However every analyst out there is saying merge to reduce capacity.
Which will happen. It won't because some dork on Wall Street things it'd be really cool. It'll happen because the overlap in the systems means you don't need 4 RJ's a day (within the same system!) fighting over revenue in Cedar Rapids, Iowa.
The analysts aren't looking at Load Factors and International growth in terms of ASM's.
Yes, Intl takes more pilots. but what does 6% domestic in block hours equate to 16% Intl block hours?
Huh?
(Watch out. Fly4hire is wary of "fuzzy math"!)
Any reduction in domestic flying will be at the Airlink level. It's that way because:
1. Airport saturation. The threat of "congestion pricing" at JFK spooked airlines into swapping 50-70 jets for 125-seaters in there because they were getting "slot limited"...not "size limited". The other business O&D cities are the same way (except DEN). Delays and disruptions in each system due to airport saturation are a significant inefficiency.
2. The Airlinks can be whipsaw'd, and mainline-owned assets ("jets") can be transfered over to a different Airlink. Any examples of THAT out there? The Airlinks are having a tough time staying staffed right now. That means a reduction in blockhours
enhances the
completion rate...which is one of the performance requirements for each Airlink to earn it's full hourly rate under the Agreement.
3. The Airlinks can't multi-task.
B757's operate from the mainland to Hawaii, across the Atlantic, and InterPort out of the NRT hub. They can
also fill the bill domestically when Marketing needs the added lift. CRJ's and EMB-170 can't.
Also Intl is staffed 2:1 with F/O's for augment. What does that do to upgrades and career progression?
More blockhours = More pilots. (Archive that, it's an important concept)
Both the utilization rates and the baseline pilots-per-hull ratios (Check latest
Scope Score Card) put International flying waaaay ahead of domestic. The B787 will be
double-crewed...just like the B777 is.
Depending on an integration methodology, pilots could lose big time in the out years on WB positions due the difference in average ages of the work force.
Got me there! A crappy integration could stymie advancement to widebody flying. Except WB positions are now just about the most junior at both airlines! (B747 S/O and B767ER F/O going to New Hires)
To date the internal capacity cuts have all been NB with RJ/SJ growth. What makes you think that will suddenly reverse in a merger?
You're wrong. You said, "To date". Go back and check your Scope Score Card's from 2001...when we were buying RJ's, parking, WB's, and
HIRING. The number of pilots furloughed matched the number of pilot positions lost to parked WB aircraft almost exactly! (928-952) That is creepy close!
Had we kept those WB seats...no furloughs.
Now, as we add WB seats (and/or International flying), we're hiring.
Attrition has been a contributing factor, and I take your point, but your premise that Airlink flying will usurp enough NB flying to cause a net loss in pilot jobs (all things considered) is wrong. I've been a staffing wonk too long.
Unless there is another BK, NWA and DAL can't simply walk away from those expensive air services agreements, nor do they seem inclined to do so...
Oh yes they can! If any Airlink
fails to perform, they can be dropped like a Romo pass to T.O.! The Airlinks also have no say in...well...almost everything! They don't set ticket prices, timetables, livery, aircraft type or purchase, or gates. The mainline giveth...and the mainline can taketh away. They're called "Weasel Clauses" because they were invented and written by weasels. If your suggesting any of the Airlinks can dictate the outcome of a potential merger negotiation between mainlines...we'll have to disagree.
No, I simply don't buy the sunshine that covers the disconnect between why the financial community wants consolidation - to reduce capacity and save on fuel costs - and that this will result in a better career for everyone.
Ok. I understand. I'm a skeptic too. But I'm looking at what I
KNOW, right
now, about our
status quo...and I weigh that against what
could be if a deal were done right.
Even if it does not result in furloughs (which I doubt) it could certainly result massive career stagnation. If you are at NWA, happen to be on a WB now the risk/reward looks a lot better than if you have 15-20 to go.
Not getting to a WB is "stagnation"? (sigh) Color me stagnate! Grab next month's bid list and check out the seniority number of the NB guys on the first page of each aircraft/base.
Surprise!
We
COULD see some stagnation. Of course. I also believe that some will see it even if there
is none! (Some pilots are funny that way...)
Bottom line is NO mergers is the best the scenario for us, and everyone should be mucho suspicious when ALPA start buying the synergy tripe the WJ wonks and management are putting out.
You're right, and I don't think ALPA is "buying" anything. I think both sides are viewing the opportunities and weighing them against the hazards.
Perhaps Anderson's vision of a global airline will really benefit all - and if it does it will be first.
Yeah, that UAL purchase of PanAm's Pacific stuff was lame. Ditto the DAL purchase of the Atlantic. Absolute failures!
The track record on mergers for pilots has never lived up to the pre-merger hype and predictions that are always trumpeted. Maybe this time will be different.........
Maybe. Maybe not.
Fortune favors the bold.
