whymeworry?
- Sep 17, 2005
Yes it dose. I think they waited to long to advance the thrust levers.Forgive my ignorance, but does manually advancing the power levers over-ride the AT's in any way, even temporarily? Seems like it should be designed that way just in case.
And I think you're talking out of your ass because you don't have a clue what happened on that airplane. Why are some of you so quick to throw fellow pilots under the bus?Yes it dose. I think they waited to long to advance the thrust levers.
If the power dropped off line and there was no power to operate the Autothrottle System, then how could they advance forward to command more power as the pilots described? Unless the engines still provided enough rotation to maintain residual power to every thing. If that was the case then why did and of passengers notice the emergency lighting come on before impact?
Typically, if there is total electrical power failure on an aircraft with FADEC controlled engines, the engines are designed to operate at a certain speed...I can't think of the correct terminology at the moment as I only have 1 eye half open and trying to get the coffee going.If the power dropped off line and there was no power to operate the Autothrottle System, then how could they advance forward to command more power as the pilots described? Unless the engines still provided enough rotation to maintain residual power to every thing. If that was the case then why did and of passengers notice the emergency lighting come on before impact? The passengers interviewed claimed every was normal till impact. Some thought it was just a very hard landing.
SG
Cardinal;1498233Incidentally said:against[/I] stabilized approaches.
Well, usually when there's a crash and no fire = no gas.
1. They landed it on wet rain soaked grass = not a lot of sparks
2. In a fuel starvation incident, it is astronomically unlikely that BOTH engines would quit at the EXACT same time.
3. Lots of talk about the APU, did it actually start?
The right wing was nearly ripped off? No fuel spillage? Hmmmmm.
