scoreboardII
- Apr 15, 2008
It'll be interesting to see what happens when people start doing that... I'm sure the company will come up with some modification of the fatigue program if it starts to become a problem that impacts daily On-Time.But lear it doesn't matter, if you need 8:45, thats what you need and per the new rule of you needing to sign that you're not fatigued, you get 8:45.
They did better. 10 hours free from duty. At my airline duty ends 15 minutes after block in and starts 30 prior to block out. 10:45 block to block is better than a lot of pairings currently provide.
Then there's 8 hours of uninterrupted rest. I'm not resting when I'm showering and getting ready for the day. I would interpret this as 8 hours from door closed to alarm goes off. For me, 8:45 behind the door.
We'll see... I doubt it.I'll tell you what, the fatigue calls will mount as folks start to realize they need to sign documents stating they are fit for duty.
Craptastic... love that word. It covers so many different subjects.Pulling pay for fatigue calls? I didn't get the rest I needed at the craptastic hotel the company put me in so yes, they better pay me my wage.
You do realize Southwest is about the only company that does that, right? At most carriers, if you call fatigue at the outstation and they can get someone in to cover, when you come out of rest, they pull you without pay and your next flight is to the Chief Pilot's office to explain. Do that enough and you might find yourself qualifying under the company's attendance policy which, at many companies, can get you fired.They already pull no pay if you call fatigued before you start the trip, thats reasonable; you show up tired for work, your fault, your kids fault, nobodys fault, why should the company pay you?.
A fatigue call is different than the protections under most CBA's sick policies... Just because SWA recognizes the importance of well-rested crews doesn't mean other airlines do (most don't).
Just as an off shoot, and a WTF moment reading those 330+ pages. On the subject of reduced rest below the 10 hours. ATA wanted reduced rest provisions, ALPA AGREED with them. Really?!?!? Anyways, FAA said, nope, we are dealing with fixing rest. Fix your schedules so you don't have to reduce rest.....
Really ALPA?
ALPA feathering the companies... And folks act surprised?:laugh:
The snowball rolling down the hill is irregular operations. Say you divert, hit the 8 hour point, however now we can fly to 9. But the scheduled flight is 61 minutes from divert to overnight, now you're done when before you could have kept going till you cried uncle.
Or better, lets say you hit the 8 hr point after you diverted, the flight from divert to overnight airfield is 30 minutes with a 31 minute divert flight because it's still at minimums. I consider I will need to account for all possible flight time, including another divert. And yes, I have diverted twice in one day.
§ 117.19 Flight duty period extensions.
(a) For augmented and unaugmented operations, if unforeseen operational circumstances arise prior to takeoff:
(1) The pilot in command and the certificate holder may extend the maximum flight duty period permitted in Tables B or C of this part up to 2 hours.
(2) An extension in the flight duty period under paragraph (a)(1) of this section of more than 30 minutes may occur only once prior to receiving a rest period described in § 117.25(b).
(3) A flight duty period cannot be extended under paragraph (a)(1) of this section if it causes a flightcrew member to exceed the cumulative flight duty period limits specified in 117.23(c).
(4) Each certificate holder must report to the Administrator within 10 days any flight duty period that exceeded the maximum flight duty period permitted in Tables B or C of this part by more than 30 minutes. The report must contain the following:
(i) A description of the extended flight duty period and the circumstances surrounding the need for the extension; and
(ii) If the circumstances giving rise to the extension were within the certificate holder’s control, the corrective action(s) that the certificate holder intends to take to minimize the need for future extensions.
(5) Each certificate holder must implement the corrective action(s) reported in paragraph (a)(4) of this section within 30 days from the date of the extended flight duty period.
(b) For augmented and unaugmented operations, if unforeseen operational
circumstances arise after takeoff:
(1) The pilot in command and the certificate holder may extend maximum flight duty periods specified in Tables B or C of this part to the extent necessary to safely land the aircraft at the next destination airport or alternate airport, as appropriate.
(2) An extension of the flight duty period under paragraph (b)(1) of this section of more than 30 minutes may occur only once prior to receiving a rest period described in § 117.25(b).
(3) An extension taken under paragraph (b) of this section may exceed the cumulative flight duty period limits specified in 117.23(c).
(4) Each certificate holder must report to the Administrator within 10 days any flight duty period that exceeded the maximum flight duty period limits permitted by Tables B or C of this part. The report must contain a description of the circumstances surrounding the affected flight duty period.
You must have some really crappy pairings, I haven't done less than a 10 hour overnight in months, and maybe only one or two in the last year.
Not sure how you got that out of the reg.
It's 8 hours behind the door. If it's going to be less than that because of delays getting to the hotel or checking in, you can adjust it accordingly, but it's not 8 hours plus time to get ready and get downstairs... nice try though.![]()
§ 117.25 Rest period.
(e) The 10 hour rest period must provide the flightcrew member with a minimum of 8 uninterrupted hours of sleep opportunity.
(f) If a flightcrew member determines that a rest period under paragraph (e) of this section will not provide eight uninterrupted hours of sleep opportunity, the flightcrew member must notify the certificate holder.
Based on the comments received from the certificate holders, the FAA agrees that using the time when a flightcrew member reaches the hotel or other suitable accommodation would present more issues for implementation than it actually solved. The FAA’s main objective with this provision was to ensure that flightcrew members have an 8 hour sleep opportunity. Building from that and mindful of the comments received, the FAA has decided to adopt a 10 consecutive hour rest requirement that immediately precedes the beginning of a reserve or FDP measured from the time the flightcrew member is released from duty. At this point, if the flightcrew member cannot have 8 uninterrupted hours of rest opportunity, the flightcrew member cannot report for the assigned FDP until he/she receives that rest. If the reason for the shortened rest opportunity is travel delays, reservation confusion, or the flightcrew member’s actions, the certificate holder is free to address the root cause. However, it must provide the required 8-hour rest opportunity.
That's completely reasonable.But the real beauty will be when the occasional drunk party animal crowd wakes me up. I will have to call the night manager to have him come upstairs and do some of that management vodoo on the drunks,... then I will be obligated to immediately call my scheduler and tell them (on a recorded phone line) that I just finished having a conversation with the hotel night manager about my interrupted sleep. Hack the clock for eight hours.
Yeah, good luck with telling your chief pilots you needed extra time to brush your teeth and wrap up in your snuggy.However the real gem is the 8 hours uninterrupted sleep opportunity. The airlines would be fools to plan less than 9 hours at the hotel since it would be unreasonable to deny crews 30 minutes to brush their teeth and get into their pajamas for the night and 30 minutes in the morning to reverse the process.
So, the penalty for exceeding the limit is more time doing paperwork after work that we don't get paid for? Riiiigght.It looks like you can extend past the scheduled FDP for unforeseen operational circumstances (up to two hour extension), with different conditions prior to or after takeoff. Also some pretty strong restrictions and reporting requirements if the extension is longer than 30 minutes.
