Airtran Pilot/FFDO Arrested: Blows .05 in MSP
  • Thread starter Thread starter SEVEN
  • Watchers Watchers 34
That’s why you should never use mouthwash, toothpaste, or dental floss. You never know how those things will screw up the breathalyzer tests. Thats why my company prohibits flying within 24 hours after a dental cleaning.
I have a problem with that! Not with showing up 0.00%, but with the restrictions on what I can do and what I can't because of what a breathalyzer might show incorrectly. At my airline if you get randomly tested and you blow anything greater than 0.00% the breathalyzer shuts down and a second sample will be taken 15-20 mins after the first one. Mouthwash does cause an erratic reading, however; the measured BAC decreases quickly over time thus eliminates any false reading and values (that's the theory anyway!)
Bottom line is, if you are accused of having a BAC greater than the legal/company limit and you know it is because of mouthwash etc. request a blood analysis. That is medically speaking the only accurate way to determine the BAC.
Speaking of guys on high-protein diets, you should also know that a lot of protein bars are very high in sugar alcohols. (They use those instead of sugars, since they don't really affect the glycemic index...i.e. "net carbs".) We had a guy who ate a protein bar right before landing, got pulled for a random test, and blew through the roof. Luckily, he also did a blood test and showed zero.
Hope this helps,
bs
The problem is that in most cases, the guys who show up blowing heat (America West), more than likely are also running on 4-5 hours of sleep. What if you saw these guys out the night prior and smelled the booze as you and your family walked on the plane? Would you think "Well, at least what they are about to do is safer than driving a car."??
Yes it is safer then driving a car. If those American West guys had actually took off do you think they would have crashed???? These plane fly themselves.... It's way different then driving down a road with only a thin white lines between you and another car traveling at you at 50MPH as your only buffer.
Those guys would have took-off, banged on the auto pilot and took turns sleepin' all the way to PHX. And nobody would have know.
Is it right?? Hell no! But getting into a car boozed up is Way More dangerous!!! Again, I am not saying either is right!!
Hope this helps,
bs
Blood samples are not allowed for DOT Alcohol tests. Breathalyzers only.
I've worked with enough FAA CHDOs to tell you what that means.
It means that working in the office is not considered rest and that if the FAA were to come in and audit your Flight and Rest records and found someone (usually a management pilot) had been performing office duties and flying, they could end up with insufficient documented rest.
It does not greenlight Mardi Gras on an overnight, sorry. Try Again.
But I would be interested in being pursuaded how turning a 4-day trip into a jet-powered trans-continental pub crawl enhances the professionalism of pilots, and how that bad old TSA shouldn't harsh our mellow. And if you've got time, maybe go over how the behavior of Wall Street types has any bearing on how professional aviators should behave, because that one sounds kinda 3rd grade to my old ears.
I'm saying the same outrage should apply to scheduled reduced rest since the same impairment exists.
And the reg is very clear- am I even required to stay at the company provided hotel?
No.
Sorry, but you're wrong on that one Bring-
And I'll never ceased to be amazed at how quickly an INCREASING # of pilots will join in on the witch-hunts-- assuming the worst of people who's performance record is statistically incredible
Yep. I was completely against drug-testing for pilots, and still am. That was nothing more than political posturing by Elizabeth Dole, who was DOT Secretary in the late '80's.
Why am I against drug-testing? Because drug-testing solves a problem that doesn't exist, while ignoring the real problem- impaired performance.
Sure, you can be an insomniac neurotic who is in the midst of a terrible divorce and custody fight and has been living on pretzels and coffee, but as long as you pee clean, you're "good to go".
You're just clueless aren't you?
"It turns out that the human body itself produces a large amount of acetone when a person follows an extreme low-carb diet (i.e. "protein breath") and most breathalyzers cannot distinguish between acetone and alcohol."
So I guess alcohol produces a big reading too. Damn. I hear this guy was under the impression SWA still had the 1-2-3 drink specials on their overnights, and was just getting in shape for the transition. No pilot left behind..
Run along son. Your student is waiting and that 152 is booked for the next hours.
MaxThrottle is a SWA pilot who recently created a new screen name. It might even be BobDylan (who is actually a SWA pilot borrowing a buddy's login).
Either way, with 7 posts, all anti-AAI B.S. that are combative, to say the least, he's going to make my ignore list in short order.
So what about someone who drives up on a DUI checkpoint, gets stops and blows a .20 (very hammered). Is this entrapment? I've heard of people getting DUIs who claim that they are safer drivers drunk than many people on the road who are sober. Maybe, maybe not, however, there has to be some standard. By saying that a major airline pilot who just downed 10 rum and cokes is safer than a tired, underpaid, commuting, just divorced regional pilot is not very logical. You can't test for "tired" or "stressed." New enhanced rest rules, no matter how conservative, will do nothing to stop pilots from flying tired.
I'm not saying any of that, Chief. I'm saying that I think that drug-testing is a waste of time and money (unless you work for one of the large companies that get the millions of dollars in revenue).
My point is that we should be teaching crew how to be aware when they or the other pilot aren't performing properly, regardless of the circumstances, instead of screening urine specimens for drugs that aren't even of remote interest to airline pilots . . . PCP . . . . heroin? GMAFB! Xanax, Ambien, and antidepressants, maybe, but they don't test for those.
