Colgan Airlines stall recovery
F/O
Smells like....
Apparently it is the following procedure:
1) do not add power.
2) pull on the stick pusher as it is trying to push forward.
3) retract flaps.
4) retract gear.
Yes, I feel these guys are being pretty badly hammered in the media. But someone please help me to understand this...
They just released the transcripts from the FDR.
Looks like they had a couple of real winner pilots on that flight.
The copilot was saying, on the recorder, ((paraphrasing)) "I've never seen ice before, I've never had to deice before, I never want to see ice like this, I never want to make a deicing decision like this, I would be afraid we were going to crash."
The captain failed 3 flight checks before this flight, in recent months.
When will airlines stop hiring women just because they are "women" and cannot truly do the job. And when will they stop keeping crap pilots on the line just becuase the scumbag unions will cause trouble. You fail a flight check, you get one more shot....if you fail again....you're ass is fired for good. Peoples lives are on the line, its not a friggin joke. The airlines have some of the worst pilots in the world, why??? Because of the scumbag unions. Wonderful!!!!!!!!!
What a pathetic industry the airlines are. Its laughable.
You are wrong Fly91. She was saying what she was thinking on her first day of groundschool at Colgan. Had you read the CVR rather than just posting what the media thinks it says, you would know that.
Too bad Colgan wasn't a union airline at the time of this crash or in all of the checkride busts.
Way to make an appropriately backed up statement. ;)
Colgan FO:
22:16:26.6
HOT-2
uhhh.
The stick shaker started about a second later. You think she saw something?
Colgan FO:
22:16:26.6
HOT-2
uhhh.
Sure do. But maybe her mind was still spinning over the past 57 minutes of non-stop conversation. There was literally not 1 minute of silence in the cockpit the whole way to BUF.
I've been in those kind of cockpits. Makes the day go quicker, but can cause problems.
If you look at the transcripts, you'll also notice a 26 second period from "22:15:59.5 CAM [sound similar to decrease in engine power] " to the beginning of the stick shaker.
Does Colgan set a speed bug anywhere for what speed you intend to fly? Or is it just set a Vref+ when it's briefed?
Really a breakdown in CRM. Non-essential chatting has its place on every flight, but this wasn't a spring-time flight in VMC conditions. A little more vigilance should have been paid to the changing conditions, especially after noticing a significant buildup of ice on the aircraft.
3) retract flaps.
4) retract gear.
No it is not.
THESE are their actual stall profiles:
http://www.ntsb.gov/Dockets/Aviation/DCA09MA027/417477.pdf
He did add power, retract flaps, and gear. The question/problem becomes regarding pitch. YOU weren't there that night, so don't judge. The airline I work at, and Colgan too, train you to the stick shaker for stall recovery. No one ever shows "well, and when the pusher goes off, then do this...." in the sim. No one takes it that far, and Colgan said that the FAA doesn't require it to be taken that far. Now who are you to judge what you would or wouldn't have done once the pusher activated only 1000 feet above the ground.
If pilot error is to blame, it is the training program that should be primarily blamed. Stall profiles at airlines need to be changed. And not to mention, fatiuge and scheduling rules need to be changed, but the FAA will not give a rats as$ when power airline lobbyists use their "pressure."
I haven't been following this story. Is the cause anything to do with an Ice Contaminated Tailplane Stall?
Nope, however, his recovery technique appears to be a very similar response to one.
Unfortunately, he was in normal stall condition...that they put themselves in. Retracting the flaps immediately after stick pusher is a very bad thing to do... for a normal stall...
Speed was down to the 130's at flaps 5 just before the stick shaker activated. That is approximately the Vref when fully configured for icing conditions.
Raise your hand if you've been taught by a Part 121 airline during the stall recovery section of simulator training to not lose altitude at all costs, no matter how long you keep it in the shaker, how much you ride the barber pole, and how close you get to a pusher.
"Don't let the nose drop!"
Actually they were at flaps 15:
22:16:23.5
HOT-1 flaps fifteen before landing checklist.
22:16:26.0
CAM [sound similar to flap handle movement]
As I remember it's Vref and GA. But it has been 7 months.
And what do they tell you when you pitch up 30 degrees?
A factor not discussed is the stupid "Increase ref speed switch." When in icing conditions and turned on it raises the low speed que about 20 knots hence the necessity for getting the corrected ref speeds for Icing conditions, or just remembering to bumb up your ref speed +15/+20 depending on flap setting. When the shaker occured it was a system manufactured event due to this little switch being moved to the on position. The stall was a result of the sudden pitch up. When the shaker occured there was still plenty of flying speed.
So if the low speed que goes up there is still a visual indication, right? You'd still just keep the airspeed out of the red?
Have to agree with flyf15, the current protocol demands that you not lose altitude during stall recovery, which requires you to pull the stick back to recover from a stall! Is this ATP PTS? If so, then the blame lies with the FAA. But of course, this whole thing will be blamed on "nonessential communications below 10,000."
I do not like reading all this speculation. Let the FAA do their thing and have some respect for everyone involved. You armchair experts are just giving ammo to all the other know it alls. Yes it is looking like mistakes were made, but what we should take from that is how to better improve our programs.
Yeah, you'd see the red floor come up, and when the airspeed dips into it, you get the shaker.
It is a bad design in my opinion with the increase ref speed switch. The switch can be on, speed can be bugged ref +20 and if it's turbulent like it is in the northeast so often, you can get +/- 20 kts movement on your airspeed and it's a very sensitive A/S ind. Every little bumb you're seeing +5 kt fluctuation.
At my airline, stall recovery training encourages minimal altitude loss, but does recognize that a couple hundred feet may be lost during the recovery. Recovery focuses on decreasing the angle of attack and leveling the wings while simultaneously adding full power. Secondary stalls are frowned upon heavily and will cause a repeat of the stall demonstration.
From faa.gov ATP PTS:
4. While maintaining altitude, slowly establishes the pitch attitude (using trim or elevator/stabilizer), bank angle, and power setting that will induce a stall.
5. Announces the first indication of an impending stall (such as buffeting, stick shaker, decay of control effectiveness, and any other cues related to the specific airplane design characteristics) and initiates recovery (using maximum power or as directed by the examiner).
6. Recovers to a reference airspeed, altitude and heading with minimal loss of altitude, airspeed, and heading deviation.
7. Demonstrates smooth, positive control during entry, approach to a stall, and recovery.
No 121 or regional experience, just military and 135, but stall recovery technique has been pretty consistent: full power, ease back pressure, minimize altitude loss. Knowing what little we know so far, it doesn't appear we can blame the FAA's stall demonstration requirements for this one.
MofY
22:16:23.5
22:16:26.0
22:16:11
Speed and configuration was OK till LOC alive 180kts flaps 5. He went flight idle and condition levers (props) max. That's a great technique to kill airspeed when doing 250 knots at the marker (high and fast). Doing that at 180 kts and level is not a good technique. He lost nearly 50 knots in 13 seconds. He didn't increase power till shaker.
22:16:24
He called for flaps 15 when he was already at 137kts... no power increase. The sound similar to flap handle movement happened 1 second later at 135 kts... way too slow before flaps indicate 15.
Here is the animation.
http://usat.gannett.a.mms.mavenapps...4b4e3f6b392e8&maven_referralObject=1120901984
BINGO! This is true. Too bad people with journalism degrees at, say, the Washington Post missed this point.
"ease back pressure": not initially, because this hits it on the head:
"to not lose altitude at all costs, no matter how long you keep it in the shaker, how much you ride the barber pole, and how close you get to a pusher."
"Keep it in there, son, hold it, HOLD IT! [shaker continues to go off]. that's it, hold it! now finally speed is coming back up, ok, now pitch down and keep it within a 100 (100 feet, plus/minus). Wow. Gone should be those days. Our airline has already done away with official stall profiles, surprisingly, right around/after the Colgan crash. In the sim, get ready for full stall recoveries, to the pusher.
Have some consideration JERK
Well I was sick of listening to the "experts" on the news so I thought I'd get on flightinfo.com and listen to the TOTAL (EXPLATIVE) MORONS.
Goal accomplished. Recommend to moderator to ban this tool from FI. Anyone who would post something like that deterioriates the discussion beyond acceptability, and that is REALLY SAYING something on this website!
Never been told that and never taught it like that.
