Colgan 3407 Down in Buffalo
I too am wondering why it would pitch up first.
I think there is more to the story than just "ice brought them down"
also, see these pics, if they landed bottom first (for lack of a better term), why is the gear so pristine?
I believe they landed inverted, flat, facing the other direction
http://www.cnn.com/2009/US/02/15/buffalo.plane.crash/index.html#cnnSTCPhoto
I was thinking the same thing about the MLG in the photos, but then why is the tail in such perfect condition?
What would be considered a nominal speed in this config?
Don't know...seems okay to me based on my experience in other types but I don't know the Q-400.
I have ridden on many of the Dash 8 variants. I did my time as a turboprop guy and never flew any of the RJ's...but I feel better when I walk up to a Dash than when I walk up to a CRJ or ERJ. Fracking thing is built like a tank and they look right.
I don't know about a Q400, but in a -100/200/300 that is way slower than when you would normally drop the gear... The gear horn goes off at 130 Kts so long as the power levers aren't at takeoff. Still a ways off from stall, mind you, but it is slower than normal.
I've thought about the scenarios above that state that the power lever position is the only factor that caused the accident and I just don't see how that would work. From what I've seen in the NTSB briefings, the power application followed the rapid pitch and was nearly simultaneous to the stick shaker.
I'm not rated on the Q400, I've never even set foot on one, but every other aircraft I've flown we've trained for that exact scenario and the aircraft never had a violent pitch up to the point of stall and then entered a spin before the pilot could correct just because the power went from idle to full.
I'm not saying that it is impossible, it just doesn't seem probable. And I'm stuck on this idea that they entered the spin because of the slow speed at which they impacted the ground even though the aircraft had a steep nose down pitch and full power and a very high descent rate.
I've been throwing around some ideas:
Sudden weight shift in the cargo area?
Catastrophic failure of the elevator controls?
Extremely fast trim runaway (highly improbable)?
Some weird reaction to the ice?
What can cause the Q400 to pitch up so rapidly that it enters a stall?
Not sure if this has been talked about, but the Dash 8 is known at times to have the Trim Freeze up. It hasn't happen to me, but I have had a few Captain's talking about being in some really good icing conditions and having the Trim Freeze up.
Just thought I would throw that out there. Like I said it has never happened to me personally. Maybe some that experienced it can chime in.
There was some questions related to when the stick shaker went off, auto pilot knocked off, and we had the nose down turn, what would the pilot have done? Did he rapidly pull back at that point somehow leading to the flat type spin that seems to be the way it went in.
Another thing is the switch that increases airspeed in ice and the 134. Is this right or should it have been more by the 20 knots mentioned. I thought the briefer did an excellent job of not putting the crew out there while explaining what is going on. While the media does not get it right, the people they get there by this point are usually the more educated aviation press while initially you have people just trying to fill some air..
With gear down and flaps 5, I would not be slower than maybe 160 or 165, perhaps even faster especially with the ref speeds increased in icing conditions. You would have to be below 181 for flaps 10, or below 172 if you wanted flaps 15.
The increased ref speed switch increases by 15kts. And 134kts for gear down is very slow. Gear is usually coming down around 180. Somewhere around 150 is when flaps 35 is usually selected too.
Hate to speculate, but since we are speculating anyway. Is it possible there was a tail stall. as the nose dropped the crew yanked back to correct from tail stall, the tail regained lift, rapid pitch up followed by a wing stall and spin.
The reports are that the deice system was turned on. Question for those that fly this airplane: When you turn on the deice system do all the boots activate at once? Or do the wings blow, and then the tail later? I'm just wondering if the wings had been cleared but the tailplane was still iced.
Where are you guys getting this spin notion from? I looked at a Q yesterday, and FWIW could not imagine an airplane with that big a tail, on that long of a moment, entering a spin. I could be wrong of course.
Its automatic, it sequences from the wings and tail. Works well, there is a knob to select Fast or Slow in the cycling. Also on the Captains overhead panel are the lights that light up once each boot inflates showing you that the system is up and running. Piedmonts Procedure is to Put it on Fast mode anytime you are in icing.
That is a great idea btw. Why put it on slow? I hope we will be able to find out where the crew had that switch set to- fast or slow.
Colgan 1549 follow up
Surplus 1 said:
As the aircraft levels, the auto-pilot trims nose up to hold the altitude as the speed decreases. The nose up trim continues slowly unnoticed by the crew. The auto pilot is also inducing aileron trim at the same time – to keep the wings level - also unobserved.
Could this accident have been avoided? YES – but not after the upset occurred.
hypothetical.
Well thought out scenario..., doesn't even require any real effects from ice. Be interesting to see what the power setting was while decelerating, while the autopilot held altitude towards the FAF (did they decel into the stall driving in?) Didn't notice the decaying airspeed and approaching stall condition until the high AOA kicked off the autopilot just prior to stick shaker & upset? Full power on the engines hung from the wings (upon stick shaker as first warning to crew) cause initial pitch up?
ILS23 FAF at BUF just under 1500' AGL 4.4 miles from the threshold... upset the aircraft at that altitude and there is no recovery.[/quote]
Thanks for all of your inputs - everyone.
I may have been a bit too vague. The hypothetical scenario was intended to include ice contamination of the airfoil - most probably asymmetrical ice. This would produce stall speeds and critical AOAs significantly higher and lower respectively than normal. The asymmetrical accumulation would induce the autopilot to apply aileron to keep the wings level. I doubt this would have happened in an ice-free environment.
In the hypothetical scenario, auto pilot disconnect is not commanded. [I believe that is consistent with the reports we have so far, i.e., the auto pilot disconnected itself.] It occurs because the autopilot has exceeded its limits (either in roll or pitch or both). My own belief is in roll.
Those who have pointed out that in a tailplane stall the pitch would be nose down are correct. While I didn’t deal directly with that in the hypothetical, I think it was an error on my part that doesn’t fit what we know now – which I did not know at the time.
Given the reported sequence of excursions (pitch and roll) that have since been posted – if they are accurate – I personally do not believe that there was a tailplane stall in this accident sequence. I now believe that the wing stalled. I also believe that one of the two wings stalled before the other. That does NOT mean that I think I am correct. It just means that the available information is pointing my thinking in that direction.
The more information that comes out, the more I see this upset as being remarkably close to the upset sequence that happened to Comair 3272 on its approach to the Detroit area. Up to this point the only major difference I note is the altitude. In the CMR event they were at about 4000 ft (don’t remember exactly) when the upset occurred. If I recall correctly, the time lapse from upset to impact was 17 seconds – based on FDR data.
In this accident sequence - When the autopilot disconnects the nose pitches up immediately (due to the unobserved up elevator trim that I mentioned in the 1st post) and the wing immediately exceeds the critical AOA and stalls. At the same time, one wing stalls more than the other (due to the ice – I believe) and the aircraft rolls in that direction - primarily because the only thing that has been keeping that wing from dropping was the control pressure (aileron) applied by the autopilot.
That would leave us with this unanswered question: What made the autopilot disconnect? I obviously do not know but I do have a theory.
There was a lot of ice on the airplane – much more than the crew realized. There was more ice (for some reason) on the left wing than on the right wing – perhaps behind the boot; Enough to make the left wing drop and the aircraft turn to the left. The autopilot applies enough aileron to prevent the turn (keep the aircraft from banking) or if in a turn, to keep the bank angle from exceeding the norm (about 25 degrees on auto pilot). So far so good.
Note: Shortly before this all happened the aircraft was reportedly vectored to a heading of 260 and cleared for the approach. That appears to comply with the 30 degree localizer intercept angle that controllers are required to give. Continue.
As the aircraft captures the localizer, the autopilot makes another left turn to the inbound heading (I have no plate – but let’s say 230). The autopilot studiously accomplishes this turn. It relives the pressure and the aircraft banks to the left. That’s what it is supposed to do. [All the while more ice is accumulating].
[As you review this keep in mind that both wings don’t necessarily stall at exactly the same time. If one wing is flying and a part of the other is not the aircraft will roll in the direction of the wing that is partially stalled.] Continue.
The next thing the autopilot has to do is stop the turn and hold the localizer. To accomplish this it must apply enough aileron to raise the left wing. It tries but the left wing is heavy with ice and it doesn’t come up. The autopilot tries harder - until it reaches and exceeds its limits. At that instant – the auto pilot disconnects itself.
If this assumption is correct, the aircraft immediately rolls hard left. At the very same time the auto pilot (previously) induced elevator up forces take effect and the nose pitches up hard (+31 deg. according to the reports.)
[Keep in mind that most of us have never seen more than 30 pitch up in actual flight. Perhaps in simulators but not otherwise. This is not ‘normal’ in T-category aircraft. Even if it were, it would not happen suddenly and unexpectedly].
The excursion is so rapid that both shaker and pusher activate almost simultaneously. [The prior post says +31 nose up and 46 deg (left) wing low.]
At this point the upset has occurred and there is really nothing the crew can do to recover within the available altitude. Of course that doesn’t mean that they stop flying. To the contrary – they react immediately in an effort to recover from the unusual attitude.
Taken completely by surprise, the PF (pilot flying) grabs the yoke, moves it full forward and at the same time applies full right aileron to raise the left wing. Full power is applied. [The power application helps to increase the nose up tendency and the PF fights it – as is natural].
The nose rapidly drops through a 76 deg. arc to a -46 deg. nose down pitch and the aircraft accelerates. PF applies up elevator (a whole lot of it) to stop the excessive pitch down. The nose comes up rapidly but most of the aileron input is still there (not consciously). A secondary stall (accelerated) occurs (shaker/pusher activate again) with the aircraft rapidly rolling (almost if not snapping) to 105 deg right bank angle [technically that's partially inverted].
In the effort to recover, control movements are extreme. There is much over-controlling. That's not pilot error, it's to be expected under those conditions. The PF will always be a little behind the aircraft's reaction to control input – this is acrobatic flight but it is not intentional. All of these things occur in 5 seconds or less. Remember - they are not visual - this is all on instruments.
I've never flown the Q-400 or its predecessors. I don't know what if any limits the attitude instrument may have. Are they capable of normal function in acrobatic flight? Can it maintain accuracy with a 105 deg bank angle? Some can, others can't. How much pitch excursion does it take to make the presentation illegible? I have no idea. Can the back up gyro handle that? I don't know. The AS indicator is probably a tape - is it easy to read or does everything become hieroglyphics in the process? I don't have those answers.
You ask: "(did they decel into the stall driving in?) Didn't notice the decaying airspeed and approaching stall condition until the high AOA kicked off the autopilot just prior to stick shaker & upset?"
I think the answer to that question is YES – they decelerated gradually into the stall regime. Why did that happen? Not too difficult.
There was no reason to believe that the airspeed indication was critical. They were intentionally decelerating and IAS was well above stall (under normal conditions) - under normal conditions. Note caveat: I have no idea what a ‘normal’ approach speed for the Q-400 might be but 134 kts does appear to be somewhat slow at the OM (with zero flap) for an aircraft of that size – by about 40/50 knots.
But, conditions were NOT normal. There was likely a great deal of ice on the airframe - in places that they had no way of seeing or knowing. Critical AOA was much lower and stall speed much higher than 'normal'.
Continued below
Continuation
My educated guess is that the autopilot did not disconnect because of the up elevator trim or because it was kicked off by high AOA. I say this because the reports indicate that the autopilot disconnected before the shaker/pusher activated. If that is correct - It disconnected because its ability to control the bank angle had exceeded its limits. That’s my theory – and that’s all it is; a theory.
When the disconnect occurred, the nose up elevator trim caused the initial pitch up. That pitch up caused the wing to stall - very suddenly and immediately.
The reports tell us that an attempt was made to retract the flaps (and maybe the gear). If that is true – it was mostly likely because the PF associated flap extension with the upset. In any event in stall recoveries in this category of aircraft Training often says “max power, flaps up, gear up”. Again, I have no idea what that airline teaches, so that thought is pure speculation. In any case I consider it to be essentially irrelevant in this instance.
Again, I know nothing about this a/c type but my guess is that the elevator trim is electric - and there is no trim wheel in the airplane (something I personally find objectionable – just a quirk of mine). Therefore, it is especially difficult to tell where the elevator trim may be at a given point in time, especially at night in a dimly lit cockpit, when the a/c is being flown by the auto pilot, holding altitude, undergoing power changes and decelerating – all at the same time.
An upset in a transport category airplane is simply not recoverable at an altitude of 1500 ft AGL; certainly not on instruments and totally unexpected. Most if not all upsets are never anticipated.
The very best among us have worked experimental upset scenarios in simulators trying to develop satisfactory recovery techniques (down in MIA if I recall correctly). They developed some ideas but no real solutions and no brilliant recovery technique. Unless there is a great deal of altitude below you, the only thing they managed to prove was that upsets in T-category aircraft are not recoverable. They must therefore be avoided by all possible effort.
Avoidance isn’t cut and dry. Each aircraft is different and one size just doesn’t fit all. Likewise, Icing is a different ball game in each machine. As someone before me pointed out: “In aviation there are three types of ice: Good Ice, Bad Ice and Hazardous Ice.
Good Ice is found in the galley”.
This is NOT the first incident or accident to result from an upset. Perhaps it is the first in the Q-400 but that aircraft can't be so unusual that it 'can't happen'. We all know Murphy’s Law.
Several upsets have occurred in the Brasilia. At least two that I know of resulted in accidents, one of them as tragic as this one. More than one has resulted in structural damage. ALL occurred while the airplane was being flown by the auto pilot and several in VMC. There have been several in versions of the ATR, especially the -42, at least one of which was also a fatal accident in this country. Its obvious or should be, that these new generation turboprop aircraft require their own rules of operating technique and flight crew understanding. The results indicate that some of the invented simulator scenarios just aren’t cutting the mustard. We just can’t keep repeating the same thing over and over an hoping for different results.
It should also be noted that upsets have occurred in heavy jets as well and in small jets too – also involving autopilot operations and situational awareness.
Unless we choose to make ourselves aware of history and act differently as a result of our knowledge, history will surely repeat itself.
It is not my purpose to affix blame or to be critical of anyone. Its not about blame, its about cause and effect.
It is my purpose to do whatever I can to avoid unnecessary repetition of tragedy or even white-knuckle operation. I am willing to err on the side of safety in that effort. I also believe in the axiom – knowledge is power.
If you see error in this phase 2 hypothetical please point it out. I won’t be embarrassed if I’ve made a mistake. At this point I am willing to rule out the tailplane stall theory.
“Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.” — Captain A. G. Lamplugh,
PS. Sorry for being so long winded.
The part i dont get, is if there were no pitch control input changes prior to the AP disconnect, why would it pitch up? They were already trimmed for level flight (pitch) and possibly coming out of the initial intercept turn (roll), but still 'in level trim', so if the roll excedence were to cause the disconnect, it seems that the pitch shouldnt change? I think i understand when you say that when they were slowing the trim was compensating for the required trim until it reached a limit but usually when you get a AP disconnect because of limits, the plane stays where it was, whether it be level pitch, or in a 20 degree bank turn, or what have you because thats where it was when it disconnected.. Granted you have to take immediate control to prevent something from happening further. You might be right about the wing stall but the nose would dive and the pilot would yank bank which would address the pitch up reports.
