Lear70
JAFFO
- Oct 17, 2003
What PD said is completely accurate, except your profile indicates the BE40 and C550 which means you have some jet time as well. If a good amount of that is PIC, you *might* qualify as a street CA, and then you'd be on reserve.
Different ball of wax. Reserve is "almost" always commutable. Downside is it's just 10 days off every month... which, if you're used to being home, is a BIG slap in the face after the newness wears off.
But yeah, anything in the country within a 3 hour flight of the hub (pick one) is commutable on reserve, unless they change the line construction to all Home Reserve and make it start at 0700 or something goofy.
p.s. Bribery works well in Crew Scheduling. Pizza deliveries, cases of Tequila, all those things go over pretty well to make sure you get a lot of trips on your schedule and reserve periods removed, making your life a LOT easier.
Not that I'd know anything about that.
