FLOPS Impass?
Ok...I've decided.
News Flash:
Out of 9 new-hires in this months class, one was recommended for a check ride at Simuflite.
So yea Flops management can get applicants, but none of them are making it to the line.
Bottom line, we are paid 50% of the industry standard and as such management can only attract pilots unsuited for the task.
Time to pay up management.
As for you CJS, go turn a wrench or something. At least do your homework before you come on here.
No, the system worked.
There are lots of pilots looking for work, and if they can't get through training, the system worked.
Is it pretty? Nope, but the system worked.
With airlines dropping like flies, there will be a lot of pilots falling into those positions. When they all pass training because the market and economy is slipping, will you be posting the numbers saying they all passed Gerry?
I think not, because you won't post any Flight Options successes, only what you percieve is a failure.
You really need to fly for Netjets.
What is a B19???????????
The Douglas XB-19 was the largest bomber built for the United States Army Air Corps until 1946. It was originally given the designation XBLR-2 (XBLR- denoting Experimental Bomber, Long Range).
The purpose of the XB-19 project was to test the flight characteristics and design techniques associated with giant bombers. Douglas Aircraft Company strongly wanted to cancel the project, because it was extremely expensive. Despite advances in technology that made the XB-19 obsolete before it was even completed, the Army Air Corps felt that the prototype would be useful for testing. Its construction took so long that competition for the contracts to make the XB-35 and XB-36 occurred two months before its first flight.
The plane finally flew on June 27 1941, more than three years after the construction contract was awarded. In 1943, the original Wright R-3350 engines were replaced with Allison V-3420-11 V engines. After completion of testing, the XB-19 served as a cargo carrier until it was scrapped in 1949.
So a B19 is something that is experimental that should be canceled, is extrememly expensive, obsolete before it is finished, behind schedule, and will eventually be scrapped.
Sounds about right.:)
ROTFLMAO!!!:laugh: :D :beer:
. What is it about flying that justifies forming a union? It's not too often you see guys with four year degrees forming bargaining units anywhere other than aviation ...
How about Doctors... they have the AMA.
How about NFL players? NBA Players?
Pilots are the STARS of every aviation operation. Just like the pro sports player associations.
only thing this idiot has ever said that makes sense..
I've been saying that for two years. I've repeatedly made the statement, if you want to fly for a union carrier, do your research and fly for one that matches your needs.
Unions want you to think that if you are not happy at your non-union carrier, just bring one onto the property and all will be fine.
Nothing could be further from the truth.
The FLOPS guys are experiencing it now.
Two years ago I stated that there would be at least 3 years of turmoil, a stagnant company and that when the pressure is on the most is when unions react the worst.
All of these are now coming home to roost, and I hope the industry is watching.
Economy is slipping, 1108 didn't get it done and the FLOPS pilots are in deep turmoil judging by the posts on these boards.
If those pilots that wanted to fly for a union carrier had just gone to NJ, they would have been so much better off today.
My guess is that they didn't go because NJ didn't want them, and they knew it.
You can't be comparing a pilot to a doctor, NFL or NBA player are you?
The only thing that a pilot has in common with a doctor, NFL or NBA player is that none of them need or require a union to be good at what they do.
....So a B19 is something that is experimental that should be canceled, is extrememly expensive, obsolete before it is finished, behind schedule, and will eventually be scrapped. Sounds about right.:)
:D SHACK!! CD SCORED A DIRECT HIT!
And Gunfyter rolled in with great back up!!
men arent born with vaginas, but if you keep bitchin your gonna grow one.....
uhh.... Jetblue, Skywest and Flexjet?
(Was that a trick question?)
Flexjet does not have 500 pilots. And according to some of the posters claiming to work there ... there seems to be issues with Crew Rest requirements....
JetBlue and SkyWest.... AirlinePilot Central shows pretty sad pay for pilots considering equipment. Also it shows a union drive going on at JetBlue right now....
Best you can come up with?
I think I'll stick with the union.
You do that.
It'll make the rest of us feel much more comfortable.
Last I knew,Flex had over 500, airlinepilotcentral has them at 485. Close enough.
We've seen what unions have done to other large regionals such as Eagle and Comair. I'll take Skywest thank you.
JetBlue still has a way to go, but in consideration of the industry, I'll take the 121 carrier over the fractional after working in both.
Delta is the least unionized legacy carrier.
How do you stack up against Delta as a company, not just a pilot union? I know that you don't consider that like I do, but that is a consideration.
You're non-rev privs holding up well?
non rev priv.s?
You're non-rev privs holding up well?[/quote]
Non-rev privs.?
Are you joking?
That's almost an urban myth today.
Go on a vacation non-rev?
With the stress of getting there and back, within days of each other, no way.
Also, when/if you get to where you're going, how to pay for lodging?
Spouses, kids and family are only gonna put up with that stress a couple of times before they wanna stay home.
Non-revving is great! Ride in the back of a Falcon or a X with your family.Have taken Pilot's families, mechanics families and office workers families. Non-scheduled so be prepared to fing your own way back but if you are flexible you can usually fingd your way back with 21 days off for vacation.... But why not just use your Airline miles to get home on a reserved seat after staying in a Hilton or Embassy Suites with your Hotel points?Not many here would opt to return to the 121 world.
Funny how you twist those facts. Yes Delta is the least unionized as a whole company. But the pilots are very unionized. I know many of them and they are as hard core as it comes. Hel!, the DeltaPilots Union torpedoed the NW/Delta merger! That is FACT.
Stop spinning you troll.
edit:
Non Rev!?! Are you fking kidding me!?! What a joke. Been there and done that back in the day when it was reasonable. Still sucked. You can add that to the dog pile with the stupid hat and JS privileges. I will use points/miles and a decent paycheck to get where I am going.
Get a clue you 80's throwback.
edit 2:
Isn't skywest on the bubble?
edit:
edit 2:
Delta/NWA was been slowed down, not torpedoed. On top of that, was that something to be proud of? I think not.
FACT: Just this morning USA today had an article stating that the merger is about to happen anyway and the unions are going to have to slug it out on their own.
Being the least unionized allowed them to weather the storm better than any other major carrier.
I've had the points and the non-rev at the same time. I'll take the non-rev thank you. I'll admit the points are nice, but I travel too much and burn them too fast to rely on them. We've never had a problem to get where we wanted to go to. A lot of experience goes a long way.
Living in the 80's? :laugh:
Unions don't have the strength that they once did and is why they are overated and outdated. You need to live in this century, not the last one.
With the economy the way it is, 1108 needs to get off it's high horse and get it done. They longer they wait, the worse it gets for them. It's a new century.
Two thirds of the pilots at FLOPS voted the union in and have gotten exactly what they asked for. They've stagnanted the entire company, got three years of turmoil and have ineffective union leadership that is simply acting as all union leadership does under pressure. They are going to not react and let everybody just languish in a stagnant company that can't do anything while the union just does nothing.
Quoting Butt Boy B19
Hawker Dude
Dime Line
GunFyter
My brothers, et all who still are quoting butt boy B19, many of us have cut this jerk off and placed him on our ignore list. Not seeing his constant dribble disrupting threads is a great thing, you should try it. Until you come to that point please do the rest of us a favor, if you must reply to this mooron please do not include a quote. The jerk has proved again and again that he has nothing to contribute on this board or in any discussion.
Please help us sweep butt boy B19 under the rug.
Thanks:beer:
I second the motion. Lets all get behind the movement of getting rid of the troll. He obviously gets off on the entertainment that responders give him.
DON'T GIVE HIM THE SATISFACTION.
Putting words in my mouth.
I was writing to your spinning that Delta was the least unionized. You can have a fully Unionized carrier that is weak. Or a less Unionized DAL that is very strong. Case in point, DAL. The Delta Pilots are very strong within ALPA.
We are talking about pilots and I really am not interested with other groups. I know that is your new angle, the poor other workers. Just keep that line of crap in mind when you shove your next cutback down the poor other groups throat.
I have seen this FUD before.
And yes, it is a good thing if the Pilots at DAL were going to get the short end of that merger. It may be good for the upper management folks, but again the line folks get screwed. Regardless, it is all business, so if the delay helps the pilots in the long run, then patience was a good business decision for them.
As far as living in this Century. Is that why NJA should stay with the IBT? Funny.
You are talking in circles. Crazy talk.:nuts:
Wow! I just used the ignore function for the first time.
I feel like I just had a colonic.:laugh:
For those that continue to feed b19...
Here's a good piece of advice from Mark Twain:
Never argue with a fool... onlookers may not be able to tell the difference.
These threads are just getting consumed with his garbage. Think about how devastated he would be if no one acknowledged him... what better way to show disregard for someone... he talks and no one listens or responds. Spend your time on relevant discussion of value and leave the trash where it belongs.
True... however, I'm talking about the really nasty, old, smelly, rotten, pungent, moldy trash the truck should have picked up a long time ago.
