automatic checkride busts - your opinions
In training? Sure. On the checkride? I don't think I'm such a big fan. The PTS does give the examiner the discretion to make the applicant do a raw data ILS, but IMHO (and MHO only) the examiner had better be able to justify the reason as to why the applicant all of a sudden lost his flight director.
Depends on the MMEL, and the limitiations that come with the deferred item. If it is in the MMEL it is fair game. If your 'time in type' is long enough sooner or later you will see the defer.
Most 'type' rides are given following the completion of of an 'approved training program', be it a 121 or 135 air carrier program or a 142 school such as FSI. The rules governing those programs allow the designee to give credit for some items in the Practical Test Standards if they are documented in the training program. Most do so.
Long and short of it is the PTS tells both the applicant and the examiner what constitutes a 'failure'. If you are completeing an approved program - pay attention and you will do fine.
Haven given many check rides, both military and civilian. My biggest problem is with a PIC who is not the Captain, does not take charge of the cockpit, does not use or properly direct his crew. The guy flies by standards, but is always behind the airplane. They seem surprised by what will happen next. Like on a NPA, the configuration call of "Gear Down, Flaps 25, final item" shoud be done about two miles from the FAF, but this guy calls for it just before getting to the FAF, doesn't bust stds, but is working his butt off to stablize due to late configuration.. BTW Just a tip I give to trainees' the ATP stds for flying at MDA are -0 +100', fly a +50' over MDA, it gives you fudge room and is within stds. I have seen too many pilots who try to fly at +0, it just makes it much easier to bust.
Runaway stab trim after v1 but prior to vr on a 12,000' runway with a balanced field of 3500'?
No clear cut answer on that .... but if any examier would give you that senerio he/she is a total a-hole.
It depends. If your GOM says you will go post V1 (if the aircraft is capable of flight) then you go. Runway length is irrelevant. Stick to your SOP then there is no chance for any mis-understanding.
That is approaching loss of control, which is an emergency, use emergency authority do what you need to save the situation. How about both engines flame out at Vr? Worry about CYA after the fact. SOP is for normal procedures.
I agree in a real live situation, aviate and worry later about arm chair quarterbacks. As far as a check ride goes, the only " double" anything I every simulated was a engine fire followed by a failure. I have been out of the industry now going on four years, and with 4 more years in age, I'm too lazy to look it up, isn't most double failures not allowed by the PTS? Of course, if the crew couldn't identify and verify a dead engine and shut down the wrong one, that was on them! ( fortunately that was training and not checking and after the talking too afterwards, I'd bet it won't happen again with those two;) )
Never heard of a "minus anything" call out in any plane I have trained on...
What do they rec'd?
I hope not discussing what the light/situation is?...I have heard some odd stuff at training centers, like aborting at V1-1kt for a screen failure...not happening on most runways we use. Common sense applies - 12K runway or 4K runway? They said it didn't matter...:confused:
Its all in the brief, get everyone on the same page.
We used to brief "After 80 KT, abort only for engine failure, fire or directional control problem". At V1, take it into the air.
30 KT windshear at liftoff: the airplane WILL land. Take the abort rather than trying to accelerate and fly. I've done it. It works.
So you abort for windshear at Vr?....:confused:...who analyzes this in the 4 seconds between V1 and Vr?
Do whatever you want, Im more concerned in a thorough briefing than I am in anything else...and the brief should vary with conditions. I'm also sure you define "directional control"
On a 15,000ft runway in a business jet one can simply brief that they want to stop on anything before Vr (if they want)
But sorry, with most of the regular runways I use you wont find me aborting for a windshear at VR.
How about landing? You could be going around 10X on a real gusty winter day at my home airport (on a plateau) if you ran each time it yelled "windshear"
Its a never-ending debate, fly how you like and how your company likes...but planes will continue to go off the end of runways for items they could have easily landed with 5 mins later.
Until you have been there and done that, it is easy to Monday morning quarter back, and that is why CA's are paid the big bucks, to make those decisions, most guys get it right, some don't.
Back to the subject of what can cause an automatic bust. There use to be an examiner around here that would bust you immediately for breaking the sterile cockpit rule. He would even try to get you to bust it by asking unimportant questions. One guy that was taking his ATP single was taxing out when the examiner asked him about what type of plane that was sitting on the ramp. When he answered, the examiner told him to taxi back. Immediate bust! That question was not pertinent to the flight so he busted him for answering instead of telling him to be quite unless it was something in regards to the flight.
Not normally. This was a rapid 30 KT rollback of the airspeed drum with the mains about 5 ft AGL (Field elev 6600 or so). Airplane settled to the pavement with about 5000 ft of runway remaining. Got stopped about 100 ft past end of runway. I might have cleared the berm another 100 ft further, but then again, I might not.
Did you miss the "if the aircraft is capable of flight" part? If both engines flame out or if you can't control it then why would you try to fly it?
are you second guessing me?
