Safety should come before performance numbers.
Yes, and on that token, safety shouldn't be used as a scapegoat for being too lazy to follow the cost savings procedures.
Safety is relative......At one time ALPA said it wasn't "safe" to fly an MD 80 with 2 pilots.....Was it really "unsafe"? At one time ALPA said it wasn't "safe" to have a pilot fly the day after his 60th. birthday...Now it is "safe"....
If you can't take 85 degrees....you probably shouldn't be in the South in July.....
I've refused aircraft for heat....but I also won't sabotage our performance numbers to make a point in this environment.....
Thats the issue Joe...it's NOT 85 degrees! It may be 85 outside, but it will get well over 100 degrees inside the aircraft.
MD80? Need to go back a little further to the DC9, which by virtue of being lighter than the 737 (under 80,000lbs), could be operated by Delta with two pilots.Safety is relative......At one time ALPA said it wasn't "safe" to fly an MD 80 with 2 pilots....
Airline passengers are owed the highest standard of care, an extraordinary standard. (to quote Georgia law, in effect, even in July). What you stated would not meet the test of an ordinary standard of care. The quote states a callous indifference to a known hazard which has resulted in injuries to passengers.If you can't take 85 degrees....you probably shouldn't be in the South in July... . I also won't sabotage our performance numbers to make a point in this environment....
"ASA will not dispatch a 200 with an inop APU with the OAT 30 C or above."
You don't even have to do any standing on your soapbox. Just follow the company's FOM guidance!
