affects one side (parking of the 742s) pre-SOC---has to affect ONLY that side. (due to SLI binding arbitration) Do you think the company would have a large AE pre-SOC and leave the 742 stuff out? Highly doubtful. After SOC, there could be a large bid, no doubt. But, the company will dump the 742s prior to SOC (to save from getting FAA approval on training programs, checklists, etc for that 742), and that portion cannot be used on a joint AE bid. That is my point. Not one guy can be dumped from the 742 prior to SOC and bid any Delta-S equipment due to that displacement. Those 742 guys will have to bid down (or up to 744), resulting in bumps all the way down the line, and then after SOC try to bid over to Delta S if they want. But, training will have to result, and it will be costly. No shortcuts. If they do it prior, they would be breaking the binding arbitration results.
A quick LOA will take care of that:) However, I want to see how much displacing there will be on the Southside. You can bet your ass LM will push for a LOA if the Southies are going to get hammered and vice versa if just the North. We will know in about 6-8 weeks.
The South is going to get hammered in 6-8 weeks or six months. As I stated before when the surplus the North seats in the northern bases, and add them to ATL they will not need to follow the seat. They will bid what they want.
There are no real seat protections with the movement that will be going on in the next two years.
Saving your and my six for six months is hardly worth the cost for DALPA or the company.
****Think right now there would be more surplussing going on on the south than the north, so you may some protections in that.
easy
I'll bet it wouldn't...I'd bet you hold NO union position or ACTIVELY, regularly serve...
I also bet if anyone posts anything remotely related to your airline at 4am you'll answer right then
Dude you're barking up the wrong tree. ACL provides some pretty reliable info and reasonable posts.
GL-
I personally don't care one way or another, but my understanding is the arbitration addressed furloughs, not displacements. Again, I'm not interested in defending the NERD position on this issue as the joint displacements will happen post SOC either way. First joint AE should be fun as NERDs tend to bid big equip if it's available.
Schwanker
GL-
Schwanker
Great, if there are AEs that means only the positions that are available. If there are displacements, then that is another story. The SLI award stated the parking of any planes will AFFECT that side, and I think that means furloughs or displacements. Regardless, if you are senior, you will do alright.
It would be a little of both. AE positions and surplus positions. The trick is to make sure that the surplus positions are not greater than the AE. If that is the case we will have a problem Houston!
You already have a problem-Houston.. It is called NWA lackeys. They are stacked on your board, they are running all the upper-level positions nowadays.. The problem is: with a board stacked that deep with these clowns, it will be damn tough to get a change in leadership whenever people figure out how deeply in trouble you are!
Every company has issues these days, but at least most airlines have not just been 'jacked by the kind of scumbags who ran NWA!
Get a life you reject and worry about where you work and not where you got turned down.
There is not going to be a system wide rebid after SOC. Pre SOC's displacements will be handled in accordance with the PWA. If there are displacements pre SOC you displace to your respective pre merger fleets, if there are displacements post SOC you can displace to whichever category your seniority can hold with the exception of the growing 777 fleet for the FNWA pilots and 747 fleet for the FDAL pilots.
So do RDs, proportionally there are more RD's on the top of the list than NERDs.
But not in the same proportion of big equipment brought to the merger.
The pull and plug method of crediting future attrition on day one gives the NWA guys seniority above the equipment (and presumably bases) that they are currently working in.
Sure there might be more RD's on the top, but there were more to begin with. No one I've heard (or read) is worried about RD's bidding NWA equipment.
The real shame is that the displacements on the South side are already forcing South pilots out of the 767 as the North's aircraft are redeployed on Southern routes where more demand for their underutilized capacity exists. Back a couple of years ago when I observed NWA's load factor was shrinking on reduced capacity I posted that management would surely want to shift NWA's underutilized equipment to the south where both demand wa growing on increased capacity.
Although NWA had cash, the trend vector was negative. Delta had a positive trend vector, but not much cash. The merger made sense from a management standpoint and was good for NWA employees. If there is any silver lining for Delta employees I have not seen it yet. Maybe it will be evident in 5 years.
And next month I'll be flying a 767ER to NRTand GUM and do a CDG through MSP. It swings both ways. Displacements are being caused by a decrease in capacity system wide, not the fact that 330s are in ATL.
In a stove pipe new hires would never hold the 767ER, but due to the rapid expansion of international capacity and the dynamics of AEs there were wide bodied opportunities that otherwise wouldn't have existed but for the rapid expansion. The opposite is true during times of contraction. Post 9-11, with the decrease in capacity the category lists started to look much more like a stove pipe than during the preceding year when the company was rapidly expanding.
Key word system wide rebid.
There will be AE's/Surplus bids. About four to eight of them. You are correct in saying that not every seat will be up for bid.
I am just pointing out that what you are saying is a total rebid, not a shifting of many of the seats.
That's like saying had it not been for the large number of early outs at Delta you would not hold the seat that you hold.
It is what it is regardless of how it came to be.
Prior to SOC only. Those displacements off the 747-200 pre-SOC have no freeze, nor do those that get caught up in the waterfall displacements.
In short, it's a DAL-N problem only until SOC, and then it's everyone's problem. Again the logic for a pre-SOC position award, especially if there is an AE, will cause less impact than a far larger number of relatively senior unfrozen DAL-N displacee's. Never mind dispalcements, we will own a lot of AE and VD activity. I'm still betting on an early position bid....
