Colgan overheard in EWR today
  • Thread starter Thread starter slackass
  • Watchers Watchers 27
The FSM says 20Kts MAX with the following conditions:
*Nosewheel steering operative
*Antskid operative
*Flight spoilers operative in both modes
*Bleed air off
*Takeoff with flaps 10 or 15
*Takeoff performance caclulated
*Antskid operative
*Bleed air off
That is correct. I didn't feel like typing all of that.
I wouldn't do the same for an instrument approach because I can go down to DH as long as I have the vis by the FAF, If I see the runway at DH, I can land because I will have the required vis. Tower can say whatever they want as far as vis goes after the FAF and I can continue legally as long as I have the flight visibility during landing.
The winds on the other hand are changing constantly, especially on gusty days. I can't disregard tower winds and say "Yeah but the wind sock only showed 20." You get guys asking for wind checks and tower gives the winds when he clears you to land. I don't want an ATC recording of a 21 tailwind should something happen on the runway. When it gets close to the limit, it could just as easily be over the limit when I land. It is not a matter of whether the airplane is capable. I know it is, and it could easily handle more. It is a matter of covering your ass. If the FAA ever looks into your flight, do you want them to see that you exceeded the limit when you landed?
My question for those who don't see my logic... Would you land with a 20 knot tailwind with an FAA inspector in the jumpseat? It is legal yes, and it can also be safely done. But are you going to then calculate the tailwind compenent every time tower gives the winds to make sure it is not 21? Wouldn't it be easier to land on runway 4/22 and not worry about the tailwind component?
For those of you who would land with a 20 knot tailwind with an FAA inspector in the airplane... Why would you choose the runway that is 1 knot away from a possible certificate violation?
Visibility changes constantly as well. there have been 2 occasions that I can think of where I had to go missed below mda or dh due to a sudden drop in in-flight vis. To me, having to execute a go around due to a wind change isn't any different. If the winds are within the required limits, then I will land. If the situation changes I won't.
I don't fly the plane any differently if there is an FAA inspector on board. My job is the same no matter who is watching me. Why make things complicated and change the way you fly based on whether the FAA is watching or not? Follow FARs and SOPs and you're good to go....simple.
A 20 kt tailwind is within my airplane's limitations and my personal limits. If the winds are all over the place then it may not make sense to take the tailwind landing. But, if there is no reason to believe that they will change, other than a fear that "it could happen", that doesn't seem like a valid reason to me. Lots of things "could happen" when we fly, but it doesn't prevent us from using the airplane to its full capability, within legal and safe limits.
I agree, that given the choice I would take the runway that's lined up with the wind. However, in EWR, it's often a choice of take the tailwind or stay away. If it's legal, and safe, I'll take the tailwind.
He knew it and was taught it but, it was his 4th training event in one year due to displacements and he had just come off the CRJ where you use them on every landing. Also, in training you use them on 95% of the landings because you are either single engine, on a wet/contaminated runway, or on a short runway, so there was a big negative transfer of learning.
Ahhh damn that sucks. I can see that. Unfortunate.
You must be one of those "wind check" guys. What a silly bit of logic. By the same token you probably shouldn't accept an approach to minimums. What if the visibility goes to 1/4 while you're in the flare!.....oh no!
seriously...ever try looking out the window and see where the nose of the plane is pointing?
would ya please pull ya diks out of colgan's buut... to the tool that started this thread, you're gonna F'up big one day..get ready tool to fill out that report.
Yes, every time. What's simpler, one operation on a calculator or a full fledged go-around + resequence + rebrief for another runway. An inspector would laugh at you, then ask "what the hell was that all about?" during the debrief. My operation keeps crosswind component charts handy at all times, it's a no brainer. It also easy to determine the maximum wind value from a given direction, and then you know within your limitations until the wind exceeds that.
Saturday I heard a Mesaba 900 crew calling their dispatcher on Airinc because they couldn't do the math on a quartering tailwind component. My FO and I laughed all the way across Colorado.
Is that 20kts the steady state winds or does it include the gusts?
Wouldn't you want to take the more conservative (read: safe) side and use the gust factor?
don't you mean the nine
i guess that defines utilizing all available resources
I would have refused runway 11. Although you are a full 1 knot from the limit now, what if tower calls the winds from 320 with gust to 24 on short final? Are you going to pull out your E6-B in the landing flare to see if you are legal?
If you have a tire fall off on landing (hey, it could happen right?) the FAA might just take a close look at the flight in question. They might just decide to violate you for landing with a 21 knot tailwind.
...Saturday I heard a Mesaba 900 crew calling their dispatcher on Airinc because they couldn't do the math on a quartering tailwind component. My FO and I laughed all the way across Colorado.
There's that classic "cover my ass" (said with nasal Fran Drescher-like voice) airline pilot mentality we've all come to know and love. These are the same guys who wil take what should be a short nap of a recurrent class and turn it into a 4 hour discussion on the "what-ifs" of hazmat and personal oxygen...:uzi:
