Colgan 3407 Down in Buffalo
Also, have any of us driven an airliner, either for real or in the sim, into a stick shaker with the autopilot on? I can't remember doing so. I would imagine that having the a/p kick off as the stick shaker fires could lead to some interesting reactions!
This is a maneuver that they used to train at ACA, the reason is because they had an accident in 1994 on a J41 in CMH, where the crew stalled the airplane on approach with the autopilot on. It was quite a different stall from what you normally saw. It has been a long time, but I think that the autopilot warning was inhibited because the stall warning took precedence. There was some question about weather or not that crew realized the autopilot had disconnected. Anyway, it is an interesting question and good to train that way.
Maybe there's just something wrong with me.
I understand the concept of approach to stall recovery with minimum loss of altitude. Shaker is an approach to a stall.
I do not understand a concept of zero loss of altitude at any cost, and difinetely do not believe that is possible in the real world of line flying - especially in IMC. Maybe you can do that neat trick in simulators - but it's still a trick.
Nobody intentionaly activates a shaker in the real world. Simulators are wonderful tools but they are not real airplanes. You don't ever practice stalls in a real airliner full of people.
I just can't imagine a training program that would tell you to put the yoke in your stomach at the sound of the shacker because you might lose 100 ft of altitude, or even 200 ft.
Also, I do not understand how a pilot looking at an ADI that shows the nose rising rapidly would continue to apply back pressure in hopes that would change. Maybe someone studying for an instrument ticket - but an ATP with several thousand hours and assisted by a compentent F/O?
Putting the nose at the level-flight deck angle and powering out of the approach to stall makes sense to me.
Sucking the yoke into my stomach in an effort to avoid losing some altitude, just dosen't make sense in my head.
I've been driving airplanes since I was 20 years old. 20 years of that was in airiplanes much larger than a Q-400 - some with popellers and some without, followed by another 12 years in airplanes of similar size. I don't remember anyone ever telling me to do that and if they had I'm real sure of what I would have told them to do with that idea.
If that is what were teaching pilots to do we'd better revise that program in one hell of a hurry.
Training needs to fit the real world. If you near stall at 200 ft AGL in anything but a toy airplane the ground will come up and smite you 99/100 no matter what you do. 121 has nothing to do with that.
If you lose 100 ft anywhere above 500 ft, chances are it wont - again regardless of 121.
I just have a hard time understanding that people would intentionally teach this Captain how to kill himself and his passengers.
Of course none of us has heard the CVR - hopefully it will provide the AI's a better understanding of what took place - if they said anyting relevant after the shaker went off.
At this point I'm a lot more worried about what happened after the shaker than how they got there in the first instance.
Apologies for the rant - it just doesn't compute.
Surplus,
Spot on as usual, but I'm afraid that is how it's trained. It's the FAA, not the airlines. We do it the same in our 135 training. I've thought it was stupid and dangerous since the first time I did it. In a clean CRJ, they want you to hold the pitch at 12-15 degrees as I remember, don't let it drop at all. Very standardized and neato, but dangerous as hell in the real world. Even in the sim, I have seen secondary stalls and pushers activated due to this wonderful technique.
i know on the boeing, the trick is to watch the angel wings come down and you maintain pitch to about 5 degrees and ram it up.
like you said, sims tricks...
I think most of you folks are on to it now. Also, consider that the spread between shaker and pusher could have been very narrow with a little ice contamination on the airplane.
Many really good comments.
In a transport with all engines operating there is tremendous excess thrust at landing weights. There's no reason to lower the nose because of that excess power. Start thrashing around with the yoke and you're going to induce pitch osolations. Radar power and roll wings level and hold what you have in pitch...if it is a normal flight attitude.
Unless it is an upset of course and that's a different situation
Belchfire, I agree with you. In a normal level flight attitude, at any altitude below 10K (and that's very conservative), whether turning or not, add max power, hold the pitch you have and roll wings level. You'll power right out of the shaker or buffett. If you yank on the yoke you virtually guarantee pusher activation and things are likely to go TU in a big hurry.
If you upset at low altitudes its guaranteed the ground will come up and smite you.
If you do it at higher altitudes it is highly probable that you will cause structural damage or simply tear the airplane apart in the effort to recover.
If its a jet with rear engine placement (and you do recover from the upset), the probability of a flame-out on 1 or both is very high. Better hope you're not over the Andies, the Alps, the Caucauses, the Rockies or those giants in Asia. Many would require drift-down before you can even attempt to re-light.
Unless you're very close to the ground, and I mean two hundred feet or less, it doesn't matter one iota if you lose 100 or 200 feet in the process. The objective is to keep the wing flying and avoid stalling it.
There's one 4-eng proppeller transport that I once flew (Not a C-130), which at low landing weight had so much excess power that you could literraly nurse a go-around with 3 inop. Not something that was recommended or probable but something that was possible under ideal conditions. With 2 out on the same side it was not extremely difficult.
There was another (twin), with so much power that the 1st immediate action after engine failure on TO was to reduce power on the good engine - to relieve/reduce too high rudder pressure. I always felt (personally) that the fin/rudder was too small on that type. They modified the tail but the aircraft wasn't really designed for those engines.
According to the manufacturer, the engines on the Q-400 ea produce 5071 shp. That's a whole lot of power for a 55,000 lb landing weight. I would imagine it would have no trouble at all powering out of a shaker on final approach.
This is a very sad story and if what it now looks like proves to be true, the training for this type will require some major revisions.
If this captain pulled hard on the yoke when the shaker went off - it probably follows he was trained to do just that.
If true, I don't see it as pilot error - although I think they will call it that. I see it as being trained how to induce an upset and lose your airplane.
I think the technique taught now for stall recovery - with a flight director - is at the first indication of a shaker is to hold what you have with regards to pitch attitude - this will indicate level flight at the time of approach to stall and to power out of it using all available thrust. Depending on the thrust vector of the engines and the type of airplane, this might require slight back pressure (or slight push over) to maintain desired pitch - but nothing as aggressive as has been suggested might have occurred. The elevator trim as positionned by the autopilot trying to maintain a set altitude with reduced power would also come into play and would have to be countered with - for a rapid increase in thrust.
Yeah, diving the nose to negative 10-20 degrees isn't appropriate. You're gonna be in a heck of a descent at that point. But pulling against a stick pusher just seems so counter intuitive, but being that close to the ground at night, in IMC...
Suppose all the Capt. had on his brain was ICING. He's seen the video or been briefed on tailplane icing in this and other aircraft. As they approach the marker, they get configured and slow rapidly. He's new to the airplane, and fairly unfamiliar with the aircraft's stall logic. Suddenly the stall warning sounds, combined with A/P kickoff and rapid nose down pitch over. For someone new to the aircraft, it has the look and feel of tailplane icing. Looks like he recovered for tailplane stall rather than wing stall. I don't fly this aircraft, so I may be missing something, but I'm wondering if the two different recovery methods weren't confused in his head...
Well, the aggressive pitch-up could be explained in that if he was overriding the stick pusher with brute force, then remembering the SP/AP button on the yoke, suddenly the pusher is gone and all that muscle coming back on the yoke...
There is a delay, albeit a short one, between shaker and pusher. That's where the correct recovery has to be made. Once the pusher activates - it activates for a reason - using the yoke button to override it -in my opinion, is counter-productive. When the pusher activates, the airplane needs to fly itself out of the stall via an unloaded wing.
Well in a tail stall there would be no shaker/pusher. That's the fundamental difference between the two stall types.
How about this:
They get slow, shaker and then pusher comes on.
At some point, the throttles are jammed forward.
The elevator, which was attempting to maintain altitude, is trimmed most of the way, if not all the way nose up.
The initial pitch down is commanded by the pusher and A/P disengagement, but the pitch up is the result of going from <30% Torque to >100%.
In other words, couldn't this just be a trim stall?
Yeh...I know what you're saying. I'm thinking it's been a long day, and he's got "tail stall due to ice" on the brain. A/P kicks off, he's got yoke going forward, and in the heat of battle, disregards the shaker, knowing full well that in a tail stall, he's gonna have to come in with a gut load of back pressure...
Tired....spring-loaded in the wrong direction...thinking loss of hundreds of feet within seconds...
EXACTLY RIGHT A number of posts here have talked all around the subject of how to recover from a stall. Any pilot that has worked as a sim instructor or sim check airman in a 121 carrier's program can tell you two things. One - how a pilot responds to something in the sim is how he will respond to it in an aircraft. 'If he does it in the sim he will do it in the aircraft'. Two - when faced with a surprise in an airplane his immediate response will be exactly the way he was trained in the sim. It sounds simplistic but it has been demonstrated time and time again.
In a 121 training program the way you recover from a stall, and the required performance, is dictated by the FAR's. Appendix F of FAR 121 specifically states the three stalls you will be tested on (clean configuration, take off configuration and landing configuration) and the performance requirement - no loss or gain of altitude and clean up on a specific schedule. It is a constant altitude maneuver. The FARs require you to hold a lot of back pressure on the yoke and power out of it. That is the only FAA acceptable way to complete a Proficiency Check that a Captain must pass every six months. Since that is the requirement to pass a checkride that is the way hours and hours are spent training the maneuver. ​
There is a school of thought that claims this is 'negative training'. Some swept wing, T tail jets with aft body mounted engines are 'deep stall' AC. There is no recovery from a fully developed stall because all five flying surfaces are stalled. In these AC at altitude (no thrust left to accelerate with) the only 100 percent successful way to recover is give up altitude. There is a similar school of thought that emphasizes these maneuvers are simply a 'proficiency demonstration' that you would never actually use in an aircraft. The problem, if these schools of thought are correct, and emphasized in training, is now we provide no useful training for the situation. And that means there will be no telling what each pilot will do when faced with the situation.​
Now add to this discussion the issue of an icing induced tail plane stall that is unique to AC with fixed horizontal stabilizers (most turbo props and no swept wing jets). The immediate response to one is exactly opposite the response to a wing stall. Reduce thrust and pull full aft yoke to move the airflow stagnation point back to where the ice is. Then the tail will start flying again. When pitch authority is regained relax the yoke before you enter an accelerated stall. Fortunately this problem has been well documented for decades and engineers have known for decades how to design tails so they do not have this problem. There are no turbo props in service in the US that are known to have the problem. The A model SF3 was the last AC known to have this problem but they were all modified years ago to eliminate it. The 'B' model SF3 has an entirely different empennage.​
If "icing," tailplane or otherwise, was such a great concern to the crew don't you think airspeed awareness would be among your top priorities, if not your number one priority.
Regarding tailplane stalls, flying faster only exacerbates that situation with increased flap deployment. You shouldn't get a tail stall at only flaps 10, ice or not. Plus the switch which increases Vref by 20 knots gives a big margin with only a flaps 15 landing assuming you keep the wing flying which would be no problem even if you flew a little below Vref.
I'd like to think the crew had something else going on besides "significant" ice concerns or mere lack of airspeed awareness and nobody pushed the power up. (By the way even if that's all it is, I'll wager most of you have been part of a crew where somebody did an "oh sh***" and pushed up the power or some other type of mistake. Mistakes happen. They shouldn't but they do and if it hasn't happened to you yet then it will. If you doubt that please let everyone know so we can avoid flying with you.)
I agree with Surplus1's original comments. Something doesn't seem right about this NTSB alleged "stall recovery" by the Captain unless it was a panic reaction. There has to be more to it (I hope). Maybe even the "5 cent light bulb theory" which someone else mentioned. Classic example.
Like everyone else I eagerly await more "actual facts and data" so we can learn from it.
Great post. I've never liked this approach to stall "training" and believe it to be a proficiency test at best.
Chealander is a loose cannon. He is the same guy that showed up at the SWA 1294 press briefing after the MDW accident and proceeded to treat it like it was a fact finding mission when in fact it was to announce the findings. He made some comments about the pilots that were not at all supported by the text of the NTSB report.
I think that he is WAY out of line wrt this Colgan accident. Speculating and proposing theories to the press. I've never seen an accident investigation handled this way and find it disturbing and unprofessional. He needs to find another line of work and the NTSB needs to get back to their job of determining the causes of accidents and away from the job of feeding the press monster with regular, poorly thought out speculations.
Because I live in LEX and knew some of the folks involved in the 5191 crash, I watched the entire NTSB hearing on 5191. From his remarks and demeanor in the hearing I think Chealander has a real disdain for regional pilots. Chealander spent most of his career with the Air Force, and was a Chief Pilot at American.
Bio:http://www.ntsb.gov/Abt_NTSB/Bios/chealander.htm
I agree that could indeed be a possibility. However, I think most of us will just think "stall" when the shaker/pusher activates. I agree with what the other posters are saying with regard to "reacting as trained", there could be a lot of truth in that.
I am curious that some of the posts indicate that you are pulling on the yoke during stall recovery. All of the types I have flown require you to push forward at the first indication of a stall due to the amount of aft trim that is present. Our current SOP is for minimal loss or gain of altitude during recovery.
It appers from what's been said here earlier that the kind of training you get depends on where you get it. I have no idea how Colgan trains. While I agree with what you said, it doesn't seem as though everyone is doing that.
If the alleged extreme back pressure was intentionally applied by the PF - when the shaker went off and BEFORE the pusher - that would mean that pusher activation was the RESULT of the back pressure - not because the pilot was fighting the pusher.
In other words if what they are saying actually occured - then the pilot's reaction to the shaker was the cause of pusher activation and stall.
When the shaker activates the wing is still flying. There are situations that could make the pusher follow the shaker very closely but airplanes don't fall out of the sky because a shaker went off.
As belchfire said - the time line or sequence of events is very important.
If this pilot was trained to hold altitude at all costs after a shaker event - as opposed to holding pitch and powering out of the shaker - that would explain why he pulled so hard (as alleged). A rote reaction to a training enviroment - another version of conditioned reflex. Pavlov had a great theory. It works for dogs but shouldn't be applied (IMO) to pilots.
It should be noted that this airplane has a "common type rating" with several other models. Granted it is 'similar' to those earlier models but it is not the same. For starters, according to the specs the engines have double the shp of the 300 and it is substantially larger. I can only wonder if the same sims are used for all types or if the sim is specific to the Q-400.
It's a personal peeve but I've always had a problem with "common type ratings" for substantially different aircraft. That's driven by economics - not flight safety. A good example is the DC-9. "Differences training" is an excuse, not an answer.
The autopilot nose up trim plus the effect of so much power added suddenly would increase significantly the effects of any pilot applied back pressure - and gravely aggravate the pitch up effects.
If the airplane is trimmed to hold an airspeed the nose isn't going to drop instantly as the autopilot disconnects. It is either going to stay where it was for a couple seconds or pitch-up. Now add full power in those two seconds and it will pitch up a whole lot - even if you don't touch the yoke. Pull on the yoke at the same time and the pitch-up will become extreme.
In the process you will trigger the pusher right away.
Because the elevator already has much nose-up trim, the application of full power will most likely set off the pusher - even if you never touch the yoke.
You need to touch the yoke - but the input required from the pilot is mostly likely going to be forward pressure to hold the attitude and nose-down trim as the aircraft accelerates - not back pressure.
If for whatever reason you don't train that way - you won't fly that way when it happens.
I suspect the traing here may well be the underlying culprit. That dosen't mean the company didn't comply with what the Feds wanted. Most likely it means that the Feds are emphasizing the wrong thing.
This is a fairly big airplane. It's not a Navajo or a King Air.
I can deal with pilot error - but I have problems dealing with errors that result from defective training or poor design.
Surplu1 said:
"I can deal with pilot error - but I have problems dealing with errors that result from defective training or poor design."
Fair enough. Excellent point.
Q400 sim is not interchangeable with the 100-200-300 series.
Difference between shaker and pusher is .05 Vso (shaker 1.1, pusher 1.05).
I don't know what Colgan's manual says about altitude loss in a stall recovery in the Q400, but Horizon's says:
"Stall recovery is prompt following relaxation of rearward pressure or application of gentle forward pressure on the control column. Altitude loss during recovery can be minimized by the simultaneous application of power and positive control of pitch."
In other words, the operator of the largest fleet of 400's in the world does not consider stall recovery and "no altitude loss" maneuver. I think if an FAA inspector or check airman tried to ding someone for some altitude loss on a stall, the candidate could make a very reasonable case that such an expectation is unwarranted, unsupported by the FOM, and probably not a great idea in terms of ingrained reactions in the real world.
At Mesaba, if memory serves, they were worried about a net loss, ie at the end of the maneuver get back to the same altitude. At some point, I think the training department finally said something like, "Get it flying again and worry about the altitude bust later with an ASAP."
They weren't concerned with flying the same altitude the whole time.
Agreed, it is a "minimal loss" goal, not a constant altitude.
This is developing a feeling of going way off on a tangent now. Different aircraft have different recovery technique mostly dependent upon power available. The saab is underpowered-it actually requires a nose drop to recover. The two hawkers I'm typed in, one (800) was pretty much a light lessening of back pressure with power and the 1000 would just fly out of any of them by holding pressure.
I just don't see it, if it's a tail stall there will not be a shaker, and since the ap kicked off with the shaker (and not forces), regardless of training, pitching the nose up is just not something I can see this guy doing-especially to the degree the plane did. If anything, he came out of a saab and had a short time in the Q, wouldn't instinct after years of dropping the nose while sim-stall training override the new technique?
Nah, something else is going on-maybe the forgot power thing, I don't know. What I keep coming back to is the extremely low speed the gear came down at. Right now there is no good explanation for that.
Anyone else notice that his name is not featured prominently in the stories the last couple of days, I think finally someone told him to STFU. Damage is done though, NTSB spokesmen shouldn't be speculating, period. that is a right you lose when you get privileged information as part of the accident investigation team. imho.
I’m not going to say you’re wrong sinkrate – because knowing a little about the FAA you’re probably dead on right. But, that does NOT equal the right thing to do in stall recovery training. Please don't take this personal - it has nothing to do with you on that basis.​
I’ll confess I don’t remember when the last time I looked at 121 Appendix F was, or more importantly – cared much about what it said. Yes, I’ve been a Sim instructor & a training captain but never by choice wanted to be a Check Airman. Turned it down whenever offered, which was more than once. That was precisely because of conflicts with the FAA.​
The reason for that isn’t arrogance – I’m about as far as you can get from being a pilot with an ego or a know-it-all attitude.​
In fact every airliner I’ve ever flown as captain was especially modified for me. Right next to that hook where you hang your hat – there was a special two-position switch (ON/OFF) installed. It was labeled - Ego Switch. ​
After hanging the hat, the 1st thing on the before-start checklist was to select that switch to the OFF position. It stayed there for the duration of the flight. The last thing on the shut-down checklist was: Don Hat – Ego switch – ON.​
Now back to the FAA. The FAA is made up of people – and they’re just like you and me. Some of them are very bright. Many of them work there because they couldn’t get hired anywhere else. Some of those turn out to be POI’s.​
In the good ol’ days we didn’t have FSDOS. We had GADO’s and ACDO’s. ​
GADO’s (General Aviation District Office) were for light aircraft – they took care of the small planes, gave check rides to new pilots, appointed examiners, and told us all how to fly. New pilots and CFI’s thought of them as demigods and hung on their every word. Most of the inspectors had precious little more experience and sometimes a lot less than the pilots they supervised. 135 POI’s came from the GADO.​
ACDO’s (Air Carrier District Office) were for the airlines. They did most of the same things that the other folks did, but there were some major differences. 1) All of the pilots in the ACDO were experienced airmen. 2) They were regarded as equals (if that) and not gods. 3) They didn’t try to tell us how to fly – they usually asked us. 4) They were typed in the aircraft in/for which they gave check rides. 5) Most (though not all) had flown the line before they got the job. The POI’s always came from the ACDO.​
Once in a while you’d get the proverbial AH. Usually that was an X-military jock of field-grade rank that was accustomed to “giving orders” and thought he could do the same in the civ, world. Usually it didn’t take long for us to run them off – usually to some 3rd world country. [No, I have nothing against the military – that’s where I learned the trade – or thought I did; I was wrong.]​
Then one day somebody had the bright idea of consolidation, and the result was the FSDO, which made one out of two. In short order just about everything went to h-ll in a breadbasket. We had people telling us how to fly airplanes that they couldn’t fly themselves. People giving check rides and line checks that were not rated in the type. People with backgrounds in light airplanes serving as POI’s with airlines. Training regimes and modules that had everything to do with “rules” and little to do with the real world in which we worked every day. The one-size-fits-all concept may have pleased FAA managers but airlines that got the GADO types were not pleased at all.​
I recall one instance where a former GADO dude giving a check ride in a 72 in which he wasn’t rated nearly resulted in the temporary shutdown of EAL. I also remember a PAA crew walking off the airplane and leaving the FAA to figure out what to do next. The ‘white hats’ just weren’t going to put up with the nonsense.​
The regional carriers usually got stuck with the newbies and the GADO types. Well, the regional carriers have evolved. They are not flying Bandeirantes and Metros any more. The equipment is every bit as sophisticated as that of the legacy carriers, even if not as heavy. ​
Over the years a lot of that has gone away, particularly in the large airlines. However, a whole lot of the BS is still present in the regionals – or at least the one that I worked for. When I first started there I had to unlearn a whole lot of things to keep up with the FAA circus and fill in the squares. At the time the company didn’t have the cojones to tell the FAA when to bug off. Eventually most of that was overcome but only after the company started changing the equipment. From what I hear, some of the residue is still left.​
All of that war story relates to why I think that training for recovery from an approach to a stall or a stall - that requires it to be “a constant altitude maneuver” [your words] is bad training – whether or not it says that in Appendix F of FAR 121. If it says that (I believe you) then it needs to be changed, and now.​
While training does have to comply with the rules, that is not and should not be its primary purpose.​
I believe that making stall recovery’s primary focus ‘a constant altitude maneuver’ is not only a bad training procedure but a dangerous procedure.
The FAR’s are not written in granite; they can be changed and have been many times over the years. Training manuals are written by operators and approved by POI’s. They can be changed too and often are.
If you know or sincerely believe that something in the FARs is wrong you don’t just acquiesce and go with it. You fight to get it changed. The FAR’s are not intended to assist in killing us. They are intended to keep us safe. As long as you can show that you know what you’re talking about, you can find people that will listen and make things happen.​
I sincerely hope that method of training did not contribute to the upset of 3407. Unfortunately it looks like that possibility is lurking in this tragic accident.​
PS. Kudos to Horizon for what appears to be a prudent and sensible training policy.​
If they added full power and pitched up aggressively that would be the ground prox escape maneuver. Fatigue can do strange things.
