PSA runs off runway during a aborted takeoff at CRW!
Yeah, you go off to the south west without that and you won't stop till you hit downtown!
Is the EMAS part of the stopway? How'd they get into the EMAS?
Do the ACARS numbers keep you out of the EMAS if you stomp on it at V1-1kt?
Wow. Having been there several times I know how bad that drop is. The engineers who came up with EMAS should be given a medal or something. That stuff has helped avert several potential disasters.
Years a ago a drug ring wanted to up its load out of CRW so they switched from a king air type to a DC4 or 6. Too much pot, too heavy and the aircraft went over the edge and down......
Any details?
Glad the outcome was everyone is safe!!! A very worthwhile investment!
I'm under the impression that depending on your performance vendor, yes the EMAS area may be considered part of a 'clearway' or 'stopway' and therefore be usable in factoring accelerate-stop numbers. Maybe you even get a little extra because of being able to sink into the porous concrete like they did and stop far quicker than if it were just plain runway surface. Who knows?
EMAS cannot be considered when calculating balance field length....remember accelerate stop distance is not the same thing.
EMAS should be at the end of every runway; think of all the runway overruns we've had in the last few years. Southwest, Pinnacle, Shuttle America, American, ASA-seems like every airline has had at least one. And also you have the learjet accident in CAE that overran at a high speed so it may not have helped with that one. Too bad it costs so much
There is actually a grave yard immediately below or down the hill from the edge of the EMAS. We used to mention that in our take off briefings.
The airport has it's own Facebook account and posted pictures. This is funny(or maybe not so funny - hey mom I'm on Facebook); an airport doing this. Can you imagine every airport doing this? Expect your screwups to be posted folks. And the airport even sent it out on Twitter.
http://www.facebook.com/FlyCRW
I have heard various accounts regarding that DC-6 which ran off the side of the hill at CRW. The rumors are the Six was trying to land and the brakes failed so Cappy decided to cob the throttles and take it around the patch but instead the old girl went off the side of the cliff and split wide-open spraying the contents of the aircraft (Pot, in this case) all over the hillside. Supposedly the pot started growing, and unbenounced to the cops, the locals started harvesting it off of the hill leading up to the airport. I'll add that the pilot made an out of court settlement. He didn't serve any jail time at all.
The important thing is everyone is ok. Speculating on why they stopped is pointless but it was definitely for a good reason because we all know that runway is short and the view at the end is not a good one if you're not taxiing.
EMAS cant be used in performance calcs, neither can the stop way, acars only uses the usable runway for calcs.
Not sure what criteria PSA uses for takeoff data, but most Part 121 carriers I've seen use data that is predicated on 121.189c1. Which states:
" The accelerate-stop distance must not exceed the length of the runway plus the length of any stopway."
So, yes, on a high speed abort on a runway limited field you can expect to go through the end lights and end up resting in the stop way area; or EMASS; assuming you do everything right.
I always understood the T/O data to include the use of the stopway, or in this case, the EMAS. In short, I fealt that C.W. was a departure not to be aborted unless a wing fell off..............
Installing EMAS would actually do more damage to an airframe at several airports rather than the grass at the end. It's too expensive and very impractical for many airports. If the ASA 700 would have used the EMAS at SAV, it would have torn some stuff up good (gear doors, struts, belly skin, etc.). With the grass at the end, it probably just needed to be hosed off and given an inspection with few, if any, broken parts as a result............
