NTSB info on SWA at LGA crash
See, there is the problem RIGHT THERE. Where was the "Wind Check" call? Crews should ask every 300 feet to be safe! We all know that...:)
Bye Bye---General Lee
Won't save you from landing on a taxiway......
Serious lack of airmanship here. Landing on the nosegear means they were probably way over ref speed. If not then it was a controlled crash into the ground with no flare.
CVR will be very telling in this case. Sure sounds like this captain was widely hated and she has very poor flying skills. Thank God nobody was killed. HS
"As for your low fuel level theory, although I unequivocally disagree, it still does not explain the necessity for the Captain to assume control of the aircraft at 400ft instead of making the command decision to call for a Go-Around. "
Really? Always?
That would be a cool to watch....Let's say you're down to 2800 lbs in a 737 and not "stabilized" for whatever reason... you're going around?
Okay...." News at 11 "
YKW
Really? Always?
YKW
If, as a Captain, you manage to fly an aircraft to a critical low fuel state situation and you opted to continue to your destination instead of diverting to an alternate, then some serious questions needs to be raised about your Captain leadership ability! Under IFR, you must have enough fuel to fly to your destination (and alternate if applicable), PLUS 45 minutes. If you have not seriously considered diverting once you reach 45 mins fuel remaining situation, then it clearly speaks volumes of your decisions making skills or lack there of.
Secondly, in this SWA accident, the Captain never reported Min Fuel or Critical Fuel (which the latter would trigger an automatic emergency ATC handling).
Thirdly, if this was a low fuel situation as you described it (which facts do not support your theory), why take the controls at such a low altitude? Evidently the FO managed to fly and stabilized the aircraft, with precision and pose, all the way down to the point the Captain took controls of the aircraft. Therefore there is absolutely no sound justification for the Captain to assume control of the aircraft!
That's a lot of EXCLAMATION points!!!!!
Very sound argument against a hypothetical-
Final findings will give everyone plenty of chances to dissect everything in context- until then- again- knock yourself out, but you're mostly pissing in the wind
Wow. Slow down Cowboy...:)
( The above proves here, once again, Pilots are functionally Illiterate...)
Your diatribe is another unnecessary overkill to a perceived threat to your supposed intelligence... I never came up with any "Theory" .
YOU stated the Absolute...."We Go-Around when the Manual/GOM/ Procedures "Call for IT"."
Sometimes things ain't like Grandma wanted 'em...Capiche?
Sometimes, a little "Common Sense" would be good too. Eh?
There are Reading Comprehension Courses online...available to anyone, no matter what their means.
Although, Common Sense, really can't be taught.
Have a Good Life....And Good LUCK.
YKW
Just curious if you guys do Cat II approaches and how you handle them.
Yes, Cat II and III Autoland. Captain is always PF for those.
Same rules apply. In case of pilot incapacitation, the safest course is to continue the autoland and this is specifically allowed.
Any other reasons I can imagine for transfer of control (to the FO!) below 500' would require a go-around.
Hmmm...I think I said that?!?
Av8tordude said:
All airline procedures, in their own language, dictate that for any reason a safe landing becomes questionable, a Go-Around MUST be executed
So if a landing becomes unsafe, will still attempt a landing?
[/QUOTE
I guess you must be speaking from personal experience?
