Most Challenging Regional Aircraft??
EMB-120 Brakillya. Hands down.
V1 cut, no autofeather? Good frickin' luck. Just try to hit the ground wings level.
Icing? Get out quick if it's more than just frost. Don't slow below 160kt lest the ground rise up an smite thee.
Props blowing up or overspeeding to 200%Np? Ya never know... ASA had an overspeed a couple months before they went away, still not sufficiently explained.
Flying characteristics... very stable at cruise. Like a Corvette on a icy road any time else.
Landing characteristics... flaps 25 not too bad. Go to 45 and they'll feel it in Shanghai.
Turbulence... knock your teeth out. That stiff wing.
Hot hot hot. Cockpit temps above 90 in flight not uncommon here in Dixie.
Brasilia is tough, but any good pilot can handle the V1 cut without the autofeather. It also will haul some ice. Not that I advocate flying around with a lot of icing, but it does OK. It is definately the hardest airplane I flew, but if you are a good pilot, you can do a V1 cut without the autofeather.
Sure, anyone can do it in the SIM when you are ready for it and the conditions are simulated.
Try one on a 98 degree day and at the limits of performance and weight. Talk to us about that. Your last name Yeager?
you could lose the autofeather and make it on the E-120 if you where on your game. Did anyone have their instructor fail the autofeather and go to manual reversion on the rudder??? Now that was about the toughest thing I ever saw in the sim...Took both pilots pushing on the rudder pedal to keep it straight. Legs where like jelly when we got out of the sim. Was a lot of fun to fly though.
StopNTSing said:
Three pages of this thread and not one vote for the Sewerpipe? WTFO? Must have been before ya'lls time?
Not before my time thanks to 5yrs of Big Sky. Left a Chieftain and C-340 that had auto-pilots(but didn't need them) to the Metro(needed one). No yaw dampner either. Add to that:
-3 foot wing extensions to add needed lift for take-off. Opps we forgot to carry out the ailerons with that.
-dual SAS computers and vanes with a 60 lb. yolk pusher. Cause if you stall you're dead.
-Water injection and JATOs, because the upside down redesigned APUs(TPE-331) don't have enough power.
The sick thing is I have fond memories of flying it.
Any turbo prop because you make so little money you are doing it with three hours of sleep because of the second job as a PDS has you up late at night.
Well, that's like beating your head against the wall -- it feels so good when you stop.
The early Jetstreams had the water-meth, too (or WeeWee, for you Metro drivers); they didn't have JATO bottles, though, so ... you win!
edit to add: I do not understand why so many of you are voting for the Brasilia. It had Y/D, autopilot, autofeather, APU, catering, coffee, a flight attendant -- and, most importantly, a biffy. Y'all never had to walk to school, did ya?
I love the day I left the "weed dart" especially the ones with the McCauley Props (almost took me to the weeds) and went to the E120 and had my overspeed (be it after landing) the left prop went to 108 percent. I respected both aircraft they we unique in their abilities and faults. Oh yes the manual reversion and v1 cuts in the E120 were leg killers.
My vote is for the SA-227 because as the FO I was FA as well.
My vote is for the E120 because the FAs enjoyed the vibrations.
Can't decide........
No, his last name is Dudley.
Yes, my 6 month FO probably has more experience flying the line than Biscuit. But the procedure works great in the sim! And the sim ALWAYS flys just like the airplane!
Just put a doghnut on the failed engine power lever and he will identify the failed engine everytime.
Flex81 said:
BTW, my vote is for the E-120 cause it is harder than the 1900. "change power...trim rudder" over and over again
The trim thing was goofy, but you forgot about it after a minute b/c you were so used to it. The Beech could definately carry alot more ice-advocated or not you're likely to see it in the 'turbopropause' portion of the atmosphere. I thought the ice equipment worked better than the 1900-but I always felt like it had too. The airplane started losing a/s in ice way before a 1900 would. Can't believe no one's mentioned the Brasilia's slightly overenginered flap system, or it's well thought out QRH. Engine's burning, go ahead crank that APU, turn page, oh caution you might want to determine which engine is burning b/c you might feed the fire. Almost forgot, basically the same radar as a 1900 but big difference in display if the radome is wet on a Brasilia. I thought it flew nicely outside of icing and landed much easier and more consistently than the 1900 at both flap settings. Had a few issues with the nws from time to time, but none were worse than a 1900 with one prop in reverse and one at flight idle due a screwy low pitch stop.
J32 hands down has got to be the winner. Only plane I've ever flown that would try and roll over if you let go of it. That was fun for 10 legs a day, no autopilot, no yaw damper, no electric trim, no bathroom, and no coffee!
Can't believe no one's mentioned the Brasilia's slightly overenginered flap system.
i agree. more than once i got to do a no flap landing
This is what happens when a bunch of furloughed Boeing engineers go to Brazil and start drinking caipirinhas.
:beer:
E-120 wins!
Any airplane with one generator for every 6 passengers must be a bugger. I always worried about a real v1 cut at the end of a long duty day, at night, in the weather. In the sim they gave everyone a free try on the pro check. Flap misconfigs were common and the rudder required constant attention. EEC's kicked off out of the blue and props killed a many a good crews and passenger. Other than that she was a tough bird and performed well. Short approaches were a blast. I loved the bird but as with all sport cars I knew she demanded respect. The training department was on speed by the way. When I was in training in 2000 one of the Airline publications listed the ASA E120 program as the hardest 121 training course in the USA.
LOL, studying for E120 school next month and I was blown way, 5 generators!? WTF for? 3 ways to extend the gear? 15 individual deice boots? Still staring at the prop schematic, still haven't figured it out. What would have been so worng with using a big-ass spring like every other prop system on the planet?
Flown 'em all. The J32/J31 is the clear winner. Brasilia, tough but as soon as you said "stable at cruise" you lost the fight. The J32 wasn't even stable in cruise. The only time a J32 was stable was sitting at the gate. I'll never be so good a pilot as that again.
Be glad it's got 3 ways of dropping the gear, I had to use all of them!
I give it to the Jetstream by far
No way the Dash-8, you can get so far behind that thing and be okay.... The metro works yes but not the best in all conditions like the dash.... Don't know about the 1900 but i'm sure it's a solid contender.. The jetstream thought be aware all the time because when it decides to bite it will bite hard................
Cardinal:
The funny thing about having all those generators on the EMB-120 is that if you loose the two main generators and the APU is not available the packs are inoperative and you loose pressurization...even with the two aux generators working normally. Cool. Not.
Hopefully, no Skywest regular PAX's will be reading this post!LOL. I always wondered about the Brasilia. The bird looks like a real stable platform when landing and you rarely hear about accidents with the Brasilia. Seems to me the biggest complaint is more on systems & equipment rather than flying qualities. At any rate, this is a great thread.
Gotta suck having to reverse engineer a turboprop in ground school.
I have never flown it, but from what I hear, the Brasilia was a ball twister, and I know that ASA has some stories involving that one. Thank God I did not have to learn it.
For my own experience I would have to say the Metroliner. I don't know if they still are flying them in 121 service or just Part 135 now. My instrument skills was the best they have ever been after I flew that thing.
OPECJet said:
Dash is nice in a crosswind. Use the wing down, and let the SOB hit. Got a huge rudder back there to keep it going straight.
I've hear horror stories about that little Limey Jetscream.
Funny thing about landing the Dash. I had a month where every landing was a greaser. Couldn't have made a bad one if I tried. The next month, every landing was crap. Opened the overheads a few times. My paycheck was the same as when I was making the good ones... Now I just don't give a frogs fat arse.
Heyas OPEC,
I have to agree with you 100 percent on that. In my 5000 hours on the Dash, I ran into the EXACT same thing. You'd have good months and bad months for no rhyme or reason.
I did love Flaps 35 though...that freaky pitch angle and that BIG flair at the end.
Still, I loved that bird. Built like a brick privy, and still able to carry 37 people and their sh!t out of HHH on a summer day (well, "1995" people, anyway...they weren't as fat back then).
A/C was weak on the -100s, but MUCH MUCH better on the -200s. Summer in CLT or MIA, though, with a -100 was brutal, even with the APU.
Nu
GuppyPuppy said:
As for the 402's...I imagine they are a handful. Same goes for the Chieftain.
GP
I have no idea how a 121 Cheiftain was.. but I flew a corporate PA31-350 and it was marvelous. Flew about the same as a Baron... if you could get the engines started.
I can't believe all you Brasillia wussies.
You had an airplane with APU (air-conditioning), a lav, an autopilot, glass, and an F/A to bring you coffee and you're whining?
You guys wouldn't have lasted ten minutes in the Jetstream.
To the tune of Gilligan's Island:
Just sit right back and you'll hear the tale
Of a typical Jetstream trip
(We) Stuff nineteen paying passengers
Aboard our tiny ship.
No Drinks, no Stu, no Cockpit Door
Not a single luxury
Like Or-ville and Wilbur Wright
As primitive as can be
My armrest's stuck, my back is shot
I have a second job
The engines are not making torque
I wish I flew a Saab
We wrote one up, the boss is mad
It's me he wants to fire
I should have stayed in dental school
The majors will not hire
The freon's out, the flows are bad
No damper is installed
The passengers are turning green
The new guy is appalled
The pressure spikes, the radar's shot
The brand new engine quit
I hope I live to tell the tale
Of a typical Jetstream trip.
A-board our ti-ny ship!
