Power washing a jet engine...interesting results
thatpilotguy
This is interesting. I ran across this article while surfing this morning. I'm happy to see that the airlines are entertaining other ideas to save fuel and maximize profits. It beats paying another passenger based fee.
It's seems so simple, I wonder why we have not heard about this before, and if it will ever trickle down to the corporate jet world. I would imagine some larger operations, such as the fractionals would see a return and honestly I would be interested in knowing how it would impact a small 500 hours a year operation. I'm all for saving a buck, especially if it is such a simple situation.
Not sure if I have this link right, but there is a video bar. It's titled cleaning with a jet engine bath...
http://www.msnbc.msn.com/id/21134540/vp/27320663#27320663
I don't think compressor washes are anything new...Cessna asks me if I want one every time I visit a CSC.
Really? I have never heard of such a thing. Of course if an authorized service center had offered that service I would have probably laughed thinking it was some sort of snake oil. Does Cessna offer any documentation on the performance post wash?
I don't know...never accepted the service because our engines are less than 200hrs out of overhaul.
There were two different types of washes going on in that video. However, a compressor wash isn't "snake oil," it's a standard maintenance procedure that's as old as turbine engines. If you know anything at all about maintenance done to a turbine airplane, be it turbojet or turboprop, then you will know about doing a compressor wash.
A compressor wash is more than squirting water in the front of an engine, and it involves the disconnecting of certain bleed and other lines, and the use of soaps and solvents as well as water under pressure to clean the compressor while the engine is being motored, and restore operating efficiency.
When they used to run crushed walnut shells through the Darts on a G1 it was a sight to see... Smelled pretty good too!
P&W recommends a compressor wash on the PT-6 after every flight in high salt environments. I learned this the hard way a few years ago...
Is that a recommendation on all PT6s? I know there have been problems with compressor inlets and corrosion on some of the single engine pipers.
What happened in your case?
The only time I saw data after an engine wash was when we had our PW545a hosed down because of high ITT temps at takeoff and inital climb out.
It dropped the temps by a pretty signifigant amount. It was long ago so I don't remember the numbers. Glad it solved the problems, the alternative was very expensive as I recall.
yep...been around forever, too bad the premier guys didnt know that. i know of at least 2 premiers that would not start cause they werent doing em...lol
It just goes to show that you learn something new everyday.
I'm not new to jet aircraft, and thought that I was pretty much up to speed on most maintenace procedures. This is the first time I have ever seen or heard of such a thing. I guess not having any PT6 time might have something to do with it. However, walnut shells through a Dart on a G1 would be great sight to see! Is this a more common procedure with older type motors? I suppose I really should talk with the Honeywell rep regarding our motors, but I'm curious if technology has anything to do with the level of cleanliness.
Honeywell engines don't have the compressor wash schedule like a Pt6 or Williams engine. Heck on the TFE731 I don't know if they ever do one :)
we do them after every flight in the turbo-beaver. Let the engine cool down, hook up the hose and blast it. Doesn't seem right to me either, but salt water kills.
This is standard with nearly all turbine powerplants, though walnut shell isn't always used. Various nonabrasive media are used, and washes using solvents, soaps, and water are standard.
This has nothing to do with "older" powerplants, and nothing to do with PT6's.
I operated TFE731's on Westwinds for years. Never had a compressor wash there and don't recall it being in the maintenance manual for the 731-3 engine. A compressor wash would probably gut that engine or cause another #@&% oil leak!!! The Pratts on the Citations are washed anytime there is a ITT issue or power loss. Practically the first step in the troubleshooting process.
There is usually no doubt about whether or not your Caravan had a comp wash overnight by mx after you've turned on the bleed heat.
Not exactly spring fresh.
