ksu_aviator
GO CATS
- Dec 1, 2001
Capt. Renslow, 47, joined Colgan in September 2005 after graduating from a pilot-training academy, employment records show. He had a history of flunking check rides -- periodic tests of competency that are also required anytime a pilot begins flying a new type of aircraft. Before joining Colgan, he failed three proficiency checks on general aviation aircraft administered by the FAA, according to investigators and the airline.
It sounds to me like the captain hit his early 40's, enrolled in a flight academy with a bridge program to Colgan and upgraded into the Q400 with barely 100 hours in the airframe. Yikes. To top it off, he failed 5 rides along the way.
GA busts are too subjective to be counted on as proper examination of an applicant. Some DE's are in for the busts and the money. Total conflict of interest.
121 rides are way more indicative of a pilot's skill than those GA rides.
True but if he failed three at the GA level, then he must have failed two at Colgan. That kind of pattern leads me to believe he should have seriously contemplated a different career change. As said a few posts above, not everybody is cut out for this job, no matter how much money they have to throw at it.
5 busted rides, you get 5 re-trains and 5 do-overs. 1 bad bust in real life, you, your passengers and crew end up dead. Of course pilots with perfect records can do the same thing, and everybody can have a bad day in the box, but given this info, these failures cannot be dismissed as contributing factors.
http://www.msnbc.msn.com/id/30683954/
"The newspaper found that Renslow had failed in his first attempt to qualify as a co-pilot in the Beech-1900 aircraft and he had to re-do his check-ride to upgrade to captain of a Saab 340-TurboProp. Colgan's spokesman told the Journal that the company believes Renslow failed to fully disclose that poor performance when applying for a job."
Just passing on info at this point.
GA or not, 5 busts is absolutely unacceptable. Checkrides aren't hard to pass. They test to minimum standards. If you fail to meet minimum standards - 5 times, perhaps you aren't cut out to be a pilot, let alone a professional pilot.
Yeah, but even Yeager ran his P-51 off of the runway.
