Union coming at Flexjet!
We don't do training at flexjet. We do flight checks. You don't get any training unless you fail and that's only if the TRB says your worthy of training. Food for thought.
Sorry Bunman but I'll have to call BS on that. Everyone who busted got another chance. Some even got two. And realize to bust a 135 check you have to screw up 2-3 events. By the time someone busts, they earn it. No saying it is right, just stating the facts.
Bunman,
What do you call the simulator time the night before the checkride? How about the 4 days of ground training during your long recurrent? The FAA considers that training, not sure what your definition is.
You are also incorrect on the TRB. The TRB doesn't have the authority to give training. The TRB gives a recommendation to DG who makes the decision regarding additional training. This is usually re-qualification training, not the same as the training you are saying we are lacking.
If you want to scare our pilots into a union, at least use facts not myths. You lose credibility every time you post something that is so far from the truth.
TWA 2 ASA FO
ok so if it isn't right then what is it? I can tell you this; turning the FD off on a single engine approach is BS!
Bunman,
TWA 2 ASA FO
The sim the night before the flight check is a practice flight check. When is the last time you had any failures similar to what you had on your type ride? This is what i'm refering to. Not ground training. If you read my second post, you would see i just said their is serious room for improvement and there is. Clearly a nerve is struck here with you. Also, why does only one person have control over ones employment in regards to training rather than your committee who actually still flies the line? I'm Not trying to scare anybody into the union because I don't have to. You guys are doing it all by yourselves. Convince me your training is above and beyond industry standard. If your under the delusion everything is fine in the TC and no changes are needed, then maybe your not the guy for the job. Just sayin.
For Bunman and Jetmaster, the 2 checkrides given each year are ALMOST 100% driven by FAA requirements for these checkrides ie 2 precision and 2 non-precision approaches, single-enginge approach, etc. It is spelled out in FAA documents. If someone goes into the training center and wants nothing but practice on, say V1 cuts, I imagine the instructors would accommodate this wish as long as the student realized that his 2nd ride would be the normal checkride (and without the benefit of having practiced anything other than the V1 cuts that he(she) requested. The only manuever I am aware of that is not FAA-driven is the raw date approach, which is DO driven. And if Mr. Jetmaster727 is so afraid of flying the plane without a FD, he probably should try another profession...these FD's do fail occasionally, and having practiced in the Sim for such an event is the exact training I would want to have practiced.
WL
Uh, Brokeflyer, we don't have a union(otherwise, it would be it's fault). that's supposed to be a joke for all you humour-challenged folks.
WL
PS, yea, I know it's coming blah blah blah.
WL
If not FAA required then why do it? This is the problem with you guys; when someone makes a valid point you get all defensive and attack the person. I'm
hardly afraid of flying without the FD as I have been doing this for a long time. I mean according to your logic, we should shut down both engines because it could happen, right?
I would seriously question the judgement of a captain who continues to an airport on one engine with the weather at mins and no FD. But what do I know, I've only been flying transport cat airplanes for over 20 years!
Actually Jetmaster it ,the raw data approach, is in the ATP PTS with this caveat:
"NOTE: Two precision approaches, utilizing NAVAID equipment for
centerline and glideslope guidance, must be accomplished in
simulated or actual instrument conditions to DA/DH. At least one
approach must be flown manually without the use of an autopilot.
The second approach may be flown via the autopilot, if appropriate,
and if the DA/DH altitude does not violate the authorized minimum
altitude for autopilot operation. Manually flown precision approaches
may use raw data displays or may be flight director assisted, at the
discretion of the examiner.
If the aircraft is equipped with advanced flight instrument displays,
the raw data approach should be flown by reference to the backup
instrumentation as much as is possible with the airplane’s
configuration.
For multiengine airplanes at least one manually controlled precision
approach must be accomplished with a simulated failure of one
powerplant."
http://www.faa.gov/training_testing/testing/airmen/test_standards/pilot/media/FAA-S-8081-5F.pdf
Page 61 of the ATP PTS PDF. I don't know about you, but I would rather fly without a flight director instead of peanut gyros. We don't make this stuff up. As far as a single engine raw data approach, take it up with the 135 certificate holder's D.O. they require this, not Flexjet.
So your attacks now become personal because you don't like the response given. Sorry I respond to your post with logic and facts. Is that iceberg still "dead ahead"?
Since you seem to think you have a greater understanding of what we should be doing at the training center, please give us some honest suggestions that are workable under the FAR's we operate. We are always open to suggestions on ways to improve "your" training experience.
TWA 2 ASA FO
After seeing both the Flex training and the Bombardier instructors training , give me the guys at flex any day. (now I have offended the Bombardier instructors, so my next recurrent is going to be an adventure).
But out of my last 4 Bombardier based training events, I feel I am actually going backward in standards each time, the standards seem really lax on the other side of the fence, and as for the ground school, its really day and night, what you learn and have to memorize at flex I feel does make you a better pilot than what you do for the 135 world under Bombardier training .
The only "one person" that controls the destiny of ones employment is YOU. If a pilot goes to a TRB (the commitee, which has line pilot representation, that you seem to disregard) makes a recommendation. I have never seen anyone not recieve more training. In fact the only time DG over rode the recommendation was when the TRB recommended a person be removed from training. He asked the pilot what they thought they needed. That pilot stated she could take her check right now and pass without any problems. She subsequently failed her checkride in stellar fashion and was terminated. So there is one person in control of your employment BUNMAN, and that person is you!
FAA Doc. 8900.1 - Check Airman Handbook -VOL 5 Airman Certification ATP. Chapter 3 Sect 2 paragraph 5-832 APPROACH EVENTS. Sub-paragraph A. 2)
If the operator’s aircraft operating manual permits raw data ILS approaches to be conducted, the operator must provide training in the use of raw data for controlling an aircraft during ILS approaches. If the operator’s aircraft are equipped with a flight director system, the flight director must be used on at least one manually controlled ILS approach. While a raw data approach is not required to complete a flight test, inspectors and examiners should occasionally require a raw data approach to determine whether the operator’s training program is adequately preparing applicants.
When raw data is used on ILS or MLS approaches in an airplane, inspectors and examiners shall require applicants to use a DH of 200 feet above the touchdown zone.
To be fair to everyone, we don't discriminate. Everyone gets to do it. I would question having to fly with someone who was unable to do it and was too insecure in his or her own abilities to get it done. Its not always a matter of judgement, that may be your only choice. We train for the worst case scenario, not what actually happens day to day. If that were the case, we'd sit standby in the customer lounge and save on the sim expense.
Is that point valid enough for you? Do you feel attacked still? Those training guys are so out of control!!!! Help us IBT!!!! HELP US!!!!!
Look at all the office boys and girls coming out of the woodwork. Must be serious. Or hired bloggers.
Merely stating the facts. I keep hearing and reading nonsense. I figured it was time to actually get on here and see what all the fuss was about. Clearly, the assumptions are just that. You want your voice heard? So do I. You have a campaign to start a union at flexjet based on rumor and paranoia. I will post what the reality is. The pilots can make their decision based on fact rather than the trash you continue to spew.
TWA 2 ASA FO
James,
Feel free to post all of the private messages i've sent you. Thats fine because i'm not affraid of expressing my opinion. As always, feel free to call me on the number i sent you and we can discuss how to improve "MY" training experience. Take Care.
You guys' are getting way too wrapped around the axle with regards to these alleged and so called in-justices that have been taking place in the past and supposedly present during training at Flexjet. First of all, the dreaded Raw Data Single Engine ILS!
This particular item that I am aware of has NEVER been the single cause for a TRB or a termination from this company. Period! Don't believe me? Call and talk to the Supervisor of Cockpit Training and ask. They track this stuff and you could always look at a specific individuals training record and see what they've had trouble with in the past. This item was never the smoking gun, it was always something much, much more.
I don't know of a single instructor who requires it during an Initial Type Checkride, I know I never did. Sure I had the students do it during training, numerous times. Its a great tool to develop or improve their scan and is also a great confidence builder. It also was a great indicator of who and who wasn't going to be a challenge, but for a Type Check the single engine precision approach was always done with the flight director and the Raw data approach with 2 engines. Usually by the time their type ride came around, it was a non event.
Now recurrent is a different story. Sure we all do our engine out approaches raw data, so what? is it required by the FAA? No. but what's wrong with training and flying to a higher standard? I'll say it again one last time: The Single Engine Raw Data ILS is not the reason guy's and gal's have failed training and lost their jobs. It has been for much, much more than just that one item.
I'll end by saying that those individuals that I have personally seen fail and go through the TRB process were treated more than fairly and given more than enough attention and additional training. They simply could not perform to the standards set forth, Not Flexjet's standards, I'm talking about the PTS standards as prescribed by the FAA. And those of you out there who are complaining about having to turn off the Flight Director during your single engine precision approach, I'd be willing to bet that if your truly honest with yourself, that's probably not the only thing you have problems with.
We don't need a union to protect those who can't perform satisfactorily, the system we have has done just fine so far, we need a Union for a lot more important things.
Finally an educated post. I would be very interested to know what the "more important things" are. I haven't seen a valid reason for a union anywhere.
I guess I would answer your question with a question. What do you think needs changed or what would you like to see changed? Anything? If so, do you feel the current voice of the crewmembers, the FOFG can or will get it changed? If you feel they can then simply vote no, if not then what other avenue do we have?
I would also suggest signing up and asking this and any other questions on the Flexjet IBT website forum.
Yes "the pilots" will decide. I realize it's hard to stay in character while sitting in a cubicle, but try harder. Maybe spend some time on a sports message board and try to pick up on the intricacies of trolling.
I believe that anything that should or needs to be changed can be done without union representation. We haven't needed it up to this point. Why do we need it now? If you or anyone is not satisfied with the FOFG or the results that have come from the FOFG then you have every right to bypass it and go straight to the top with your concerns. The management we have has always been willing to visit with any one individual or group to entertain new ideas and address any concerns. This should not be an us against them situation. We're all part of the same team. We all have a vested interest, management included. Everyones bottom line relies on a collective effort. If you feel any one individual, or group of individuals, isn't doing their part, then you have a responsibility to yourself, and the rest of the team to say something. I'm my own union rep.
I don't need to stay in character. "The Pilots" includes me too. I fly the line just as much if not more than you. So if you think you have the market cornered on convincing the rest of us that your opinions and conspiracy theories have any merit, I'd say don't quit your day job.
To dirtybeech and Bun-Man (any relation to the hamburgler)- your posts on here lack any type of sincerity or fact. You are not even close to being the type of individuals anyone would want to be represented by. However I embrace your positions of ignorance, for the simple pleasures of watching your movement die because of your own sophomoric behavior. Who in their right mind would hold their head high with you clowns even in the rank and file.
I am also ashamed that you are a part of our company. A company that many of us have gone to great strides to make it what it is today. A company that many of us have been a part of when you were still teaching terrorists how to fly 152's. I remember what it was like at my previous employer. I remember how this place was long before you jokers darkened the doorsteps of OUR company. You have coasted in on our coattails to reap the benefits. YOURE WELCOME!!! You unappreciative, entitled, undeserving (insert expletive pro-noun here).
Sorry jetmaster727. I forgot to include you in that last one. You sir are also very welcome. On behalf of all the pilots who don't want to be a part of your secret squirrel handshake club- It was our pleasure to get you what you now have no appreciation for.
BTW- in any case you guys hand out satin jackets and secret decoder rings....count me in!!!
"I fly the line just as much if not more than you."
Why would a legitimate pilot feel the need to say something like this? And what does this statement mean, exactly? If I'm a line pilot and you're a line pilot, how can you fly the line more than me?
You're either a) someone from management masquerading as one of the guys or b) a Ford & Harrison troll, and a pretty sorry one at that.
If this is what we're up against, I'm highly encouraged.
In response to your buddy's claim that I was not a pilot and having to pretend from a cubicle.
If I have to point out the obvious to you, then I too am highly encouraged.
