The_Russian
Low Level Pilot
- Sep 3, 2003
This is not always true. AIM 1-1-9 d.Well I dunno, as I recall the AIM was pretty clear- GS signal is not valid outside of 10 nm. If you're outside of 10 miles, you fly the profile-Inside 10 miles, the glideslope is valid.
3. The glide path projection angle is normally adjusted to 3 degrees above horizontal so that it intersects the MM at about 200 feet and the OM at about 1,400 feet above the runway elevation. The glide slope is normally usable to the distance of 10 NM. However, at some locations, the glide slope has been certified for an extended service volume which exceeds 10 NM.
That being said, does anyone know how to find out whether a GS for a particular approach is 10 nm or 10+ nm? In other words, where is it printed?
