Response to JoeMerchant
surplus1 said:
I really don’t want to revitalize the old arguments. We’ve beaten the horse to death and neither one of us intends to change his position.
I would however say that, with the very able direction/assistance of the ALPA, the large network carriers have already proven beyond all doubt that they have not only failed to limit the employer’s ability to “outsource to the lowest bidder”, but have also numbered themselves among the very lowest of “bidders” for the very flying they were attempting to prevent. To paraphrase, never before have so few (ALPA leadership and network carrier leadership) done so little for so many (ALPA membership).
That is correct, I do believe that no pilot group “owns” its code or can control it. I did not fail to note that you quoted me earlier.
Perhaps if you would focus on controlling the allocation of your work as opposed to the Company’s “Code” you might have made some progress.
Whatever the union does with your “scope” is fine with me, as long as it does not use my “scope” as the means to achieve your bargaining objectives at my expense.
Sooner or later we will hopefully be able to prevent ALPA’s sponsorship of that modus operandi. If at that point you should decide to take your marbles and “move on”, I would not object. If you think we are “bidding against each other now”, just wait until your exodus is complete. It won’t be pretty.
Keep in mind that none of the “little people” have yet made an attempt to “bid” against you directly; they are busily bidding against each other. In contrast, at least 3-4 of you “network carriers” have been actively “bidding” against the little people. Your may win those bids today and you have, but your victory is Pyrrhic. There are no better examples than the now defunct MDA, the newly created Compass, your own contract and the new and improved AWA/AAA, excelled only by non-union JetBlue.
I congratulate you all on this brilliant “scope strategy”. What will you all “trade” next time you’re in the barrel?
Why would you even care old fool! You're retired, now back to the AARP, viagra and social security! If I wanted any crap out of you, I'd squeeze your head!
737
Wrong twice in just one sentence. DAL scope is well defined, if DAL could have, they would have outsourced Song flying to a much lower bidder, your beloved CMR. When it comes to underbidding DAL pilots, DAL management stated, in sworn testimony during the recent 1113 motion, that CMR pilots cost half as much as DAL pilots.
O.K., so you believe companies can outsource their code to whomever. Thanks for clarifying your position.
My work is flying DAL code flying in accordance with the mutually accepted terms of my union and my company.
So you have no problem with DAL pilots taking back all DAL code 70 seat flying, for example. That wouldn't be an issue with CMR "scope, since CMR scope doesn't and never has had any controlling language over the DL code. Thanks for clarifying your position.
It's really quite simple, the CMR pilots can negotiate whatever scope they can with their employer CMR, and DAL pilots can negotiate the same with their employer DAL. Fair enough Surplus.
FDJ2 said:
Your work is flying whatever DAL operates on the DAL certificate and nothing else. If you think you have the right to fly Air France aircraft because they use DAL "code" why don't you demand it from your Company and see how far you get?
You once had the opportunity to prevent all outsourcing and you chose to "sell" it back to the company. You weren't smart enought to figure out that once you did that, they would ask for more and more, which they have. And, when you didn't feel like giving more they would force you to, which they also have.
You opened the barn door and the horse is gone. Live with it.
The company owns its code and its flying. They give you what part of it they want to give you and nothing else. You can foam at the mouth all you want, that won't change a thing. You've been trying now to close the barn door for more than a decade and you haven't succeeded. Resistance is futile.
The outsourcing you created is here to stay as long as the company wants it to stay. If they really want more they will get more. If you don't like it you have one option; strike. You are free to make that decision in every Section 6; have at it.
That spin effort is less that what you're capable of; try again.
You have already been actively attempting to "take back" all the 70-seat flying ever since CMR initially ordered that aircraft - at a point in time (pre '96) when you did not even have an attempted prevention in your PWA. You have failed. Not only did you fail, it has increased from the feeble attempt to limited it to 57 airframes to the new limit of 200 and it's now up to 76-seats. When DAL decides they want it to go higher, it will.
In other words, your efforts at predatory "scope" are a failure. The same ALPA effort has failed at every other network carrier, consistently for more than 10 years. Your failure to acknowledge that reality is your problem, not mine.
When the ALPA decides to stop interfering with the collective bargaining process for the purpose of furthering your ambitions at our expense, then that will be fine; not before.
Hopefully, the courts will require the ALPA to represent fairly. IF they do, at that point you can make good on your threat to leave the ALPA.
As soon as you put that decision into effect, we will then be free to negotiate with whomever we please for whatever we please and so will you. Remember that; it may come in handy in the future.
As you say, it's really quite simple. I wish you luck.
No one messed with your scope. If you fly for ASA the scope says that all ASA flying (Ev code) will be flown by ASA pilots. If you fly for CMR, your scope section says that all CMR flying (OH code) will be flown by CMR pilots. Since there is no EV or OH code, no one has touched your scope section. CMR pilots fly the part of the DL code allocated to them, ASA pilots fly the DL code allocated to them, etc. No, the DAL piltos don't own the code, DAL does. But DAL must allocate it within the limits of the DALPA PWA.
And Joe STILL owes an apology to MW.
And Surplus is still the biggest dolt on this board. He is too old to see the truth, he invents his own "facts", then supports them with innuendo, methaphors and melodrama. Nothing of any substance.
Pay him no mind. Because he has no mind. Or very little left of it. One day, what IS left of it will go away, HE will go away, the RJDC suit which he so ardently supports (another sign of his dwindling reasoning) will go away, all his money will go away (a regional lifer couldn't have built much of a nest egg and he is squandering what is left of it on his meager retirement lifestyle and contributions to keep a hopeless lawsuit alive), and then he will cease to exist on this board since he will have nothing to talk about nor the means to do so.
It is nature's way.
Huh, what about the code flown by ASA pilots and transferred to SkyWest pilots to get around ASA's pilot contract?
The transfer of flying proves we have no scope. The direct, indefatigible, reason for that is ALPA National's actions, which were directed by the Delta MEC.
Let's not forget the sinking of the Titanic, which happened nearly 100 years ago....Also the fault of the DL MEC. :rolleyes: Your excuses are tiresome dude, and you should spend more time fighting the real enemy...Management!
737
Yes we do have scope. We have scope over the EV code. The code flown by ASA pilots that was tranferred to SKW pilots was DL code. I don't like it, but that's what happenes when you don't own the code that you fly. That's why I want to move on, because I think that there is more job security when you own the code that you fly.
As far as anything being directed by the DAL MEC, all they directed was how much flying could be done by someone other than themselves. Just because we fly it doesn't mean that it becomes EV code. It is still DL code, and always will be. We have not had EV code since we began our code share agreement with DAL, and likely will never again.
Be careful atrdriver, you're starting to make sense, and you'll be scorned into the same corner as the evil DL pilots. Remember, its everyones fault but fins! It makes him look at himself easier in the mirror. And as for Surplus, he's been retired for nearly 2 years, no longer has a dog in this fight, but he has to have something to brag about in his twilight years. Imagine how terrible it must have been to fly with some old miserable fart like him!?
737
surplus1 said:
FDJ2 said:
[/color][/size][/font]
Wrong again Surplus, but that's no surprise. Even you should know that the scope of DAL pilot flying is defined in section 1 of the DAL PWA. The same is true for CMR. It has nothing to do with what aircraft DAL operates or has on its certificate. If the PWA stated that Delta pilots would fly KAL 747s that have DL code on them, for example, then that would be DAL pilot flying, so long as it was ok with KAL of course. Likewise, if our PWA allowed KAL pilots to fly DAL 757s, even though they were on our certificate and under the operational control of DAL, that wouldn't be "our work." Section 1 defines the work, not the standards you conjure up out of thin air, such as only "whatever DAL operates on the DAL certificate and nothing else." One day you'll learn the difference.
Horses can be rounded up and barn doors closed.
Live with it.
I can live with what we negotiate with our employer, you're the one with the problem and the endless, going no where lawsuit.
We get what we negotiate. It's all part of the collective bargaining process.
So you agree that if we want to close the barn door we could, and that would be legal if both DAL and the DAL pilots agreed to it, since as you say, "we are free to make that decision. Great Surplus, we have common ground, I can negotiate whatever I can with my employer.
I have no problem with the CMR PWA or colective bargaining process, I'm not the one with the lawsuit. The CMR pilots have ratified everyone of their contracts, not the Delta pilots. The fact that their previous MEC leadership failed them miserably and left them with no job protections in the event of an acquisition is not my fault, but rather the fault of the weak and short sighted MEC that negotiated their PWA prior to their acquisition.
We won't have to leave ALPA, since the RJDC lawsuit is failing miserably and can't even make its way out of discovery three years after 90% of the RJDC's baseless claims were summarily rejected and the discovery process started. What do they need to discover, the language in the PWA is a matter of public record? If they had a claim they could back up, they would have moved forward by now, but they don't.
Why can't you admit that APA and ALPA FUBARed the career by allowing jets to be flown by regionals. FUBAR- Do you know what that means?
I'll admit that, but that has nothing to do with this silly little lawsuit.
Well, it kind of does. Scope has failed the legacy pilots, and to an even more pathetic extent, it has failed the regional pilots. It would be better if we worked together, but that is completely lost on ALPA and its roll-call majority. Its an ego thing, and there's no accounting for that, as we all know.
The problem isn't that scope failed the legacy pilots, the problem is that the legacy pilots gave away all of their scope. Just look at General Lee. A few days before the TA was released, all he could talk about was how he would vote down any TA that contained scope concessions. What actually happened? He voted for a TA that allowed further erosion of his contract's scope language in a sad attempt to hold onto a few bucks an hour and a work-rule here and there. Even after all these years of outsourcing, the General and his legacy buddies still don't understand that all the pay and work rules in the world don't help when your flying is being done by another pilot group. That's the real problem.
This isn't really the fault of the national Association. It's ultimately the fault of the individual MECs and pilot groups.
ALL? A bit of a stretch there don't you think? I agree that we have relaxed our scope too much and allowed too much of our code to be flown in larger gauge aircraft, but don't forget that still is only ~ 15-18% of ASMs, not all.
BTW, I voted no, but I respect the bargaining process and accept the decision of the majority of DAL pilots. It is after all the DAL Pilots Working Agreement, not FDJ2s.
I recall in the late 90's when everryone was hiring..... We didn't even need Mr Roarke to say... SMILES! Everyone SMILES!!!
True, but ASMs do not create pilot jobs; block hours do. If I remember correctly, about 49% of DAL block-hours are flown by DCI carriers. That's roughly half of all Delta's flying being done by outsourced pilots. That's one heck of a lot of jobs!
I don't mean to blame the entire pilot group, because you're certainly right that many pilots did vote no. However, we all need to understand what the real problem is here: outsourcing of mainline jobs. The RJDC is fighting on the wrong side of this issue, and that's really my main point.
I think I am going to be sick. As much as I have raked PCL over the coals for his past transgressions, he is dead-on balls accurate on this. It pains me to say this, but I could not possibly agree with him more. Well said PCL......
Um, I'm gonna disagree here. If MEC's were signing away scope, why didn't national step in? There has to be accountability in the ranks, but when every MEC is doing what suits it best at the expense of the career, there needs to be a higher power to intervene.
I vote for an overhaul of ALPA. I mean, the sticker says "one union, one mission...".
I don't even remember when you raked me over the coals, but glad to see you've come around. :) ;)
you guys truly are hypocrites. I thought all scabs were evil and could never be forgiven? I guess they can if they pay their dues. Goes to show its a buisness like everything else.
Its funny how you guys always love to blame management for the ills of the world however ALPO can do no wrong. They are the management. If there is a failure among the ranks then its managements failure is it not? You are all hypocrites if you dont blame management(national) for the shortcomings that have taken place. Also why is it so hard to recall MECs etc. Why does it have to be so political. Why not put it to a simple vote majority rules one way or the other. ALPO operates using cowardly tactics all the way.
Dad..blastit. Need I remind you guys once again!!!!!!
This thread is reserved for discussing what an ass-hat JB is. Scope, RJDC, etc. take you fight elsewhere.......
JB is an ass-hat. Please discuss amongst yourselves. Dispite our many differences, I'm sure we can agree on this much.
Here. I'll get us started......
JB is such an ass-hat, that............... {eagerly awaiting the fill in the blank session}
Sorry, Freightdog. I just figured that John's ass-hat status was a given. :)
And the number 4 slot on the Ignore List goes to...............
This message is hidden because D'Angelo is on your ignore list.
Ahhh, that's much better.
I find it ironic that this thread has turned in to an RJDC hi-jack. It is ironic because even the RJDC has distanced themselves some from mental instability of JB.
He is clearly trying to fight a war, in his own mind anyway, by himself. Well two if you count his other half. ;-)
