Flex's new bases
Mostly this. Peak will suck. More than normal. You'll have to watch how you end your bid months now as the optimizer tries to front load each month for some reason I have forgotten. And 8-4-8-4 is possible, but keep in mind other things like 5-3-8 will now be a scheduling possibility. Fans of the 5-3-6 can now up their game.
The bases are a good thing. I think that jacking with the bid rules will have unintended consequences that seem minor now, but will create a lot of frustration down the road.
We should not have to give up days off/longer rotations to get more bases! All of these bases are MAJOR CITIES and don't warrant this schedule change! The bases would have happened eventually because when the hiring starts again know one will come work here and move to one of 6 bases! (This has already been proven in the past) so to remain competitive they would have to add them either way. Also no Flops guys are going to come to the Flex side and uproot family and to move to one of our stellar 6 bases. So what they are doing is taking advantage of the situation and getting something for nothing.
Bingo
...but our longest rotation is no longer than your average rotation....
You guys help set the bar for our long rotation.
This is true. However, In a 31 day month on a standard 8/7 schedule, we can only work a maximum of 17 days. With 8/4/8/4/8/4 you could potentially work up to 23, and your shortest time off is way less than our 7 days. You guys are setting 2 new bars there.
Someone who gets it.
I am not sure how we could work up to 23 days.
8-4-8-4-8-4-8-4 is not an option.
You can only be forced to work up to 16 days in a 28 day bid period. So during a 31 day month the most they can force you to work would be 19 by my math.
The bar has not been changed, you are just unfamiliar with our bidding rules.
TWA is right. We have a different bid system and the yield has not changed. If you fly the max every bid period, you will fly 13x16=208. Minus your vacation, so I'll use my three weeks and get 193 days. From a practical standpoint it is lower for me because I don't bid max all the time. That will not change. The mix will change if I bid a secondary. Since pretty much everyone knows who I am (I type the way I talk) my MSP June-September bid is known to most of you. During that time my mix will change and I may get some 8-4 rotations, but my max of 16 days per BP will not change. I'll post my results, if anyone wants them, for the whole of next summer. Also, since those secondary bases are bases, you can voucher in and out for a rotation if you want. So I plan on visiting the parents in PHX this winter once or twice. Got that straight from the horses mouth too. You are not giving up days off for this change.
First, let me say I hope the see things improve in lots of ways for you guys because I think this will provide leverage for my union's negotiators when they head back to the bargaining table this fall.
So within that context I have a few questions. Yes I'd like to see the results of your upcoming bid, but I'm wondering are you a fairly senior guy? Will a junior guy be disproportionately disadvantaged by this new basing/scheduling system. Have you guys ever worked 8-day rotations in the past? Even if this new system doesn't result in more annual days worked, doesn't a 8/4 seem kinda harsh? Do you expect many pilots will change domiciles given the more onerous schedule?
Yes to all (except for the seniority since I don't know who he is).
A junior pilot may be forced into longer rotations than he is used to unless he normally bids 7 or 8 day rotations. As it is now, no one can be forced into anything more than 6. This will only be the case if you opt to be in one of the new secondary bases.
We currently have the option of bidding for lines that have 8 day rotations that have a minimum of 5 off, I believe. I never bid them so I may be inaccurate on the minimum time off.
8/4's would suck, yes.
I believe there will be plenty of takers on the bases. Maybe not immediately since lots of guys have families and homes etc that will take time to make the move. I for one will be making my last drive to Dallas ASAP.
Forced
Wow! "FORCED"
Interesting.
Company offers a policy change. Pilots vote. Change occurs or not.
So, no negotiations with regard to the proposed change. Take it or leave it. No direct supervision by pilot representatives (mainly because there aren't any) over the voting process or results.
Sounds real fair.
Especially that part that requires 8 days of work to get 4 days off. Now that's a great schedule that the rest of the pilots in the fractional industry will appreciate.
I wonder how Flight Options pilots negotiators will handle that when they go back to the table. Perhaps the Flight Options pilots will send Flexjet pilots thank you cards for putting them in that bargaining situation.
Get those votes in! You have until the 14th at noon!
I am definitely unfamiliar, and apparently I misunderstood, so fair enough, I stand corrected. However, your shortest time off is still way less than the 7 days we get, and 19 days is still 2 more than the max of 17 we can work, so you are still setting 2 new bars. The whole fractional industry thanks you for that.
Wow! "FORCED"
Interesting.
Sounds real fair.
No one is forcing us to do anything. If there's anything we don't like in the proposal then we're free to vote "no." Have you ever voted for anything that had something in it that you didn't particularly care for (such as your current CBA)? Or do you just vote "no" to everything because of your spite for management? Overall, it's a huge increase in QOL for many of us and my QOL having a negative bearing on your next negotiation session doesn't really concern me.
I'm not sure where I bid right now. There has been some movement. Last I looked, I bid 37 of 52.
The total days worked hasn't changed with the proposal. You can still get anywhere from 14-16. Senior pilots usually like lower total days which result in the junior people getting forced to 15 or 16 based on seniority.
If you are senior and get a 14 day line the 8-4-6 would be followed by 10 days off. That is significantly more than the 7 days off you get, but averages out to your 7.
I guess we at FJ have been lowering the bar for years based on your logic. If only the white knight IBT could come and save us.
Wow! "FORCED"
Interesting.
Sounds real fair.
It is a term our junior pilots use when they don't get anything they bid for and are given a line based on thei seniority. They can't be assigned a line with less than 14 or more than 16 days out of 28.
Thus the term forced.
Kinda like in the 121 world where if you are junior enough you are forced on reserve because there are no lines left when they get to you.
Personally, I 'm not a fan of the proposal.
I don't see why they can't make a standard schedule work for crews based in IAD, PHL, CLT, MCO, etc.
For the smaller airports the potential to work longer rotations seems reasonable but the 4 days off after 8 isn't.
Some will argue the proposal should be adopted in the hope that changes can be made later, I'd rather see an agreement approved that is fair from the start.
As for being FORCED to do anything, we aren't. The standard schedule is 16 days on out of 28, the minimum is 14, that hasn't changed. The 8 day trip isn't REQUIRED, it's now a possibility. During bid periods, not months, that have training and/or vacation, an 8 day trip will be difficult to schedule. Crews based at the alternate airports will still have bid choices that don't include 8 days lines, if you're senior enough and don't want to work them, don't bid them. If you're not senior enough to chose your schedule and don't want the possibility of working longer trips, don't move to an alternate airport.
I don't like the proposal and won't vote yes, but if it passes, it's not the end of the world. There may be doom and gloom coming but this isn't it.
None of you guys at FLEX are gonna like one bit only 4 days off after 8 days on. You will see your work load pick up in the future, you will be tired after 8 days.
Some already do it quite a bit. It was only available on yellow (non-standard) lines. I do believe this will not be an issue for those who are senior, although it may affect new hires. new hires will have a choice to choose the job or not based on this info.
Uh. It means the rest of us on the 16 days forever train with minimum time off will see ugly scheds if we choose to move. Remember, these are green lines now. Bid something you want and you can be awarded 4 off after 7 or 8 on. I really dislike that part.
Like I said, it's not just about peak. We're pretty much busy all of the time between everyone having 3-4 vacations and our lean staffing. Be very careful how you transition from one bid period to another. If you actually have the ability to influence it.
Does anyone know how the new bases were picked and were the line pilots involved in that selection? Was there any input from the pilots on the number of new bases?
I think everyone is generally thrilled with the list.
I'm glad you guys are thrilled, but where did the list come from?
I don't understand why you guys can't be happy for us, we are finally adding bases.
You just won't be happy until we aren't.
We have been asking for more bases for years.
They added 2 new bases under Bombardier, DEN and ORD.
Now under DAC we are adding 33 more bases.
It seems to me that if I were to win the lottery all you would do is tell me how much laying my taxes would be and did I get to negotiate on how much the lump sum payment option would be.
Where did you get this information from?
Is this just another fabricated statement used to validate your point.
4 years at RTA (Manufacturing company, just like Bombardier) and then 12 years here at Options.
At RTA didn't matter much if we flew or not we were the sales arm of the company, at options the company doesn't make money unless the plane is in the air. Not rocket science the plane moves ya make money it sits ya don't. When we merged our flying picked up exponentially, very big difference between the two company's.
So...Fabricated statement...no... experience.
I wondered this as well, so I asked? In response, I was told by the D.O. that the new bases were largely based on those most served by the airlines. How they cut it off at 33, I don't know??? Little Rock, and maybe a couple of others (OKC?), were added due to the amount of crewmembers who live in and around those areas. There was no direct input from the pilot group other than voicing for years where they'd love to see bases based on their commutes. Hence, Little Rock and Oklahoma City.
During the last several years under Bombardier we were a self contained business model. We only made money when the aircraft flew. And suprise, we made money.
Our flying has picked up before the DAC purchase. It is due to the economy, not being sold.
There is not much more flying we can do we the airplanes we have, hence why we are gaining a lot of aircraft this fall and starting to upgrade to captain again. I am sure hiring will be in full swing this fall also. Will be interesting to see how many current FO pilots are willing to jump ship to FJ.
Ok....
