Where did this automatic thing even start ? A sky nazi ?
RE: Captain upgrade
Just getting a feel for what you guys consider "automatic checkride busts." This came up as a hangar discussion at our place a few days ago.
We agreed these were automatic, no-choice-but-fail items
1. Incorrect turn on Missed Approach
2. Exceeding a limitation and not immediately recognizing/correcting
3. Stall RECOVERY - improper/sloppy
some banter/non consensus occurred on
cockpit organization, charts, etc
stall entry (knowing the profile by memory or being able to use cheat sheet)
comments ?
Consistently exceeding tolerances stated in the TASK Objective, or failure to take prompt, corrective action when tolerances are exceeded, are indicative of unsatisfactory performance. The tolerances represent the performance expected in good flying conditions. Any action, or lack thereof, by the applicant which requires corrective intervention by the examiner to maintain safe flight shall be disqualifying.
When, in the judgment of the examiner, the applicant's performance of any TASK is unsatisfactory, the associated AREA OF OPERATION is failed and therefore the practical test is failed. Examiners shall not repeat TASKS that have been attempted and failed. The examiner or applicant may discontinue the test at any time after the failure of a TASK which makes the applicant ineligible for the certificate or rating sought. The practical test will be continued only with the consent of the applicant. In such cases, it is usually better for the examiner to continue with the practical test to complete the other TASKS. If the examiner determines that the entire practical test must be repeated, the practical test should not be continued but should be terminated immediately. If the practical test is either continued or discontinued, the applicant is entitled to credit for those TASKS satisfactorily performed. However, during a retest and at the discretion of the examiner, any TASK may be reevaluated including those previously passed. Whether the remaining parts of the practical test are continued or not after a failure, a notice of disapproval must be issued.
When the examiner determines that a TASK is incomplete, or the outcome uncertain, the examiner may require the applicant to repeat that TASK, or portions of that TASK. This provision has been made in the interest of fairness
and does not mean that instruction or practice is permitted during the certification process. When practical, the remaining TASKS of the practical test phase should be completed before repeating the questionable TASK. If the second attempt to perform a questionable TASK is not clearly satisfactory, the examiner shall consider it unsatisfactory.
If the practical test must be terminated for unsatisfactory performance and there are other TASKS which have not been tested or still need to be repeated, a notice of disapproval shall be issued listing the specific TASKS which have not been successfully completed or tested.
Okay opinions are like...
Did the above talk about "automatic busts", read the spirit of the thing, in it's entirety.
As to holding patterns - who cares how you entered, are you on the protected side, end of story.
The idiot playing gotcha with sterile cockpit, he probably shouldn't be giving rides.
And as to stall recovery the FAA just put out an FSO for 121 operators to say there is such a thing as acceptable loss of altitude on stalls so long as terrain is not a factor. The no loss of altitude was a misconception. You know a little comon sense, fly the jet, get some speed, recover.
Some, not all of these little airplane guys, (less than 300 tons) need to lighten up.
