twighead
Pan Pan
- Feb 5, 2006
I'd watch it before my next flight then.....
Don't worry I already did earlier. That's how I knew I had never seen it before.
I don't know about the pusher on a Q-400, but on the ATR the pusher is not tied in with the radio altimeter and is never inhibited in flight except for 10 seconds after takeoff.
Tail stall occurs when the angle of attack goes excessively negative.
Main wing stall occurs when the angle of attack goes excessively positive.
The pusher only fires at high angles of attack. The pusher should not fire during a tail stall... however if a tail stall leads to an upset it is understandable at some point during the attempted recovery the angle of attack could exceed the amount required to fire the pusher.
As someone of a friend who works for the NTSB this is what REALLY happened.....
autopilot was engages, one of the wing's de-icing system was working, the other did not work (due to a mechanical failure that is still under investigation at this moment....). The crew lost control of the aircraft as it spiraled to the ground in a nose dive from loss of lift on one of the wings.
A lift imbalance due to one wing unable to melt the ice off caused this crash!
Godspeed to all!
I'm on dial-up. What does it say?
Godspeed to all!
Nope... At least not on the DHC-8-100/300. Bombardier says start the boots at the first sign of ice on the airplane. I have never seen "bridging" in any turboprop I have flown. Occassionally, you will run someone who claims to have seen it, but I think it is sort of like the Loch Ness Monster... It doesn't really exist.
I think you may be oversimplifying things a bit there.
Tail stall occurs when the horizontal stabilizer's critical angle of attack (negative angle of attack) is exceeded or there is airflow separation about the horizontal stabilizer due to ice on the leading edge. The horizontal stabilizer (tail) experiences the highest demand for negative lift (tail down force) and the most negative angle of attack when the wing's center of pressure (lift) is furthest aft of the center of gravity. This occurs at higher airpeeds and when the flaps are extended. If you think about it, when you accelerate or when you add flaps you need to push on the yoke, or add more tail down force to keep the nose from rising. This act of pushing is what increases the angle of attack on the tail (in the negative direction if you will) and can lead to a tail stall.
Maybe a name change to flight jock itch is warranted?
Something doesn't sound right here.
when the NTSB releases the investigation results I am going to relink that thread to my original post. You will all see that I am 100% accurate.
Have a nice day! And believe what you want, I KNOW the truth and having nothing to lose by "leaking" it.
I am the great cornholio I need T.P. for my bunghole.
I hope my bungholio does not get polio.
I come from Lake Titicocka where I never saw any true "bridging" I always liked to wait for a decent amount. If you blew too early only small chunks would come off leaving a nasty looking with lots of big chunks sticking to it. If you let build up then big chunks would break off and leave you with a pretty clean edge. I also think that waiting for approx 1/4 to 1/2 inch of seemed like it did a better job of getting the clean with smaller amounts on the leading edge. I am the great cornholio I need T.P. for my bunghole.
I come from Lake Titicocka.
