Look at the windsock and fly the airplane.
You must be one of those "wind check" guys. What a silly bit of logic. By the same token you probably shouldn't accept an approach to minimums. What if the visibility goes to 1/4 while you're in the flare!.....oh no!
I have never asked for a windcheck.
Your visibility analogy is a silly bit of logic in itself.
I would have refused runway 11. Although you are a full 1 knot from the limit now, what if tower calls the winds from 320 with gust to 24 on short final? Are you going to pull out your E6-B in the landing flare to see if you are legal?
Prohibiting the use of reverse thrust would be like prohibiting the use of ailerons in flight. Or prohibiting the use of the landing gear.
Maybe, someone is thinking about the use of reverse thrust inflight being prohibited.
Is it prohibited there or just not encouraged?
American Eagle prohibits the use of reverse (idle) on the erj on any dry runway over 7000 feet. Some TSA jets don't even have reversers.
I obviously disagree.
Your contention is that one should have an extra cushion when landing in winds close to the airplane's limits for fear of a chance that those limits might be exceeded at the last minute. So, why wouldn't you do the same for an instrument approach?
More of an "operational culture" thing. Nothing prohibited that I am aware of.
If it's a limitation, shouldnt he have known it?They don't want the mx costs associated with maintaining the reversers. My roommate busted his type ride for opening the buckets because he (violated a limitation) yes, it's in the limitations.
