So what's the story on this latest 400 flameout?
greygoose said:
Pamed
No plane is safe, if you are as worried as you look on your posts sell your share and stop flying. I could walk out my front door trip and hit my head on a rock and die.
I should take a poll on here and ask if I should stay in my house. I will get a ton of dumbass remarks saying to become a mole and never leave.
On top of that the Concorde went from the best aviaition safety records to the worst. All in one day it took, now something was done about this. It wasnt because of the incident but because of the aging fleet. Flying is by far safer then driving, yet there is still millions of more people that drive every day then fly.
Flying has become much safer with the advent of the turbine engine.It is a very, very dependable machine.The odds of a turbine engine failing are small. The odds of 2 turbine engines failing on the same aircraft at the same time are incredibly small.I am happy to fly in the Beechjet when the cause of the flame outs is found and fixed.With 5 duals in 2 years something is wrong with the aircraft.
As an ex 400 driver, my advise is to reduce power on one engine before the other for the descent. I never had one complaint from the passengers when I did this (it didn’t yaw noticeably). I don’t think that anyone at Raytheon has a true idea why this aircraft is prone to misbehaving like this.
Pamed19,
I'm aware of the July 2004, November 2005 and last month's dual flameouts in the Beechjet--when/where were the other two? Also, does anyone have an N-number for last month's Beechjet flameout (PM me if you don't want to respond publicly)? I still can't find anything about the latest incident in the FAA or NTSB accident/incident databases...
AeroBoy said:
Pamed19,
A 400a in Brazil was the first.Last summer a CitationII[same engines] in Alaska.It was reported.I have been told that the last incident has been wrapped into the ongoing investigation by the NTSB/FAA.I have no tail number for the last one. It was reported by a member of this forum who heard the mayday.The one in Brazil is anecdotal.
I saw this mentioned a few times and wanted to clear it up: The Citation II does NOT have the exact same engine as the Beechjet. The CII has the -4 series JT15D engine, and the BJ has the -5. While basically the same, they have MANY major differences including fan, fuel control and exhaust.
In comparing apples and apples, I would not mention the CII anymore and just focus on the BJ issues that we are all concerned about.
I would not be surprised at all if a major action is taken by the FAA in response to what appears to be a real and growing problem. I just hope it gets solved completely before the fleet gets grounded pending further investigation.
This is probably best for another thread, but bringing up the 747 and Airbus incidents you mentioned... very poor examples due to the circumstances surrounding those disasters. They have absolutely no relevance in this discussion whatsoever.
beechjetpilot1 said:
I would have to agree with you two.....however, our job is risk management. There is NO safe airplane, some are just safer than others and some are operated safer than others. I don't know why the beechjet is having these issues all of the sudden...it could be design, it could be operator error, it could be pilot error, it could be a mx procedure error...we just don't know and they are not telling us. Many aircraft have come up against issues over the years that wouldn't be considered un-safe aircraft:
747's Fuel pumps in the center tank ...TWA that blew up
737's Rudder problems
Airbus 300 Vertical Tail departed aircraft do to operator error and design
B-52 early models had tails that fell off in turbulence
......and many others
Who the heck is this guy joining the board just to post in this thread, and then to post this ridiculous drivel?
RossTwivel said:
What that says is "Thar ain't much arr up thar"
We could guess all day as to the cause of these flameouts and the fact they are recent occurancies, but consider this.
Maybe we are flying the airplanes higher than we used to. The price of fuel along with the 2,000 ft increments (RVSM) has caused us to fly higher and delay the descent a little longer requiring more power reduction for descent. Some engins have limitations on the amount of power reduction above a certain altitude. I like not below 85% above FL350.
Another point is the Core Lock was probably secondary to the engines quitting. Core lock is caused by pulling all the power off at a cold and high altitude.
So when you get a AFM revision adding a power reduction limitation then I can say "You see what I mean Verne" till then don't fly too high.
Good point.Certainly the engine in the CII appears to have less trouble.Do you have any thoughts on the cause?
I am as puzzled as the rest of us... but I have to agree that lack of Prist is seeming less likely.
I will tell you this, I am not going extended overwater unless it can be done under FL350 until this gets solved. And I am not talking about solved like TWA 800 or AA 961... still cant believe that guy referred to those two flights in reference to this issue.
"Just wait you will see" In the mean time running others down sure makes you seem smarter.
Dude, your first post to this entire messageboard was a copied lesson in atmospheric science that you pasted directly from Wikipedia and added nothing to.
Your second post was erroneous and condecending, offering little to the substance of this topic.
I am not trying to sound smarter. It just ticks me off a little that you show up out of nowhere to give us a remedial lesson in the science of how to fly a jet.
From today's AINalerts:
[FONT=Verdana, Arial, Helvetica, sans-serif] A Third Beechjet Flameout Under Investigation
On June 14, Beechjet 400A N440DS lost all power from both Pratt & Whitney Canada JT15D-5 engines while the airplane was in cruise flight at FL380 near Norfolk, Va. Unsure if they could remain clear of clouds, the pilots decided to turn on the engine anti-ice. They told the NTSB that they turned on the engines’ igniters and then retarded the power from 101.5 percent to 89.5 percent N1, but before they could reach up to turn on the anti-ice, both engines flamed out simultaneously. The left engine restarted on its own at about FL300 and the right engine restarted on its own at about FL240. Testing of the fuel that was drained from the airplane confirmed that icing inhibitor was present and in the correct concentration and that the fuel was jet-A. The NTSB is also investigating two previous Beechjet dual engine flameouts—on July 12, 2004, over the Gulf of Mexico and another on Nov. 28, 2005, near Jacksonville, Fla. Both of these aircraft were being operated by Flight Options. Investigations of all three incidents are ongoing.
[/FONT]
OK, back from FSI and here is what they told us...
In the ORF flameout, the crew did as prescribed and lowered power to about 89% N1 prior to turning on engine anti-ice, and the engines flamed out before they could get the anti-ice on. They did get one engine restarted in the descent.
Apparently, FLOPS and NJ are telling their crews to turn on engine anti-ice in ANY visible moisture, even high altitude ice crystals. The theory is that perhaps those wispy high altitude clouds that you sometimes don't even realize you are flying in, have ice crystals that are turning into water vapor when they enter the engine, then build up in the low compressor. When power is reduced, presto...flameout. The advice from FLOPS and NJ is that there is no lower limit to use engine anti-ice.
The only problem is this latest crew reduced power prior to turning on the engine anti-ice, as required by the airplane manual to preserve the cool air boundary in the combustion can to extend engine life. It was reported by someone in the class (not an Options pilot) that FLOPS is recommending to turn engine anti-ice on without lowering N1 first. That would solve the theoretical problem at the probable expense of long term engine reliability and against the Handbook recommendation from Pratt & Whitney. I do know that a careful pilot can turn on engine anti-ice and reduce power simultanously without raising N1. That probably still doesn't prevent the heat from burning up the combustion can. The other suggested action of turning on ignitors and boost pumps before reducing power at altitude could be useful. Another suggestion thrown around by FLOPS crews was reducing power on one engine at a time, so at least you do not suffer a dual simultaneous flameout.
The thing that really annoys me is that Raytheon says it is unable to comment on the incident because it is a "participant" in the investigation. That just sounds like a chickensh!t backdoor way to try to avoid additional liability risk. They should at least have a "best practice" procedure out there already. Mutiple dual flameouts under similar circumstances should warrant either an immediate response or an emergency AD grounding the fleet in my opinion.
Another consideration. Both engines that were restarted were not lit until about 14,000'. That implies temperatures above freezing. If this were to happen in an area where the surface temps are below freezing, a restart might be very unlikely.
There is an AFM amendment on its way that will "allow" the anti-ice to be turned on above 90%.......
Incidently, the 2nd flame out was an internal icing issue....."they" are working on a solution.....
