AA JFK crosswind emergency...
Closed and not in use are two different things. If the runways is closed for maintenance etc. it is not part of the air tranport system.
I agree. That's why I hypothetically asked:
What would you do if the runway you needed was simply closed and fuel was not an issue?
You'd divert and it wouldn't be an emergency, right?
Another hypothetical: What if AA was on final ILS 22 and instead of winds going above their crosswind, they had to go missed approach because of fog.
Should they declare an emergency and demand to be #1 for the ILS 31R?
If fuel was an issue, sure. Go ahead. If it wasn't and issue, you might divert or you might ask for vectors to 31R.
A few years back (probably similar today) at DAL, min fuel on the 767 was 7100 and emerg fuel was 5200. Among other things, we were required to declare min fuel any time the arrival fuel was estimated to be below the min fuel value. Min fuel was certainly not an emergency situation, but could easily lead to an emergency if not managed properly. I'm curious to know if the crew ever declared min or emergency fuel anywhere along the line...I'd like to hope they did and that it just wasn't a case of a pi$$ing match gone awry.
61 replies but no mention of what the big, scary crosswind actually was.
I guess they were the only 767 that flew into JFK that day, because all of the others would have crashed.
Stop the PIC chest beating. How about manning up and flying the aircraft.
who cares...if that crew declared an emergency...that's it. They get what ever they want!! Pic decision....end of discussion! Everyone who seconds guesses them shut up and learn what is means to be a pic! Nice job aa crew.
exactly! Nice job aa2 heavy!
How about when you've actually flown a jet with under-wing engines you come back and comment? For some jets or airlines' FOMs the x-wind number is a limitation, not a "demonstrated". Supposedly the gust was to 39 knots, which would exceed my crosswind limits as well.
it's 7300 & 5300 now at DAL (in the middle of TOE here)
Winds were reportedly 320@23G35, and I've read somewhere that the max crosswind (demonstrated) @ AA in the 767 is 29kts.
How's that quote about using one's superior judgment to prevent a demonstration of superior airmanship go again?
If there wasn't a fuel issue these pilots deserve to have their tickets pulled......
He initially disregarded the commands of ATC. He's demanding ATC to clear the airspace for this supposed "EMERGENCY". I think the Feds should take a long look at this and consider all the chaos in the traffic flow these guys caused because they felt they had an issue with ATC
In order to keep the discussion going, I am going to DISAGREE with the AA crew, however this does not mean I am claiming ATC was not out of line either. However, simply from the AA crew, my observations:
Sec. 91.3
Responsibility and authority of the pilot in command.
(a) The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft.
(b) In an in-flight emergency requiring immediate action, the pilot in command may deviate from any rule of this part to the extent required to meet that emergency.
(c) Each pilot in command who deviates from a rule under paragraph (b) of this section shall, upon the request of the Administrator, send a written report of that deviation to the Administrator.
If they had low fuel due to unforecast headwinds, etc etc, or similar situation, ok, but I do not understand declaring an emergency because they could not get the runway needed. This is where ATC must be held accountable, but delcaring an emergency by the crew?
In training and in real life I associate the word itself, and the use of the word on the radio for "Life, Death, Serious Injury/Harm depends on my declaring this (as an emergency)."
This would be (amongst others)
- Low Fuel
- Heart Attack on board
- Baby birth on board/possible complications
- Equipment/Mechanical/etc malfunction, failure, etc
- Crew member incapacitation, etc
- Etc Issues
I personally would not consider a my-d1ck-is-bigger-than-yours war of words with ATC to justify declaring an emergency. I would pick up my toys and go to the alternate, and document the incident for follow up action.
http://www.faa.gov/air_traffic/publications/ATpubs/AIM/Chap6/aim0601.html#6-1-1
6-1-1. Pilot Responsibility and Authority
a. The pilot-in-command of an aircraft is directly responsible for and is the final authority as to the operation of that aircraft. In an emergency requiring immediate action, the pilot-in-command may deviate from any rule in 14 CFR Part 91, Subpart A, General, and Subpart B, Flight Rules, to the extent required to meet that emergency.
REFERENCE-
14 CFR Section 91.3(b).
b. If the emergency authority of 14 CFR Section 91.3(b) is used to deviate from the provisions of an ATC clearance, the pilot-in-command must notify ATC as soon as possible and obtain an amended clearance.
c. Unless deviation is necessary under the emergency authority of 14 CFR Section 91.3, pilots of IFR flights experiencing two-way radio communications failure are expected to adhere to the procedures prescribed under "IFR operations, two-way radio communications failure."
REFERENCE-
14 CFR Section 91.185.
6-1-2. Emergency Condition- Request Assistance Immediately
a. An emergency can be either a distress or urgency condition as defined in the Pilot/Controller Glossary. Pilots do not hesitate to declare an emergency when they are faced with distress conditions such as fire, mechanical failure, or structural damage. However, some are reluctant to report an urgency condition when they encounter situations which may not be immediately perilous, but are potentially catastrophic. An aircraft is in at least an urgency condition the moment the pilot becomes doubtful about position, fuel endurance, weather, or any other condition that could adversely affect flight safety. This is the time to ask for help, not after the situation has developed into a distress condition.
b. Pilots who become apprehensive for their safety for any reason should request assistance immediately. Ready and willing help is available in the form of radio, radar, direction finding stations and other aircraft. Delay has caused accidents and cost lives. Safety is not a luxury! Take action!
http://www.faa.gov/air_traffic/publications/ATPubs/PCG/D.HTM
DISTRESS- A condition of being threatened by serious and/or imminent danger and of requiring immediate assistance.
http://www.faa.gov/air_traffic/publications/ATPubs/PCG/U.HTM
URGENCY- A condition of being concerned about safety and of requiring timely but not immediate assistance; a potential distress condition.
Unless someone can convince me otherwise (and I am open to it...), I don't see the justification to claim the emergency flag on this ATC exchange.
AGAIN: I am making no validations of ATC, they were wrong too. But the AA crew wasn't right either, not that I can see.
"PIC AUTHORITY" is not an automatic pass to "do what you want". It means the PIC as a professional has the authority to make decisions as appropriate, safe, and legal, per industry and professional standards. PIC AUTHORITY does not green light you to say "Fire" in a dark movie theater.
Further note that at no point am I claiming that the crew are "jerks" or "morons" or similar language. I am sure they are good guys and very capable pilots.
I am simply saying that based on my (little) knowledge (NOTE: self admitted little knowledge !) of the situation, my OPINION is the use of the emergency word was not appropriate.
It sounds like weather was fine but windy since they declared emergency and then said they were on a visual. Impossible to know if they did any holding for flow into JFK prior to landing clearence. Does AA dispatch airplanes that show up at destination on emergency fuel? Doubtful. He didnt declare minimum fuel or it happened at a time frame prior to released audio. At first it sounded like he accepted landing clearence on 22 then came back and said he couldnt take it. So why accept it in the first place? It sounded like he said that he WOULD declare emergency if NOT allowed a runway change. Did they determine what runway they needed when they retrieved ATIS info? If so, did they relay that info to approach controller so that he could coordinate? Did he request it with tower when he made initial contact? It sounded like a last minute decision by the sky nazis and then they got pissy when controller was trying to verify intentions and communication. Telling him to fly RH allows him to keep the 767 from trading paint with all the other aircraft that just might be around some of the busiest airspace in the country. How dare he. Just because he declared an emergency doesnt mean he should fly off willy nilly in congested airspace unless the airworthiness of the aircraft is very questionable. If he had a fuel issue then that is something that should have been monitored and dealt with long before he was on final approach to a runway he knew he couldnt accept. From the tapes the controller didnt do anything wrong. He confirmed what the pilot wanted and then let him have it. He didnt argue with the guy. He was just trying to make sure that he flew a direction that would keep all planes safe. He has a better idea of what is around than the pilot. There is a lot more to this story and it would be nice to hear it all but from what is heard it sounds more like the pilots got behind and then had to deal with it from a bad position. PIC authorization to declare emergency and get carte blanche exists because the PIC knows better than anyone on ground his ability to keep aircraft flying, however, it doesnt mean it is a VIP membership cause your panties are twisted. Coming from the west he had a dozen airports to land a 767 on if his plane was in danger before getting to JFK. I usually get ATIS of ACARS no less than 100 miles out unless it is about to change and I want new info. Those winds didnt just happen they were blowing all day. I live in NY. It has been windy for a week. Windy right now. Actually, I dont give a sh** what happened. I just like rambling at times.
According to Flightaware, they held some....maybe 30 minutes worth.
Regardless, if it was a fuel issue, they should have known this in the hold and passed the word to center so they could inform approach and tower.
Instead, they had to play "My d*ck is bigger than yours"
link to center and approach recordings?
If you fly long enough you will get in a situation where you are holding and know fuel to the alternate is the same as to destination. I have been in it a few times and knew the problems to alternate were the same as to destination so if I knew my line up and the wx to destination was ok I would burn into alternate fuel because it was safer than diverting at that point. They knew it was VFR and were in the lineup so continued to JFK. On short final they were told the wind was now beyond their crosswind limits so they must have felt their fuel situation would cause an emergency situation being sequenced back for another landing. Notice the gust info was not transmitted after their incident? I would like to see a wind readout with gusts before and after the incidents from the monitoring equipment, not from transmitted wind from tower.
They had a crew "man up and fly the aircraft" down in Kingston.
That worked out really well for them, didn't it?
The original poster included this link in the first post (1/61) of this thread. I guess you were too busy counting. In the future take a little extra time before unleashing Spontaneity, passing wind included. http://www.avweb.com/avwebflash/new...s_clearance_crosswind_emergency_202510-1.html
Did the crew ever state the nature of the emergency, once they actually declared? Or was it just ' get outta the way, we're coming in'???
"If you want 31 you are going to have to declare an emergency."
"Ok we are declaring an emergency."
Pretty obvious what the nature of the emergency was.
Some of you need to grow a pair and stop letting ATC run your cockpit.
Pretty clear? Yeah.
Tower: "AA, if you want to deviate from an ATC clearance, you'd better be having an emergency."
AA: "Fine, maybe we didn't say anything up to this point about any problems, but now we're an emergency aircraft. All your airspace are belong to us."
Grow a pair? Funny, sorry, but I have over 18,000 safe flight hours AA73, what it takes is a brain, and at least a basic understanding of the big picture.
If they would have properly declared an emergency, ATC would then request "what is the nature of your emergency?"
What is even more pathetic about this is the FAA has essentially mandated that we, as a PIC, must declare an emergency to use the safest, most appropriate runway for a particular operation. Have I got that right?
Pathetic that you would even ask such a stupid question. Are you for real?
The FAA would have eviscerated the crew if they had attempted a crosswind landing, beyond their company limitations, and had struck a pylon/tip when a perfectly good piece of concrete pointing into the wind was right there.
I guarantee in the post-incident investigation, the local controllers would have said "31R would have been available had you just asked for it".
That wouldn't appear to be the case here. I think it's pretty clear ATC indicated an emergency needed to be declared.
And before Jaun gets his panties in a wad, are you reading something different. JFK should have been using 31 for landing ops. Shouldn't take an emergency to get the runway you want! geez.
BUT, we don't even know what the emergency was, or if there even WAS an emergency.
Think about it. ATC said if you want 31 you need to declare. OK, so they declared....
Allright, whats the nature....Uhhh...well, we don't have an emergency...but you told us we had to declare to use the runway of our choice...
OK, so if THAT is really what is going on, then the comments by the flight crew and their actions of 'we're bringing her in folks, get out of the way, sure seems a bit odd, wouldn't you agree?
Why wouldn't you simply follow ATC instructions, take the hand-off and get in line for that runway, right?
What are we missing here? Can't believe we haven't had an AA'er chime in with some more scoop.
There ya go an AA'er...
I cant believe some of the crap pilots are saying about another pilot USING his AUTHORITY to DECLARE an Emergency.
READ THE FRIGIN FAR.
If anybody is PUSHING YOUR "TIN" YOU LET THEM
At least in the "good old days" pilots HAD a set of BALLS ..
More than a few clowns here remind me of the SwissAir MD11 Captain delaying his emergency descent and landing while asking Moncton ATC if it was OK to dump fuel. He probably reconsidered his delay after the plastic ceiling panels started dripping on his forehead.
JFK Tower knew damn well what the problem was, which is exactly why he didn't ask and properly prioritized his tasks to handle the other traffic.
He also acted like a little "beetch" with his attitude while directing the guy to ground control. He knew he been had and there was nothing he could do about it.
Face it fellas' . ATC is a great bunch, but in the last 10 years, there has been more smart ass prick attitudes slowly creeping into daily ops. It's still miniscule in the big picture, but starting to show up.
THEY DID ask for it, after the controller told them "to get 31R you will have to declare an emergency."
...yes, I know - I'm supporting your colleagues' decision.
My point was if they hadn't asked, and had an incident while attempting to land beyond their crosswind limitations, I'm sure the local controllers would claim in the investigation that it would have been available if only they had asked for it.
Have more details been released yet? More tape? I hadn't heard tape where the controller said they had to declare an emergency to get 31... You'd think by now that more tape and details would be out
